The Gemini2 Project 5.1 DM800HD
Gemini2 v5.1
Enigma from 21.07.2010
An overview over most functions can be found here
Gemini-Wiki
Function Buttons:
* BLUE - Blue Panel (BP)
* BLUE long - Picture in Picture (DM7025, DM8000)
* 2x BLUE - BP -> Gemini Extras
* BLUE RED - File-Manager
* RED - Recording (not for DM8000)
* GREEN - Quickbutton / Subservices
* YELLOW - Timeshift (not for DM8000)
Extras:
* Addon and Plugin Server
* Cryptinfos of the channel or Cam, Stick Cam to certain channels
* Function for managing many daemons / server (BP -> Services/Daemons)
* optical enhancements like HD-skin, additional icons or modification of the channel list
* Manager for format, setup or mount devices (BP -> Device-manager)
* Additional EPG-functionality like Autosave, Refresh or different EPG-format view
* Particular addons like Dreamnetcast, Jukebox, Calendar, eMail or eTorrent, just to name some of them
* Quickbutton, to define functionality of the Green button via menun
* Detailled information about your Dreambox (Menu -> Information)
* File-Manager, which can handle different format-types, regardless whether it is a picture-, audio-, videoformat, playlists, torrent, scripts or DVD-files (BP -> File-Manager)
* complete handling of hard disks, DVD-drives, USB-Sticks changed to udev (system handels those devices by itself)
Information about many other functions can be found at the IhaD-Board or our Wiki.
New:
* HFS- and HFSPlus filesystems included
* Info about new release. Atcivate over BP->Settings->General. Then will blink a "R" in the Infobar, if something new is out. The Check will be done between 00:00 and 01:00.
* Partitions can be named anytime now.
* The Filemanager can start everytime with the same selectable folder now.
* OpenVPN now supported, in our wiki is already described, how to use the dream as server.
* Webinterface for ctorrent
Fixes + Updates:
* better support for Unicable
* Countries/Cities lists extended in the Weatherplugin
* update to ctorrent 3.3.2, addon revised
* see CVS
Important:
For the Skiners:
A Change in the network-overview and in Skin_Config2Button (have a look at BKskin.py)
This image doesn't contain any keys or softcams!
Backups or other modified images are not released by us
and won't be supported in any way!!!
Download via Database
Thank you and have fun
Your Gemini-Team
http://hotfile.com/dl/56957258/2aa5448/gemini2-510-dm800-20100721145005.nfi.zip.html
Spider1973
Созрел вопрос какого барри поставить на этот имидж с новым ядром на китайчёнка с 76 загр???
xech1960
здраствуйте;;;у меня дрим800 The Gemini2 Project 4.7...менял на The Gemini2 Project 5.1 DM800HD ....видыть транс. но не показивают хд конали нтв++ ....но другой сервер показивать хд..проблемо имидж или другой,,,,спосибо
sisoft
Добрый день. Поделитесь ссылкой на gemini 5.1 для 800HD c sim1.0
Заранее благодарен.
seal
Администраторы
sisoft,
на всякий случай предупреждаю, имедж для оригинального ресивера.
Gemini2 v5.1
Gemini-Wiki
Function Buttons:
Extras:
New:
Fixes + Updates:
* see CVS
Important:
For the Skiners:
Your Gemini-Team
http://www.i-have-a-dreambox.com
Ссылка на прошивку
