Можно вот так :
[filter]
name = dvb
rule = caid=2600;reject
rule = caid=4ae1;ident=14;reject
rule = caid=4ae1;ident=15;ident:=0;accept # для Платформы
rule = caid=4ae1;ident=11;ident:=0;accept # для Триколор с сервера
rule = caid=1833;caid:=1702;accept #SKY Germany
rule = accept
debug = 1
[filter]
rule = caid=0500;ident=030600;sid=2f45,2f46,2f47,2f48,2f49,2f4a,3715;accept#HD
rule = caid=0500;ident=023700;sid!=2f45,2f46,2f47,2f48,2f49,2f4a,3715;accept #SD
rule = caid=0000;ident=000000;accept#Continent
rule = caid=090F;ident=0;accept#BALT
rule = caid=0500;ident=024F00;accept#Akta Satelit 4.8°E
rule = caid=4ae1;ident=0;accept#TRIK,PLATF
rule = caid=0500;ident=023100;accept#trk-УКР, fut
rule = caid=0652;ident=0,15;sid=456,4B0,79E,7A8,1900,190A,44C;accept #Raduga
А дальше ридеры- по количеству портов-разницы в работе никакой,а места занимает меньше!
[reader]
active = 1
type = newcamd525
account = логин:пароль@IP
debug = 1
reconnect_delay = 20
Вопрос к "sergik".. вот кусочек лога..,ключи получаем каждые 10 секунд и каждые пять секунд - строчка 05:08:42.774 R2[newcamd525]: reconnecting... failed,
что это..может означать.,?
[OPENXCAS_API:Fri Sep 3 05:08:06.911] openxcas_module_send_msg:179 ## (wicardd): success to send message(204) at tryCount = 0
[OPENXCAS_API:Fri Sep 3 05:08:21.592] make_filter_callback:564 ## <PIDFILTER> stream_id = 0, pid = 0x003e
05:08:21.603 dvb: marker = 00000000
05:08:21.604 dvb: match [if caid (4AE1) and ident (000011) set ident=000000 then accept]
[OPENXCAS_API:Fri Sep 3 05:08:21.605] openxcas_filter_callback_ex:1168 ## <PIDFILTER> stream_id = 0, sequence = 8, pid = 0x003e
05:08:21.916 R6[newcamd525]: ECM (4AE1:000000/69A0) for DVB0[OpenXCAS] decoded (313 ms)
[OPENXCAS_API:Fri Sep 3 05:08:21.916] openxcas_module_send_msg:179 ## (wicardd): success to send message(204) at tryCount = 0
05:08:22.115 R2[newcamd525]: reconnecting... failed
[OPENXCAS_API:Fri Sep 3 05:08:36.603] make_filter_callback:564 ## <PIDFILTER> stream_id = 0, pid = 0x003e
05:08:36.615 dvb: marker = 00000000
05:08:36.616 dvb: match [if caid (4AE1) and ident (000011) set ident=000000 then accept]
[OPENXCAS_API:Fri Sep 3 05:08:36.616] openxcas_filter_callback_ex:1168 ## <PIDFILTER> stream_id = 0, sequence = 8, pid = 0x003e
05:08:36.913 R6[newcamd525]: ECM (4AE1:000000/69A0) for DVB0[OpenXCAS] decoded (298 ms)
[OPENXCAS_API:Fri Sep 3 05:08:36.914] openxcas_module_send_msg:179 ## (wicardd): success to send message(204) at tryCount = 0
[filter]
name = dvb
rule = accept
debug = 1
[filter]
[reader]
active = 1
type = newcamd525
debug = 1
