Имидж на базе группы Nemesis
allllex
Ferrari-SSL87F-Nemesis2.6-dm8000-e2-OE(1.6)-SVN(107r5)
- Webinterface
- Mediaplayer
- Timeshift
- DTS Surround
- VLC
- Wlan
- dvb-t
- CrossEPG
- Extra.url
- Ferrari AddOns Manager
Nemesis 2.6 107r5
Updated 29.03.2012-13:00
All updates until 105r4 are included
Rewrite device info panel, now are also displayed the network devices
Update dreambox-dvb-modules to 20120322 patched
Update Enigma2 to 3.2.2 (20120327) patched by Yang
Move to 2.6 version
Added possibility to disable HDD as a device for epg.dat, swap files and skins
Added possibility to remove HDD on Picon search path
Update CrossEPG to use new Autodiscover EPG (Only for Nemesis Images)
Update Bootlogo for version 2.6 (thanks @XPlanet)
Replaced the eXcort Lux default skin, with the new Nemesis Black Skin by mmark (thanks @mmark & Stardust)
Added possibility to enable/disable Pig Widget on Skin
Blue->Yellow->Setup Skin->Enable Pig Widget on skin
Added developer mode for skinner (Thank's @skaman)
Added Suppprt for Skins on external device
Now you can install skin on, USB/CF/HDD/eSATA devices
(At the moment 0nly skins without Python code modification)
Added Autodiscover Picon
Discover on: Flash, USB/CF/HDD/eSATA devices and Network Mountpoint
Added Autodiscover swap file
Discover on: USB/CF/HDD/eSATA devices
Added Autodiscover epg.dat file
Added device selection for Picon installation
You can install Picon on: Flash, USB/CF/HDD/eSATA devices and Network Mountpoint
Removed Picon Provider, System e Satellite from image
Now you can install it from Blue Panel->Addons
Updated italian CVS translation using german locale as reference (Thank's @blu8)
Updated Nemesis Panel italian translation(Thank's @blu8)
Updated full german locale translation (thanks @bigstar2005)
Updated enigma2-plugins
More languages
Blue - Blue - Packet Management - enigma2-locale-xx
Нужна регистрация.
tivon
большое спасибо!good! но ссылка не работает, перезалейте пожалуйста
allllex
большое спасибо но ссылка не работает, перезалейте пожалуйста
Ссылку исправил. По ссылкам нужна будет один раз гарегиться. Уже есть свежая версия:
Ferrari-SSL87F-Nemesis2.6-SVN108r4-dm8000-Snack
- Webinterface
- Media Player
- DVD Player
- DTS Surround
- Extra url
- Will give 3D Setting error when open plugin menu
(3D Settings included image, but now work in dm8000 clone)
С этого сайта запрещено давать открытые ссылки. И нужна регистрация. Если я их перезаливаю на другой файлообменник, они удаляются.
allllex
Ferrari-SSL87F-Nemesis2.6-SVN110r0-dm8000-Snack
- Webinterface
- Media Player
- DVD Player
- DTS Surround
- Extra url
- FanControl 2 (enable FanControl2 in plugin menu)
(3D Settings included image, but NOT work in dm8000 clone)
allllex
Немного обновился имидж без замены версии
Добавлено:
Updates 20.09.2012
- WLAN plugin by Fairbird (Thanks Fairbird)
- DTS downmix tested by .mkv and it works (Thanks Yang)
- Enigma Files updated
Имидж скачивать по той же ссылке чуть выше.
allllex
Тебе надо зарегиться на нашем сайте и написать хотя бы один пост (ты уже написал только что)
Теперь зарегистрируйся и вместо скрытого текста увидишь ссылку на скачивание в посте №4.
Это не наша прихоть. На том сайте запрещено давать открытые ссылки на других форумах. Только поэтому ссылка скрыта (hide).
