Тогда отредактируй свой файл mg_cfg !yea!.
Вот как у меня :
# EMM messages
#    00 don't show any EMMs (default)
#    01 show only valid EMMs
#    02 show valid and bad EMMs with complete data display
M: { 01 }
# ECM messages
#    00 don't show anything about ecm
#    01 normal mode, show pids processed, decoded ecm and cw
#    02 verbose mode, show valid and bad ECMs with data
C: { 01 }
# AU
#    00 disable, no emm pids processed
#    01 enable, emm pids always processed for soft-au and shared cards
#    02 auto, emm started only if channel cant be decoded
#    03 process emm pids for network cards update only
A: { 01 }
# key update (sum 01 or 02 with 04)
#    01 update only new keys, default setting
#    02 update all keys (used for valid PMK checking)
#    04 enable TPS au
#    + tps SID, which pmt pid contains au pid
U: { 02 } 0x12c0
# config files folder (softcam, autoroll, ignore/priority)
#    00 files in /var/keys
#    01 files in /tmp
T: { 00 }
# network mode, use summ for several clients
#    00 no network (default)
#    01 newcamd netclient
#    02 radegast netclient
#    04 camd3 netclient
#    08 gbox netclient
#    32    cccamd netclient, card list saved as /tmp/cccamd.info
#        (ECM only, supported server version up to 2.1.1, later not work)
G: { 01 }
# network retry, use summ for several options
#    00 disable
#    01 retry every new ecm
#    02 try to connect to offline shares every Q: seconds
#    04 try to detect and fast reconnect to lost (and not used atm) server
#    + XX messages number and YY seconds to reconnect
#    mg will reconnect to server, if no answer to last XX ecm/keepalive or
#    if no answer for last ecm or keepalive sent for YY seconds
#    set to 0 to disable
N: { 07 } 5 30
# network ecm timeout in seconds
K: { 03 }
# newcamd dead routes connect retry, sec
Q: { 150 }
# network shares priority
# 00 gbox, newcamd, cccamd, radegast, camd3 (default)
# 01 camd3, radegast, cccamd, gbox, newcamd
# 02 cccamd, newcamd, camd3, gbox, radegast
P: { 02 }
# on screen display type
#    00 No OSD (default)
#    01 neutrino
#    02 enigma
#    03 relook
#    + user password for http auth
O: { 01 } root newcs
# on screen display Options, summ of:
#    01 show emu ecm
#    02 show network shares messages
#    04 show decoding failed / fta
#    08 show emm keys update
#    + web port to use for osd
S: { 03 } 8080
# Log option, summ of:
#    00 off
#    01 network udp log
#    02 log to console
#    04 file, appended ! delete it by yourself, before it eat all your hdd
#    + IP udp-port log-file-name
L: { 01 } 192.168.2.101 514 /tmp/mgcamd.log
# keep ecm cache, seconds
# every cache entry takes 28 bytes, so 24h cache will take *only* 240-400kb of memory,
# for openbox/elanvision users with remote shares make sense to set it higher than default value,
# to not hammer cards while timeshifting or playing crypted recordings.
E: { 15 }
# cache option, summ of:
#    00 Off (default)
#    01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
#    02 Ecm data cache, remember CW for (E:) time
#    04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
H: { 07 }
# reread files, summ of:
#    00 No (default)
#    01 reread config file on channel change (including priority and ignore, but not replace/cache)
#    02 reread SoftCam.Key on channel change
#    04 reread SoftCam.Key if file changed
R: { 00 }
# debug, summ of
# 00 off (default)
# 01 debug ecm
# 02 debug emm
# 04 debug network ecm
# 08 debug network emm
# 16 debug network login
# 32 show mem/cpu stats every 1 min
# 64 add timestamp to log messages
D: { 00 }
# box type
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
# 06 dreambox/mips
# 08 stapi/kathrein
# 09 stapi/ipbox
# 11 stapi/openbox
B: { 12 }
# map all 180x nagra caids to 1801
# default is 01
F: { 00 }
nika4355
хорошо спасибо попробую. извините не скажите ,а какие у вас в паке keys файлы может там что подправить тоже
Ekvandor
nika4355! Думаю причина затыков не в MGKAMD.Но, все равно Вот моя папка Var
У меня там много чего но для тебя главное в папке var/keys файлу mg_cfg права 755 поставить. В папке var/bin файлы mgcamd и autorun.sh права 755. В папке var/etc файл start.sh права 755. :) Пробуй, может поможет.
sever7799
Вот mgcamd в виде плагина. Закидываешь папку Plugin на USB и в ресивер. Кнопочками вправо влево найдешь папку и нажмешь красную кнопку:). Ресивер установит его и перегрузиться, все готово!good!. Останется только подредактировать ключики и файл newcamd.list для шарика.
  • Plugin_Mgcamd_Octagon_SF1008_SF1018_HD_21052010.rar
    410 KB · Просмотры: 226
Neuwied
всем привет чтото мне чегото нехватает чтобы запустить mgcamd.
stawr62
Пожалуйста выложите рабочую папку VAR со всеми листами и атрибутами.
Интерес имею к НТВ+(HD, рус. и укр.), Радуга ТВ.
"В доску" замучился настраивать Шуру. И подскажите как рестартануть mgcamd?
Octagon SF1008 HD se
36 градус не смотрю в силу географического расположения:pardon:. Поэтому помочь не могу. Листы приорити, реплейс и игнорити можешь взять у своего шародателя.
Сейчас это уже не актуально. Эмулятор mgcamd есть в виде плагина. Устанавливается как все плагины. Папку plugin на флешку, флешку в ресивер, стрелками вправо влево находим папку жмем красную кнопку - готово!Заходим в меню плагины и жмем зеленую кнопку для старта и ставим плагин на автостарт красной кнопкой!good!. Вот новый адрес форума
nvidia
spartak73, Подскажи как установить эмулятор MgCam последний и где его скачать пока не имею связи с тюнером по сети можо ли как нить поставить эмулятор через флешку подскажи как хочу поставить мжкам и сскам в паре спасибо!
Вот http://forum.sat-expert.com/318968-post388.html тут качни . Установить можешь без FTP просто на флешку папку plugin и в ресивер. Почитай тут уже сто раз все разжевали:). Но без компа все равно не получиться надо еще ключи туда в папку var/keys или файлы для шары.
madu
ВСем привет народ .
Опишу мои мучения .Вроде установил всен по инструкции
последней и файл взял оттуда http://forum.sat-expert.com/faq-manuals-docs/16199-instruktsiia-dlia-nachinaushih-polzovatelei.html
зашел в плагины там появилось два newcs и mgcamd запустил mgcamd но каналы не открываются в папке keys кроме newcamd.list prioriti.list ignor.list mg_cfg
которые правил сам через акелла пад еще много каких то файлов
смотреть собиаюсь только шару 19 13 9 5
где собака порылась ? объясните чайнику
рессивер octagon sf1008 se+
nosenko
Возможно Вы не установили права доступа 755 на Start ch, mg cfg, mgcamd при помощи файлзилла. И проверьте ньюкамд лист. И в наконец как дела с шародателем.
madu
посмотрел в тотале в папке keys ко всем файлам стоит атрибут755
лист проверил вроде правильно .насчет шародателя подсоеденяя свой 918
все пакеты идутна ура .где то я что то не так делаю
Проверь правильность написания данных в newcamd.list а также открой файл mg_cfg и посмотри значение G: { 01 } а также вот это значение B: { 12 }
