Полный config эмулятора CCcam
# CCcam team uvadi CCcam v2.0.9
# Special greets go to all our friends all over the world, you know who you are!
# Specjalne podziekowania dla Ludzi z Polski, dzieki ktorym jest duzo nowych funkcji w wersji 2.0.0
# Ostatnim razem zapomnielismy o nich wspomniec w readme. DZieki Chlopaki!
# friends #
# syntax for to add a friend user to CCcam with the max up hops limit (default = 5)
# sharing of emus (default = 1), allow emm (default = 1), and optional
# downshare limits per share (default = no limits) and optional
# downshare limits per share based on caid:id:sid
# and optional timeslots in which share is valid (to block channels on box of children after 19:00 for instance)
# if no timeslot is defined 24 hrs a day is used
# emus are shared only one level down, even if no limits given
# max username length 20
# password length 'unlimited'
#F: <username> <password> <uphops> <shareemus> <allowemm> ( { caid:id
downhops), caid:id
downhops), ... } { caid:id:sid, caid:id:sid, ... } { begintime-endtime, ... } ) hostname/ip address
# example:
# F: user1 pass1
# user1 gets all our shares at max 5 hops from us
# (our local cards + max five hops away). He can share down to his own
# clients. He also receive emu shares (if he has 'yes' behind his C: entry),
# and is allowed to send us emm.
# F: user2 pass2 0 1 0 { 0100:000080, 0622:000000:1, 0500:000000:2 }
# user2 gets only our local cards but no 0100:000080.
# and our 0622:000000 cards only for himself (1 hop down),
# and 0500 cards for himself plus one additional hop down.
# He also gets our emus, and is NOT allowed to send us emm (updates).
# F: user3 pass3 5 0 1 { 0:0:3, 0100:000080:1 }
# user3 gets all cards at a maximum of 5 hops away from us,
# and get's to share them down two further levels beyond his own level.
# But he is not allowed to share 0100:000080 down to other users.
# He gets no emus from us, and he is allowed to send us emm.
# F: user4 pass4 5 0 1 { 0:0:3, 0100:000080:1 } { 0100:000080:15df }
# user4 gets all cards at a maximum of 5 hops away from us,
# He is also not allowed to view channel 0100:000080:15df
# F: user4 pass4 5 0 1 { } { } { 12:00-17:00, 19:00-20:00 }
# the share is only valid between 12:00 and 17:00 and between 19:00 and 20:00
# outside these hours the share will not give cw's to the client
# F: user5 pass5 5 1 1 { } { } { } 192.168.1.1
# user5 gets all cards at a maximum of 5 hops away from us
# user5 is only allowed to connect from the host 192.168.1.1
# connections #
# syntax for to add a client connection to other CCcam
# add yes on end to use friends emus (non public private key/emu,etc...),
# but only works when corresponding F line on server has '1' for <shareemus>
# optional limits just like F line, but for incoming shares (ignore shares more than 'uphops' away)
#C: <hostname> <port> <username> <password> <wantemus> ( { caid:id
uphops), caid:id
uphops), ... } )
#note: if {} limits are added, <wantemus> cannot be omitted. Use either yes or no.
# example:
# C: someserver.somedomain 12000 user1 pass1
# C: 192.168.1.2 12000 user2 pass2
# connects to CCcam without use of friends emus
# C: 192.168.1.2 12000 user3 pass3 yes
# connects to CCcam, and receives friends emus also.
# syntax for to add newcamd server connection
#N: <ip> <port> <username> <pass> <des(14byte)> <nr_of_hops_away (default: 1)> <stealth mode (default: 0)>
# example:
# N: 127.0.0.1 10000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14
# add a newcamd card, give it an offset of 2 hops, in the share list
# N: 127.0.0.1 10000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 2
# stealthy login on newcamd server:
# N: 127.0.0.1 10000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 1 1
# stealth modes: 0 = disabled, 1 = mgcamd new, 2 = mgcamd old, 3 = evocamd, 4 = generic
# syntax for to add radegast server connection
#R: <ip> <port> <ca4> <id6> <nr_of_hops_away (default: 1)>
# example:
# R: 127.0.0.1 678 0100 000080
# syntax for to add camd3 connection
#L: <ip> <port> <username> <pass> <ca4> <id6> <nr_of_hops_away (default: 1)>
# example:
# L: 127.0.0.1 567 dummy dummy 0100 000080
# syntax for add gbox connection
#G: <pass> <localhost> <localport> <peerpass> <peeraddress> <peerport>
# support optional limits just like C line (ignore shares more than 'uphops' away)
# { caid:id
uphops), caid:id
uphops), ... }
# example:
# G: AABBCCDD my.address.tv 2500 12345678 peer.address.tv 2500
# Other config settings #
# server shall listen on this port pro incoming connections
# default port is 12000, disable server with parm -s or set port 0
#SERVER LISTEN PORT : 12000
# server can give some info about server and client connections
# and cardinfo using telnet or webbrowser.
# Switch on/off access to info
# default is yes
#ALLOW TELNETINFO: no
#ALLOW WEBINFO: no
# Show extended client info when showing client list
# default is yes
#SHOW EXTENEDED CLIENT INFO : no
# The webinfo service can be protected with a username and password.
# This is switched off by default
#WEBINFO USERNAME : <username>
#WEBINFO PASSWORD : <password>
# The telnetinfo service can be protected with a username and password.
#TELNETINFO USERNAME : <username>
#TELNETINFO PASSWORD : <password>
# default port for telnet is 16000
# default port for web is 16001
# supported commands:
# info
# activeclients
# clients
# servers
# shares
# providers
# entitlements
# example use:
# echo servers | telnet localhost 16000
# go with your browser to
http://ip_CCcam_server:16001
#TELNETINFO LISTEN PORT : 16000
#WEBINFO LISTEN PORT : 16001
# time in seconds to keep On Screen Display active.
# default is 0 (turned off)
#ZAP OSD TIME : 3
# username used to show popup (default : root)
#OSD USERNAME : root
# password used to show popup (default : dreambox)
#OSD PASSWORD : dreambox
# port used to show popup (default : 80)
#OSD PORT : 80
# Serial reader config. Add as many as you have attached too your system
# replaces old name 'PHOENIX READER PATH', but still works.
# default is none
# optionally add readertype : phoenix,mouse,uniprog,sc8in1,smartreader+
# (when non readertype given defaults to uniprog (e.g. for mastera))
# SERIAL READER : <device> <type>
# example
#SERIAL READER : /dev/tts/0
# Serial reader smartcard write delay.
# Setting to finetune smartcard write speed, optimal setting depends on speed of system, and
# speed of card. Default value is calculated, but can overrule by setting.
# Use number of microseconds delay between bytes, 0 = no delay, -1 = calculated default
# Note: huge difference between values 0 and 1, because of schedular overhead
# SMARTCARD WRITE DELAY : <device> <delay>
# example, 10ms write delay on smartcard in reader attached to /dev/ttyUSB0
#SMARTCARD WRITE DELAY: /dev/ttyUSB0 10000
# NOTE on sc8in1; because 8 smartcards are used on the same devicename, use
# devicename_0 .. devicename_7 for settings which require devicename to make
# settings per smartcard. example /dev/ttyS0_0, /dev/ttyS0_1 ..
# example, 8ms write delay between bytes to smartcard on last sc8in1 channel, attached to /dev/tts/0
#SMARTCARD WRITE DELAY: /dev/tts/0_7 8000
# Smartcard clock speed override
# Setting override specified speed for smartcard.
# Don't add setting unless you're sure what you're doing.
# In 99% of the cases the reader selects the optimal speed.
# Adding this setting either slows your card down, or might destroy it.
# SMARTCARD CLOCK FREQUENCY : <device> <freq>
# example
#SMARTCARD CLOCK FREQUENCY: /dev/ttyUSB0 5500000
# if timing should be shown in OSD and debug output
# default is no (turned off)
#SHOW TIMING : yes
# enables mini OSD which shows server(type), cardreader, keys or fta only
#MINI OSD : yes
# turns debugging on and off
#DEBUG : yes
# should CCcam try to read and parse newcamd.conf for server connections
#NEWCAMD CONF : yes
# configure what EMM blocker you want. Add as many as readers you have attached
# default is blocking nothing
# B: /dev/sci0 01
# 00 - nothing
# 01 - sa blocked
# 02 - ua blocked
# 04 - ga blocked
# and sum of for combinations
#examples
#B: /dev/tts/0 07
#B: /dev/sci0 01
# disable all local EMM readers
# saves lots of CPU, but you won't get any updates anymore
# (unless you get updates from your clients)
# default: no
#DISABLE EMM : yes
# with this setting you can
# allow a client on two hops away
# to send the updates to the cardserver
# default : no
#EXTRA EMM LEVEL : yes
# configure how many emm listeners are started.
# for example use 2 when recording
# and viewing different systems and both need constant updates
# default : 1
#EMM THREADS : 1
# overrule the nds boxkey (4 byte hex)
# BOXKEY: <device> <byte1> <byte2> <byte3> <byte4>
#example
#BOXKEY: /dev/sci0 00 11 22 33
# set card pin
# * please be very careful with this option as you could lock your card *
# PIN: <device> <pin>
#example
#PIN: /dev/sci0 1234
# overrule the irdeto camkey (8 byte hex), default 11 22 33 44 55 66 77 88
# CAMKEY: <device> <byte1> <byte2> <byte3> <byte4> <byte5> <byte6> <byte7> <byte8>
#example
#CAMKEY: /dev/sci0 11 22 33 44 55 66 77 88
# overrule the irdeto camdata (64 byte hex)
# trailing zero bytes can be omitted
# default for unknown ASC's is 11 22 33 44 55 66 77 88 00 00 .. 00, known ASC's have other defaults
# CAMDATA: <device> <byte1> <byte2> <byte3> <byte4> <byte5> <byte6> ... <byte64>
#example, when only the first 15 camdata bytes are nonzero
#CAMDATA: /dev/sci0 11 22 33 44 55 66 77 88 99 aa bb cc dd ee ff
# custom add id's for BEEF patched cards
# BEEF ID: <ident1> <ident2> <ident3> <ident4> <ident5> <ident6> <ident7> <ident8> <device>
#example
#BEEF ID: 4101 0 0 0 0 0 0 0 /dev/sci0
# what Softcam.Key should CCcam try to read
# defaults to /var/keys/SoftCam.Key
#SOFTKEY FILE : /var/keys/SoftCam.Key
# what AutoRoll.Key should CCcam try to read
# defaults to /var/keys/AutoRoll.Key
#AUTOROLL FILE : /var/keys/AutoRoll.Key
# what constant.cw should CCcam try to read
# defaults to /var/keys/constant.cw
# file content can be like
# ca4:id6:sid4
mtpid4:ecmpid4:key16(01 02 03...)
#STATIC CW FILE : /var/keys/constant.cw
# in this file you can configure what CAIDs CCcam should prefer or ignore
# defaults to /var/etc/CCcam.prio
# file content can have ignores (I) and prio lists (P)
# note 1: I line affects both for ecm and emm (receive no emm on ignored systems)
# P line only affects ecm choice (emm still received for all available systems, not just the priority system)
# note 2: ident 0 means 'all idents'. So 'caid:0' is the same as 'caid'.
# note 3: for some systems (e.g. nagra (caid 18xx)), the ident is not known at the time the
# prio lists are checked. In that case, matching is done on caid only, even if the P line
# defines nonzero idents. So for example '1801:401' behaves the same as '1801' in a P line
# I lines work differently, they are checked two times, once before ecm or emm is received, again
# after ecm or emm are received (and nagra ident should be known)
# P lines are only checked once, before ecm received.
# note 4: if a P line contains caid:ident pairs which are not available for the current
# channel, that P line is not used for that channel.
# Example, channel has systems 626, 1801:401 then P line with "1801,100:96,626" is ignored by that channel,
# because channel doesn't have 100:96.
# But P line with "1801" works, and also "626,1801" will work for channel
# note 5: P lines are parsed in the order in which they are found in the prio file.
# Only the first matching P line is used
# situation 1: ignore allways this caid, all idents, on all channels
# I: caid
# situation 2: ignore allways this caid/ident pair
# I: caid:ident
# situation 3: ignore this caid/ident pair, on channel 'sid'
# I: caid:ident:sid
# situation 4: when both caid1 and caid2 exist for a channel, prefer caid1 over caid2
# P: caid1, caid2
# situation 5: when caid1:ident1 till caidN:identN exist for a channel, use them in order of this list.
# P: caid1:ident1, caid2:ident2, .., caidN:identN
# situation 6: when caid1:ident1 till caidN:identN exist for channel 'sid', use them in order of this list.
# Sid on first caid/ident pair identifies sid for which list is used. All other sids ignore this list.
# P: caid1:ident1:sid, caid2:ident2, .., caidN:identN
#CAID PRIO FILE : /var/etc/CCcam.prio
# In this file all provider idents are defined
# The info from this file is being used in the web interface
# format:
# <caid><ident> "Provider description"
# PROVIDERINFO FILE : /var/etc/CCcam.providers
# In this file all channel idents are defined
# format:
# caid:ident:sid "Channel description"
# CHANNELINFO FILE : /var/etc/CCcam.channelinfo
# write wrong logins to file
# defaults is off
#LOG WARNINGS : /tmp/warnings.txt
# global setting for stealthy login to newcamd/newcs server, N line can overrule
# default: 0
#NEWCAMD STEALTH : 0
# load balancing between identical cards, list device names of card readers containing identical cards,
# optionally followed by a list of service id's which are to be excluded from loadbalancing
# LOADBALANCE : <device1> <device2> .. <devicen> { <exceptsid1>, <exceptsid2> .. , <exceptsidn> }
# multiple loadbalance groups can be configured, by adding multiple lines
# warning: restart is required, when loadbalance group config changes
#example 1: load balance requests for three identical cards
# LOADBALANCE : /dev/ttyS0 /dev/ttyS1 /dev/ttyS2
#example 2: load balance requests for two almost identical cards, sid 0df3 and 0de1 are only available
#on one of the cards, so requests for these sids shouldn't be loadbalanced
# LOADBALANCE : /dev/ttyS5 /dev/ttyS6 { 0df3,0de1 }
# in version 1.2.1 and lower there was a problem which could lead to disconnecting clients
# in version 1.4.0 network load was significantly reduced
# in version 1.7.0 dangerous password bug was fixed
# in order to take advantage of these fixes, all clients should upgrade
# with this setting you can force that clients at least use a certain version otherwise they are denied when logging in
# default : accept all versions
#example 1: avoid disconnecting clients problem
#MINIMUM CLIENT VERSION : 1.3.0
#example 2: achieve network load decrease
#MINIMUM CLIENT VERSION : 1.4.0
#example 3: don't allow potentially wrong passwords (pre 1.7.0 has password bug)
#MINIMUM CLIENT VERSION : 1.7.0
# Irdeto smartcards: option to disable smart chid checking for irdeto smartcards.
# Default, only chids advertised by card are accepted.
# This avoids a lot of unwanted card traffic
# But if smartcard has hidden/unknown chids, all chids should be tried.
# In that case specify 'TRY ALL CHIDS' option for cardreader.
# Use with care, enabling option causes more card traffic.
# Only use setting when some channels don't work without it.
# note: if even this setting don't help decode all channels, try using
# commandline arg -l, to disable all self-learning features (warning: slower)
#TRY ALL CHIDS : <device>
#example: card in /dev/ttyUSB0 gets ecm for all possible chids, not
#just the chids it officially supports
#TRY ALL CHIDS : /dev/ttyUSB0
# perform smartcard post init commands
# POSTINIT : <device> <filename> (<autodelete>)
# send commands in 'filename' to 'device', and delete 'filename' when
# optional 'autodelete' argument nonzero
#example:
#POSTINIT : /dev/sci0 /tmp/postinit
#example /tmp/postinit contents:
#c134000003000000
#c13201000a
# Option to override autodetected dvb api version. Restart needed.
#DVB API: <value>
# <value> <1 = no dvb, 1 = dvb api 1, 3 = dvb api 3>
# WARNING: only use when autodetect fails!
#example, disable nonworking dvb hardware:
#DVB API: -1
# Option to set global share limits
#GLOBAL LIMITS: { caid:id
downhops), caid:id
downhops), ... }
#example:
#GLOBAL LIMITS : { 0100:000080, 0622:000000:1, 0500:000000:2 }
# all users get no 0100:000080.
# and our 0622:000000 cards only for themself (1 hop down),
# and 0500 cards for themself plus one additional hop down.
# global limits are overridden by client specific limits (see F
# Option to reject shares with less than required downhops on clientside
#MINIMUM DOWNHOPS: <value>
# default: 0 (don't ignore any shares)
#example:
#MINIMUM DOWNHOPS: 1
# ingore shares that have less than 1 'downhops' (i.e. can not be shared
# further down to other clients)
Сами смотрите на какую строку записать какой протокол поддерживает ваш сервак.
