Basics:
Enigma2 4.0: 05.01.2015
Enigma2 Plugins: 06.01.2015
Newnigma2 Plugins: 06.01.2015
DM 800 HD PVR
driver: 28.12.2013
secondstage: 84
kernel: 2.6.18
changelog E2 05.01.2015:
auto-fallback for some shoutcast mp3 webradio servers which are unhappy with HBBTV_USER_AGENT string
(fixes GStreamer plugin text/html decoder not avaliable!)
ignore SDT caids when the service already have caids assigned (fixes a CI support bug)
only add 0x0000 caid as "scrambled by sdt indicator" when no other caid exists on this transponder
fixed another possible deadlock on skip forward/backward on mediafiles
fixed crash on change servicelist style after use another ServiceList instance...
fixed blindscan constellation display
Notice: Update from v4.0.x to 4.0.12 only possible by updating via console.
Changes:
Added: Skin Evolution-HD by Kerni (thx)
Added: newnigma2.Kerni.PanTV-HD by Kerni (thx)
Added: Kerni.Gnome-HD by Kerni (thx)
Added: VideoDB V2.2 by Dr.Best (click here for more information) (thx)
Added: mediaportal
Added: swapmanager
Added: wget
Added: stat
Added: weathercomponent (needed for some skins)
Added: eventposition (needed for some skins)
Added: reftopiconname (needed for some skins)
Added: ledmanager (be carefully changed source="ButtonGreentext" to source="key_green") screen for skinner
Added: Black-Box.HD.ME (32bit skin)
Added: cryptsetup more information
Added: newnigma2-servicerestart: restart services via gui, like init.d, if telnet is not reachable screen for skinner
Added: free space check's before installing or upgrade packages
Added: min free flash space is 3mb for installing/upgrading some packages
Added: improve network connectivity check in newnigma2 installer
Added: new skin option: progress_pointer (since E2 14.02.2014 possible) screen for skinner
Added: readded extendedinfobar
Bugfix: Rebuild Picon handling/loading/caching (less memory consumption)
Bugfix: Newnigma2 Services fix getPNG cache failure (memoryleak)
Bugfix: Improved onlineinstaller cache handling (sometimes strange screen output)
Bugfix: neutrino keymap
Bugfix: newnigma2.Kerni.PanTV-HD icons
Bugfix: Caid Renderer didn't close ecm.info and share.info properly
Bugfix: for loading wrong or no newnigma2 service menu png's
Bugfix: loosing picon value in servicelist after using configsaver
Bugfix: for not shown all skins in nenwigma2 installer skin section, like tikila skins
Bugfix: prevent of loading skin_infobar_wetter.xml on other skins then "newnigma2-" skins
Bugfix: broken gui installer
Update: Some improvements on our onlineinstaller
Update: znc to version 1.4
Update: openvpn to version 2.3.4
Update: german translation
Update: picon renderer. create piconSList dir for servicelist picons.
Update: IPTV-List-Updater
Update: cryptsetup
Update: openssl
Removed: we have removed non working plugins. most of them are integrated in mediaportal.
Removed: keymanger plugin from image. It's still available from our feed.
Multiboot: No support for multiboot. Not planned. No need for such a tool.
GP3wizard: No support for gp3wizard. Probably not running. Not needed in Newnigma2 environment.
