shuricel
DreamBoxEdit-IHAD Edition 4.0.1.2
Changelog:
4.0.1.2
- fixed userbouquets with renamed services are now written in proper settings-type 4 format
- fixed problem when saving cable or terrestrial settings (some parameters were lost)
- language files updated
4.0.1.1
- fixed alternatives filename generation
- fixed error message after opening Enigma1 settings
- fixed total service counter was overlapped by displayed service counter after startup without settings
4.0.1.0
- fixed sorting services in bouquet panel was broken after adding channel numbers to the bouquet panel
- fixed error when sorting bouquets with cable and terrestrial services
- fixed some other functions were also broken after adding channel numbers to the bouquet panel
- fixed hour glass didn't get away after loading new settings
- fixed error message when using picon cleanup function and filename wasn't using proper picon reference format
- fixed alternatives are no longer considered as duplicates of fixed services in the same user bouquet
- fixed alternatives handling, now you can use the same service with and without alternatives in one user bouquet
- fixed blacklist entry for radio user bouquets
- fixed all files are now written in proper settings-type 4 format
- fixed auto insert markers for cable and terrestrial services
- added Enigma2 restart button to ftp window, use this button to activate any changes related to lamedb and/or black-/whitelist
use the autoreload or "reload settings on dreambox" button if you only change your userbouquets
- added sorting of profiles in options panel
- changed satellites in filter combobox are now sorted by position from west to east
- changed profile default paths to enigma2 defaults
- window state is now saved on application close, and restored when application is started
- some minor fixes
  • DreamBoxEdit_without_setup_4.0.1.2.zip
    2,6 MB · Просмотры: 69
DreamBoxEdit-IHAD Edition 4.1.0.1
Обновился редактор каналов для энигмы2
Changelog:
  • 4.1.0.1 - fixed problem with profile selection in options panel
  • - fixed missing parameters for cable settings after Enigma1->Enimga2 conversion
  • 4.1.0.0 - added crypto icon in main service list if service is encrypted (Note: this is only working properly on future Enigma2 Images)
  • - added filter for encrypted and unencrypted services (Note: this is only working properly on future Enigma2 Images)
  • - added copy service reference to clipboard option to context menu of main service list and bouquet panel
  • - added a info window with some informations about the new filtering behaviour
  • - fixed error message when using picon cleanup function and filename wasn't using proper picon reference format
  • - fixed error message when using add new service option in context menu - fixed application hanging when parsing lamedb with corrupted transponder entry
  • - fixed problems after adding new services, the services weren't covered by the filters
  • - some minor fixes
  • - language files updated
  • DreamBoxEdit_without_setup_4.1.0.1.zip
    2,6 MB · Просмотры: 93
aheles
подскажите что нибудь слышно
AAF Recovery Tool с новым загрузчиком а то что то страшно ставить новое родное ПО
А что страшного то? Если что можно назад вернуться. И потом, автор Solala куда то пропал. Никто не знает когда он появиться. Это по поводу ART 2.0. Для 1008 по моему ничего нового там нет.
aheles
страшно то што после загрузки последнего по может ли слететь загрузчик и ресивер будет мертвый ,а где почитать
дайте сылку
ART2.0 не для твоего ресивера для 1028. Загрузчик слететь не сможет. Он там будет просто может энигма не грузится. Так как он поверху запишет. Не умрет не бойся всегда можно восстановить все если под рукой есть все необходимое :).
TGZ-USB-Installer V0.06 L6.x0 SF-1008SE+ и SF-1028P
Version 0.6
- адаптирован к API 1.10
==> это глупо но софт не имеет обратной совместимости с API
==> Графические ошибки в API 1.10 присутствуют
==> для 1008se+ и 1028P
Установка энигмы с помощью плагина без жесткого диска!
1. Шаг S1 пропускаем.
2. Делаем шаг S2: отмонтируем USB флешку из переднего порта.
3. Шаг S3: форматируем и создаем разделы.
4. Вытаскиваем флешку и закрываем плагин.
5. Теперь идем к компьютеру, вставляем флешку и ложим файл "*.tar.gz" в новый FAT-раздел на вашей флешке.
6. Запускаем плагин снова, теперь дальше шаг S4 (УстановкаTGZ из USB-P1-VFAT)
7. Ну и в завершении всего шаг S5: запись bootargs.
Запланирован TGZ-USB-Installer который бы устанавливал бы не зависимо от модели нужные BootArgs. Без понятия когда я это сделаю.
P.S. от меня :) : я только процитировал автора плагина.
  • TGZ-USB-Installer_V0.06_LD620.rar
    88,9 KB · Просмотры: 266
  • TGZ-USB-Installer_V0.06_LD600.rar
    89 KB · Просмотры: 69
SatChannelListEditor
SatChannelListEditor by Elemental v4.2
Еще один редактор каналов энигмы2.
Version 4.2
Новое:
  • Поддержка tiTan
  • Конвертация списка каналов Enigma2 в формат tiTan
  • Koнвертация списка каналов tiTan в формат Enigma2
  • При нажатии клавиши 'пробел' показывается контекстное меню
Примечание:
  • В Windows должен быть установлен Microsoft .NET Framework 2.0 или выше
  • В Linux должен быть установлен Mono Framework (протестировано с Mono 2.0.1 , возможно нужно будет установить дополнительно WinForms libraries с "sudo apt-get install libmono-winforms*")
  • SatChannelListEditor_V4.2_Installer.zip
    401,7 KB · Просмотры: 61
  • SatChannelListEditor_V4.2_FilesOnly.zip
    262,9 KB · Просмотры: 41
TGZ-USB-Installer V0.07 L6.x0 SF-1008SE+ и SF-1028P
Version: 0.07
- работает на 1028P (ST7105) и 1008SE+ (ST7111)
- для LD6.00 и LD6.20, пишет только "нужные" BootArgs
==> Старый Loader не был протестирован!
- USB-флешка в переднем USB порту не должна содержать других файлов, иначе не произойдет образования разделов
==> на флешке могут находиться только следующие файлы "*.tar.gz", "hdd", "uImage" и "InstalledTgz.info"
- Все диалоги должны остаться (надеюсь зелеными) нужно только нажимать OK
  • TGZ-USB-Installer_V0.07.rar
    90,2 KB · Просмотры: 154
DreamboxEDIT 5.0.0.0
Changelog:
5.0.0.0 - Добавлена полностью новая оболочка GUI с подержкой скинов - Добавлена ​​прозрачность крипто иконки в главном списке сервисов
- Добавлена ​​прозрачность для подставных пиконов в панели букетов
- Добавлен настраиваемый цвет маркера для выбранных сервисов
- Добавлено правильное обращение для переименования альтернативы
- Добавлено предупреждающее сообщение, если multibouquet отключена на вашем Dreambox
- Добавил индикатор мощности сигнала
- Исправлено изменение нумерации каналов с номерами после использования "сортировать по алфавиту" из контекстного меню
- Исправлена ​​сортировка по частоте теперь также сортировка по поляризации применяется
- Исправлена ​​проблема с отсутствием объектов (службы счетчика, выбора профиля)
- Исправлено копирование и вставка сервисов с альтернативой
- Исправлено сохранение текущего профиля, когда панель опций закрыта
- Интегрированный инструмент языка (Help -> Language Tool)
- Удалены LanguageTool.exe из установки пакета
- Удалены устаревшие файлы справки
- Языковые файлы обновлены
- Некоторые мелкие исправления ---------------------------------------------------------------------------------------------------------------------- Следующие возможности поддерживаются только оригинальными Dreambox с Enigma2-имиджем на основе версии 3.2 или выше ---------------------------------------------------------------------------------------------------------------------- - Полная поддержка фильтрации кодированых сервисов теперь включена
- Полная поддержка потокового сервиса в букетах пользователя
- Добавлена ​​поддержка потокового видео
Примечание: VLC 1.1.11 или выше, каталог установки определяется автоматически, если вы используете
портативную версия набора каталогов VLC установки в панели опций.
- Добавлена ​​поддержка для снимков проигрываемого в данный момент потока
Update
5.0.0.1
- исправлена проблема запуска dreamboxEDIT в wine Замечание: поддержка скинов автоматически отключена, Wine 1.3.34 или выше обязателен
- некоторые файлы языков обновлены
  • dreamboxEDIT_without_setup_5.0.0.0.zip
    3,3 MB · Просмотры: 59
  • dreamboxEDIT_without_setup_5.0.0.1.zip
    3,3 MB · Просмотры: 158
TGZ-USB-Installer V0.08 L6.x0 SF-1008SE+ и SF-1028P
Version: 0.08
- BootArgs для ST7111 поправлены ==> PKT Haarp должен теперь с загрузчиком LD6.20 на 1008se+ грузится
- Функция обновить "sg_start --load" для некоторых "странных" USB-флешек после извлечения встроена
- Вверху сообщение теперь синим цветом :)
- Диалоговое меню показывает теперь явную ошибку.
  • TGZ-USB-Installer_V0.08.rar
    90 KB · Просмотры: 422
Maxi-Flasher для Single(1008, 1008SE) и Twin(1018) ресиверов .
Плагин для установки Maxi-U-Boot-Loaders включая Def-Boot-Args.
Flasher основан на плагине HDFreaks Bootloader Flash Plugin.
С помощью этого плагина возможно на оригинальном софте установить Bootloader без Putty и нольмодем кабеля. Установка плагина как обычно: архив распаковать и папку plugin на USB-флешку, флешку в ресивер и т.д.
После старта плагина выполняются некоторые действия:
В целях безопасности будет запрошен код: 0815
Дополнительно можно выбрать модель кнопками влево/вправо.
При установке определяется MAC- и IP-адрес и заносятся в Boot-окружение. А также отмечается Flag наличия SATA-жесткого диска . Если вы удаляете или наоборот устанавливаете жесткий диск то процедуру установки Bootloadera необходимо повторить.
Loader
Maxi-U-Boot-Loader позволяет производить запуск альтернативного софта с USB-накопителя. Следующие Boot-Args будут сразу установлены:
BA0 - загружает оригигальный софт из Flash => "Flash"
BA1-4 - загружает из первого USB-накопителя ==> "USB1 Pn"
BA5-8 - загружает из второго USB-накопителя ==> "USB2 Pn"
BA9 - загружает на примере HDF AutoBoot-скрипта и делает восстановление в случае сбоя ==> "USB 112"
Выбор BA's производиться кнопками вверх/вниз на пульте управления. По умолчанию загружается BA0. Нажатием кнопки MENU можно назначить другой BA.
Внимание: Перед обновлением софта нужно поставить BA0 (Flash), чтобы избежать ошибку при "UPGRADE APP"!
При загрузке USB BA: 2,3,4;6,7,8 будет пытаться загрузить Linux-Kernel "/uImage<P-Nr>" через fatload в первом разделе (P1). Это намного быстрее чем через ext2load "/boot/uImage", которое в конце все равно будет произведено. Для этого первый раздел P1 должен быть форматирован в FAT. uImage-файл будет скопирован и в этот номер раздела добавлен.
Примечание к 2 USB-накопителю
Порядок USB-портов у Twin "1018" задний USB1/sdb и передний USB2/sdc.
"Простой" Single "1008" имеет только один USB-порт и надо попробовать какой порт USB1 или USB2 работает. В случае ошибки это длится всего пару секунд и Boot-меню появится снова. Тогда быстро другой порт выбрать.
Для другого "навороченного" Single "1008SE" порядок портов как у Twin.
  • Maxi-Flasher-S11+BA.08.rar
    181,6 KB · Просмотры: 179
  • Maxi-Flasher-T11+BA.08.rar
    181,5 KB · Просмотры: 139
aheles
подскажите например хочу обновить новый софт последний после перехода на Maxi-U-Boot-Loaders какой у меня загрузчик будет версия интересует 2,54 или 2,23 на оригинальном софте
Сам то понял что спросил? :unsure: У тебя будет Maxi U Boot стоять. Какая там версия будет в системной информации уже не имеет значения. :)
enteran
Можно ли без проблем ставить последний оригинальный софт на загрузчик Maxi-Flasher для Single? Для перехода на Maxi-Flasher для Single с максибута надо откатываться на родной загрузчик? И стоит ли переходить с максибута на Maxi-Flasher, вопросы задаю в связи с тем, что для последних верисй оригинального софта рекомендуют ставить загрузчик 2.54, а у меня максибут который аналогичен загрузчику 2.23, вроде так.
Никто тебе не скажет пока сам не попробуешь. Хуже не будет однозначно. У тебя софт старый что ли еще? Макси лоадер для этого и создан чтобы ставить оригинальный софт и грузить энигму.
AAF Recovery Tool для Octagon 1028p V2.0a
AAF Recovery Tool AV7500
V2.0a
Исправление для работы с загрузчиком L 6.00
  • AAF_Recovery_tool_AV7500_V20a.rar
    19,8 MB · Просмотры: 301
TGZ-USB-Installer V0.09 L6.x0 SF-1008SE+ и SF-1028P
Version: 0.09
- Обновленные BootArgs для старта родного ПО (добавлено "USB Stop")
==> Теперь грузится родной софт с новой прошивкой 21011 снова :)
  • TGZ-USB-Installer_V0.09.rar
    94,1 KB · Просмотры: 656
DreamStream E2
Программа для просмотра телеканалов по сети на компьютере.
Возможности:
- переключение каналов
- просмотр ЕПГ
- функция записи
- скриншоты
- таймеры
- информация о канале
  • DreamStream.zip
    13,3 MB · Просмотры: 480
