Кто может подсказать в чем ошибка. имеются два реса IPBox99 и Дрим800 подключены в сеть. Если кабель одного отключить от роутера, второй шарит нормально, если только оба в сети включены даже на открытых каналах выдает такую хрень
28.10.2010 21:38:20 UserLevel Notice [newcamd] Connecting to
28.10.2010 21:38:20 UserLevel Notice [newcamd] Login to accepted (63ms)
28.10.2010 21:38:20 UserLevel Notice [newcamd] Login to accepted (64ms)
28.10.2010 21:38:20 UserLevel Notice [newcamd] Login to accepted (65ms)
28.10.2010 21:38:20 UserLevel Notice [newcamd] Login to accepted (66ms)
28.10.2010 21:38:20 UserLevel Notice [newcamd] Login to accepted (67ms)
28.10.2010 21:38:20 UserLevel Notice [newcamd] Card data from (125ms):
28.10.2010 21:38:20 UserLevel Notice Userid 91 caid 654 providers 6
28.10.2010 21:38:20 UserLevel Notice Idents: 000000 000001 000002 000003 000077 000078
28.10.2010 21:38:20 UserLevel Notice [newcamd] Card data from (128ms):
28.10.2010 21:38:20 UserLevel Notice Userid 91 caid 1830 providers 1
28.10.2010 21:38:20 UserLevel Notice [newcamd] Card data from (126ms):
28.10.2010 21:38:20 UserLevel Notice Userid 91 caid 1702 providers 1
28.10.2010 21:38:20 UserLevel Notice Userid 91 caid 100 providers 3
28.10.2010 21:38:20 UserLevel Notice Idents: 000065 000068 003311
28.10.2010 21:38:20 UserLevel Notice [newcamd] Card data from (140ms):
28.10.2010 21:38:20 UserLevel Notice Userid 91 caid BAA providers 1
28.10.2010 21:38:20 UserLevel Notice [newcamd] Card data from (143ms):
28.10.2010 21:38:20 UserLevel Notice Userid 91 caid 500 providers 15
28.10.2010 21:38:20 UserLevel Notice Idents: 020810 023100 023700 023D00 024700 024B00 030700 030B00 031B00 032000 032500 041700 042200 042400 042700
28.10.2010 21:38:20 UserLevel Notice [newcamd] Card data from (145ms):
28.10.2010 21:38:20 UserLevel Notice Userid 91 caid D02 providers 4
28.10.2010 21:38:20 UserLevel Notice Idents: 000000 0000A0 0000A4 0000A8
28.10.2010 21:38:20 UserLevel Notice [newcamd] Card data from (147ms):
28.10.2010 21:38:20 UserLevel Notice Userid 91 caid 90F providers 1
28.10.2010 21:38:20 UserLevel Notice [newcamd] Card data from (149ms):
28.10.2010 21:38:20 UserLevel Notice Userid 91 caid 93E providers 1
28.10.2010 21:38:20 UserLevel Notice [newcamd] Card data from (153ms):
28.10.2010 21:38:20 UserLevel Notice Userid 91 caid 4AE1 providers 1
28.10.2010 21:38:20 UserLevel Notice [newcamd] Card data from (155ms):
nikomar
Сейчас если ставить релиз от АБикома и установить addons-clientserver_0.7 то к загрузке будет мжкам 1.35а - так вот если в мжкам конфиге оставить параметр В - 11 то ключи идут а на экране малевич, если ставить параметр В - 06 то все гуд.
Nikolayevih
А не надо было mg_cfg, на свой менять. С аддона загружается с правильным параметром B: { 06 }.
volk2003
подскажите пожалуйста как сделать чтоб мжкамд стартовал после полного выключения.
С новой версией (14.04.11 или 20.04.11). Аддон-клиент сервервер 07, стартует мжкамд после рестарта энигмы с пульта, после полного рестарта с пульта, но если выключить электричество, после полной загрузки картинка не появляется. Надо жать синюю, красную, зелёную.
Alexxxej
Попробуй в /etc/init.d в файле allinonesw заменить на это
PHP:
#!/bin/sh
# start/stop client switch
export PATH=/usr/local/bin:/usr/local/sbin:$PATH
case "$1" in
start)
if [ -x /usr/local/bin/allinonesw ]; then
start-stop-daemon -S -x /usr/local/bin/allinonesw > /dev/null
fi
if [ -x /usr/local/bin/srvsw ]; then
fi
if [ -x /usr/local/bin/clsw ]; then
/usr/local/bin/clsw
fi
echo "allinonesw is started"
    stop)
	    start-stop-daemon -K -x /usr/local/bin/allinonesw > /dev/null
	fi
	echo "allinonesw is stoped"
    restart)
	killall -HUP
	echo "allinonesw is restarted"
	echo "Usage: allinonesw {start|stop|restart}"
	exit 1
esac
exit 0
hus07
При включении mgcamd стартует нормально, но при переключение на следующий канал, с другой частоты нужно перезапускать вручную, далее все работает. И еще каналы в ирдето не открываются. Как можно исправить? Прошивка апрельская, mgcamd 1.35a path
butrik
Помогите настроить шаринг в AB IPBox 55HD
Доброго всем.
Более 3х недель пытаюсь запустить шаринг на этом тюнере. Прочитав сотни страниц с разных форумов, получил некотрое представление о запуске шаринга в тюнерах на линуксе, но пока безрезультатно.
После покупки тюнера обновил прошивку на последнюю с оф. сайта абкома от 16.02.2012, потом установил через флэшку клиент-сервер менеджер. Через появившийся в списке плагинов скачал и установил mgcamd 1.35 и пропатчил его патчем из того же списка. Перезагрузил тюнер. Через тотал ком. изменил аттрибуты файлов на 755. В mg_cfg выставил знач. параметра В на 11, и выставил знач. L на 01, вписав свой адресс для снятия лога программой Tray Syslog. После перезагрузки запускаю mgcamd, нажав синюю, крассную и желтую(это меню клиет-сервер менеджер). В нем, в строчке сервер стоит SSFCAMD, ставлю на выкл(потому что не знаю что это такое, правда и когда его запускаю, тот же отрицательный эффект). Кодированные в BISS каналы работают до того момента, как я стаю на канал с шарой, которая, конечно, не работает. Чтоб кодир. канал опять заработал, я должен опять перезапустить MGCAMD. Через телнет и команду TOP вижу, что MGCAMD не всегда работает(????). Информация из лога прописывается в течении 1 секунды после запуска MGCAMD и больше в лог ничего не идет.
Прошу всех знающих и шарящих помочь. Что неправильно делаю в процедуре настройки?
Спасибо.
yupiter
Нехватает файлов
Не могу настроить,нехватает файлов newcamd list,pritity,ignore для var/keys.невылажете,спасибо
папараци
это имя знают все ...
yupiter, Да уже 100 раз везде выкладывали.На каких операторов надо?Экстру Мжкамд не поддерживает.
ARGAZM
Помогите победить Малевичь
Друзья помогите разобраться с проблемой. Суть такая - Тюнер AB IPbox99 HD
Стояла оригинальная прошивка 99HD - Flash 20120116
клиент сервер enigma2-plugin-addons-clientserver_0.7_sh4.ipk
эмулятор Mgcamd 1.35a
НТВ+
Решил обновить прошивку и обновился на оригинальный образ
99HD - Flash 20120425
Делал все как всегда но ... Малевич ((
перепробовал
enigma2-plugin-addons-clientserver_0.9_sh4.ipk
enigma2-plugin-addons-clientserver_1.0_sh4.ipk
На 1.0 при старте эмулятора вылетает в зелень
игрался с настройками mg_cfg, но всеравно черный экран (
Откатываться на прошлую прошивку не хочется, хочу разобраться с последней, сторонние прошивки ставить тоже не хочу тк не использую доп. функции а просто смотрю НТВ+
Помогите пожалуйста. И буду признателен за рабочую конфигурацию mg_cfg под 99HD
ARGAZM
Это как ?? Подробнее.
Выложите лог эмулятора, на каналах НТВ++. Каналы в БИСС открываются?
Прошился, установил клиет-сервер, перезагрузился, зашел в плагины , поставил эмулятор, закинул настройки в keys, старт эмулятора.
Только что откатился на предыдущую прошивку и заработало все с первой попытки.
Попробую предположить, что в файле mg_cfg параметр В изменить на 11 или 00 или 13.
При запуске эмулятора ключи идут?
4x6hp
у меня такая же ерунда. ключи идут а на экране малевич... версия 20120116. радуга.
когда поставил 00 в параметре В. то все заработало.[/HIDE]
