спецификация тюнеров
Quotation sheet of Set Top box 10 JUNE 2008
Model No. STS-2628
UNIT PRICE: 1000 - 2000 PCS US$25.00 FOB SHENZHEN
5000 - 10,000 PCS US$22.50 FOB SHENZHEN
10,000 ++ US$21.50 FOB SHENZHEN
Specifications:
1. Description:
Incorporating the highly integrated GuoXin single chip GX6102, The Set-Top Box is a cost-effective and high performance digital satellite receiver. It provides FTA (Free-To-Air) channels with user-friendly OSD (On Screen Display) and stores up to 5000 channels with fast inter-channel switching capability, which undoubtedly makes it an ideal choice for viewers like you to enjoy the digital life. High performance digital audio is also available through S/PDIF.
2. Features
☆ EPG(Electronic Program Guide)
☆ Full compliant of MPEG-1/MPEG-2 Digital&DVB broadcasting
☆ Variable input symbol rate(1-45Msps)
☆ Multi language OSD
☆ All of the PAL and NTSC analog TV standards supported
☆ Fast channel change
☆ 5000 channels TV&radio program
☆ S/PDIF for digital audio
☆ Timer function (Automatic turn on/off by setting function)
☆ 256 colors(Graphic use interface) number
☆ True-color OSD and 2D graphics accelerator may supply flowery menu effect
☆ PIG(picture in graphic)
☆ 8 favorite list&unlimited programs
☆ Powerful channel editing function
☆ Sorting:alphabetic,FTA/scramale,parental lock
☆ Move,delete,favorite edit
☆ Parental lock,channel rename,channel skip
☆ Auto scan/manual scan
☆ The flexible capture engine, various multi-picture browser and screen-capture functions supported
☆ Supports error protection and concealment
☆ Upgrading through RS-232C
☆ Bulid scan
3. Tuner/LNB
Input connector IEC Female(RF IN)
IEC Male (RF out)
If Input frequency 950 ~ 2150MHz
Input level -65dBm ~ -25dBm
Demodulation QPSK
Symbol rate 1-45Msps reed solomon decoding
Constellation FEC:204,188.
DiSEqC DiSEqC 1.0/1.1/1.2 and USALS
4. MPEG transport stream &A/V decoding
Transport stream MPEG-2 video (ISO/IEC 13818-2)
MPEG-1 video (ISO/IEC 11172-2)
Profile level MPEG-2 MP@ML
Video date rate 15Mbps
Aspect ratio 4:3,16:9
Video resolution PAL NTSC
Audio decoding MPEG layer I and II
Audio mode Single/Dual Channel, Stereo,Joint Stereo
Sampling frequency 16/22.05/24/32/44.01/48KHz
Automatic concealment of errors Supported
Channel quality estimation Supported
5. Video Out
Encoding of Teletext, close caption, WSS, CGMS and VPS Supported
Output Format PAL-B B1 D D1 G H I K K1、PAL-M、PAL-N、PAL-Nc、NTSC-M、NTSC-4.43
6. Microprocessor&Memories
Main processor GX6102 32bit RISC CPU
Cache 2Kbyte data cache
2Kbyte instruction cache
2Kbyte SRAM
CPU clock 216 MHz
Flash memory 8M-16 Mbyte
SDRAM 64 Mbyte
EEPROM 32 kbit or NO
7. Data port
Connector 9 pin D-sub type
Protocol RS232 Asynchronous
Data rate Max.115,2kbps
8. RF moduloator
RF connector 75,IEC 169-2, Male/Female
Frequency 471 ~ 885MHz
Output Level 82dBuV versus 74.5dBuV
Output channel CH 21-69 or ch 14-83
TV standard PAL-B/G,D/K,I,M NTSC Selectable
9. Front panel
4 Digits LED display channel number display
6 Keys power, channel up/down volume up/down menu
10. Real panel
TV scart RGB,CVBS,audio L/R
VCR scart RGB,CVBS,audio L/R
RCA A/V video,audio,L,audio R
S/PDIF optical output
Rs232 serial port 9 pin D-sub type
11. Remote control
Type Infra-red (carrier freq,38KHz)
Battery 2*1.5V AAA type
12. Physical Specification
Input voltage AC90-250V,50/60Hz
Power consumption Max.15 Watts
Standby power less than 8 Watts
Dimension 270*180*50mm 1.7KG
Operating temperature 0 ~ 45 ℃
Storage temperature -20 ~ 60 ℃
12. Packing
Dimension of unit 255*43*170 mm
Dimension of Carton box (10 pcs/ctn) 565*280*300 mm
Loading Qty 5000pcs/20'container
MODEL STS-2628, 2888 10 PCS/CTN (56.5X28X30CM), 5000 PCS/20' CONTAINER
MODEL STS-7288 10 PCS/CTN (60.5X32.2X38CM), 5000 PCS/20' CONTAINER
MODEL: STS-2628 MODEL: STS-2888
MODEL: STS-7288
