![](/proxy.php?image=http%3A%2F%2Fi069.radikal.ru%2F1004%2Fc3%2F925db0cfcf61.jpg&hash=2815046ef2a3a0dbd89895bcda960a11)
CloneDVD Mobile превращает ваши фильмы в формате DVD быстро и качественно в формат, который ваше мобильное оборудование (Sony PSP, Apple iPod Video, iAudio X5, Creative Labs ZEN Vision, etc) с легкостью может воспроизвести. Вы можете также превратить свой DVDs в другие форматы, как например DivX, XviD, Avi, MP4, и т.п. С CloneDVD Mobile вы можете поместить свои любимые фильмы или TV-сериалы на вашем мобильном видеооборудовании и смотреть их где и когда захотите!
Features
* Convert movie DVDs to play on mobile video equipment like the Sony PSP, Apple iPod Video, iAudio X5, Creative Labs ZEN Vision, etc
* Convert movie DVDs to other file formats like DivX, XviD, AVI, MP4, etc.
* Utilises a high quality picture conversion engine
* Supports multi-angle movie DVDs
* Video Preview shows an overview of all selectable DVD titles
* Target size freely adjustable
* Supports chapter trimming
* Very easy to use: Our unique Filmstrip assistant will guide you step-by-step through all settings - easy for beginners
* Picture snapshots while converting
* Logging window available
* Stable, fast and does not require an ASPI driver
System Requirements
* An IBM-compatible personal computer with a minimum 1GHz Pentium-class microprocessor and 256 MB RAM
* Windows 2000/XP/XP64/VISTA/VISTA64
v1.7.0.0 Final
- added (installer): version now displayed in the control panel's uninstall section
- fix (installer): Windows 7 should no longer display the "this program may not have installed correctly" prompt
- fix: Improved timestamp generation
- fixed: A/V runaway problem with some telecine processed DVDs
- optimized video/audio synchronization with some protected DVDs (Sony/Fox), related:
- fixed: "Audio difference to Video is too large, trying to
compensate" and "Audio did not switch into segment #" errors. - fix: several "pipe broken" errors
- improved: correcting timestamps on the fly
- fixed some issues with Sony DVDs
- improved handling of AC3 streams
- fixed "SWITCH INTO SEGMENT 2" error
- fixed: aborts due to trash data in ac3 audio
- fixed a compilation issue of ffmpeg
- fixed multipass + subtitle encoding
- improved unicode compatibility of registration process
- fixed MPEG2 pass-through profile: garbled resolutions
- fixed: some pass-through modes allowed for zooming options which is nonsense and could also lead to a crash
- error log display truncated to max. 30 lines
- added new generation of PTS/DTS timestamps
- improved video/audio sync if audio starts more than 15 sec after video
- improved DTS handling
- added matrix, user-data (closed captioning) processing in parser
- fixed some iTunes issues
- fixed a log stall when switching between multiple angle VOBUs in
too short a time - fixed several apple profiles
- fixed "broken pipe" error
- several minor fixes and improvements
- updated languages
