SWF-Vizyon-8x0/0-E2_V5.0.2_flash und USB
Basis TDT Tideglo V0.9.8
Das SWF prдsentiert euch fьr die Viyzon-Boxen 800, 810, 820 und 8000
unser neues Enigma2-Image.
Sprachen : de,en,fr,it,nl,pl ru
Diese Image's laufen auch auf den IPBoxen!
Also viel SpaЯ mit dem neuen Enigma 2
Tideglo Changes:
release 0.9.8
- fixed Scart/NTSC, HDMI/480i60, HDMI/480p60 resolutions (let me know if they are working ok or not,
here i can't test perfectly NTSC standard, but seems working good)
- fixed grey screen of death
- fixed some compatibility of HDMI video output
- fixed the switching between certain 1080p modes unreliable
- fixed YCbCr to full range RGB conversion
- sometimes happened that screen can get hidden when switching between modes that do not change the resolution
- some rescale improvements
- fixed some downscale bugs
- fixed some artifacts cases when stopping playback (need to test more about it)
- first try for audio clock initial setup for HDMI compatibility (people who are using Samsung's TVs and
have had problems with audio throught HDMI should let me know if there are improvements)
- fixed the bug where non-linear video zoom fail all over on (now it works good let me know how do you feel it)
- fixed a wmv bug
- fixed an alignment problem on DVD-player
- updated cross epg changes (now you should be able to use latest cross-epg version)
- minor bug fixes
SWF MOD :
Tideglo Changes:
release 0.9.8
- fixed a wmv bug
- minor bug fixes
SWF MOD :
SWF-Panel
- eigenes SWF-Panel
- 2x Info gs-fix
- SWF-Emustarter
- Volume-Adjust (Lautstдrkeanpassung einzelner Kanдle)
- neue Tastenfunktionen: Lange "Exit" --> Morpheus-Panel, lange "Info" --> Emustarter , lange "Photo" --> Snapshot
- Autoresolution
- Netzerkbrowser (nfs + cifs)
- multiboot integriert
Taste1=flash
Taste2=SDA1-USB
Taste3=SDA2-USB
Taste4=SDA3-IDE
Taste5=SDA4-IDE
Taste6=SDB1-USB
Taste7=SDB2-USB
Taste8=SDB3-USB
Taste9=SDB4-USB
Taste9=NFS
- Backup-Funktion fьr das Flashimage (Settings, Emus, Keys und sonstige persцnliche Sachen werden gesichert) Vorraussetzung einen USB-Stick (SWF) oder eine angeschlossene HDD / Skins, Fonts, Emu , Keys, Plugins usw. werden vom Stick geladen (sofern vorhanden)
- Standard-Skin, Concinnity910-HD
emustarter
Volumeadjust
Netzwerkbrowser
Danke alle Tester
-User = root
-Passw.= vizyon
SWF-Stick
USB-Stick in ext2 oder fat formatieren mit dem Namen "SWF" , bei Neustart wird er automatisch gemountet, egal welche Partition er ist. Die benцtigten Ordner werden automatisch erstellt . Picons, Fonts, Emus, Keys, Plugins kцnnen dann auf dem Stick ausgelagert werden.
Dann kann man im SWF-Panel ein Backup erstellen lassen auf den SWF-Stick oder /HDD, dass entweder per Panel jederzeit wieder zurьckgespielt werden kann oder bei Neuflash automatisch.
[/HIDE]
- eigenes SWF-Panel
- 2x Info gs-fix
- SWF-Emustarter
- Autoresolution
Taste1=flash
Taste2=SDA1-USB
Taste3=SDA2-USB
Taste4=SDA3-IDE
Taste5=SDA4-IDE
Taste6=SDB1-USB
Taste7=SDB2-USB
Taste8=SDB3-USB
Taste9=SDB4-USB
Taste9=NFS
emustarter
Volumeadjust
Netzwerkbrowser
Danke alle Tester
-User = root
-Passw.= vizyon
SWF-Stick
