Со слов пользователя kiel
Доигрался boese
UFS-910 ,было залито 1.03. Зарядил Stick на RC2 указал путь H:\kathrein\ufs910. Загрузка прошла, написало Ende начало перестартовывать и всё стоит только надпись на Display "Kathrein UFS-910"
и горил индикатор над кнопкой V-Format. Перестартовывал, но теперь ресивер не видит Stick verwirrt verwirrt verwirrt
Что можно сделать?
Помогло вот это emergency.ub
1.) install a tftp-server (windows e.g.
2.) download the "emergency-kernel" and copy "emergency.ub" to your tftp-share -
3.) connect the receiver through serial and network port and start the terminalapplication on the serial port
4.) power on the receiver and press immediately <enter> on the terminal, you should see the uboot prompt (STB7100-Ref>)
5.) on uboot prompt set the box ip with "set ipaddr 192.168.x.x" (you have to adapt x.x to your settings, both have to be in the same subnet)
6.) on uboot prompt set the tftp-server ip with "set ipaddr 192.168.x.x" (you have to adapt x.x to your settings, both have to be in the same subnet)
7.) on uboot prompt copy the kernel with "tftp a4000000 emergency.ub" into memory
8.) plugin the prepared usb-stick (you can get a full update of all partitions
9.) on uboot prompt start the kernel from memory with "bootm a4000000"
