Софт(ПО) и программы для AB CryptoBox 7ххHD
janigor
View Technical specification
New CPU 1GHz 2000 DMIPS
Support for new codec H.265 HEVC
Simply installation – setting receiver in two steps
FastScan – quick setting tv SK/CZ programs
Auto FastScan – automatically settings a new tv programs
IPTV – stream internet TV broadcast
Android App. for remote control box, adding and changing timer and streaming TV broadcast to your phone or tablet
FullHD resolution 1080p
1x DVB-S / DVB-S2 tuner
1x Card Reader
1x HDMI port
1x SCART
1x RS232
2x USB 2.0 ( 1x Front, 1x Rear panel )
1x LAN RJ 45
1x S/PDIF optical digital audio output
Chipset: ALI M3526
Flash Memory: 8 MByte
DDRII Memory: 128 Mbyte
Signal Level -65 do -25 dBm
LNB power and polarization
Vertical: +13V/+14V,
Horizontal: +18V/+19V
Power max. 25W
Frequency range 950 MHz do 2150 MHz
Video resolution 1080i/p, 720p, 576i/p, 480i/p
DiseqC 1.0/1.1/1.2/1.3 USALS 13V/18V, 0/22K
7 segment Display
7-day electronic guide
Fast Scan
Time Shift recording and PVR function
PIG ( Picture in Graphic )
FTP manager, games, weather, stock market information, networking capability and many more…
Automatic PAL / NTSC conversion
6000 TV / Radio Stations
26 the favorite groups
Support FAT32 and NTFS
media player formats:
audio MP3,WMA, WAV, M4A, MP4, AAC, APE, OGG, FLAC
video AVI, MKV, TS, TP, TRP, MPG, MPEG, MP4
picture JPEG, BMP, GIF
General
Input Frequency 950 ~ 2150MHz
Input Level -65 ~ -25dBm
Input Impedance 75Ω
LNB Polarisation 13V/18V/OFF, Imax = 400mA
LNB Switching 22KHz DiSEq C 1.0/1.2
Demodulation QPSK ,8PSK
Reed-Solomon 204, 188, t = 8
Roll Off Factor 0.35,0.25
FEC 1/2, 2/3, 3/4, 5/6, 7/8, Automatic
Symbol Rate 2.0~45 MS/s
DVB Standard DVB-S/S2 (EN300 421)
DVB-S2 Satellite Compliant MPEG-II/ MPEG-IV/ H.264/H.265
Video
Standard ISO/IEC 13818-2
Aspect Ratio 4:3, 16:9
Video Full Resolution 1920 × 1080p and 1920 × 1080i and 1280 × 720p for HD video, 720 × 480p, 720 × 480i, 720 × 576i, and 720 × 576p
for SD video, dual MPEG-1, MPEG-2 and MPEG-4 decode for SD resolution,MPEG4 AVC / H.264 and VC1 decode for dual SD and single HD up to 720p and 1080i and 1080p
Video Format PAL, NTSC
Video RAM 128 Mbytes
HDMI output 480p&480i,576p & 576i, 720p&1080i50Hz,1080P50Hz
Host Supplied Audio/Video I & P frame support
Format conversion Pan & Scan, Letterbox
Video planes 2 panes (1 graphic planes, 1 display planes)
Video decoder H.265(1080p@60fps)
H.264 (1080p@30fps) HP/MP/BP L1.4 Support -*.mkv, *.ts, *.m2ts, *.mov, *.mp4
VC-1 / WMV (1080p @30fps) Advanced Profile Level 3
RMVB (720p@30fps) – *.rm, *.rmvb
MPEG1/2/4 (1080p@30fps) – *.avi, *.mpg,*.mpeg, *.dat, *.vob, *.ts,*.mov, *.mp4
MJPEG (D1@30fps) – *.avi, *.mov
H.263 (D1@30fps) – *.avi, *.flv
Audio
Standard ISO/IEC 13818-3 (Decoding: MPEG-2 layer I and II (Musiccam),MPEG4 AAC and MPEG4 AAC-HE (AAC+), Dolby Digital (AC-3) with bit rates up to 640 Kbits/s,LPCM up to 48 KHz,MP3)
Sampling Frequency 32, 44.1, 48KHz
Audio Output Impedance Low
Output Mode Mono, Dual-channel, Stereo, Left, and Right
Processor
Chipset ALI M3526
Flash Memory 8 MByte
DDRII Memory 128 Mbyte 800Mhz
Front Panel
IR Receiver 38KHz
Display 7-segment
USB port 1 x
CA slot 1 x
Rear Panel
DVB LNB input and output F-type – Female
HDMI output 1 x
S/PDIF 1 x
SCART 1 x
USB2.0 1 x
RJ45 1 x
Others
Power Supply Smps,Input AC 100 ~ 240V, 50/60Hz; Eureapean plug
Power Consumption Max 25W
Ambient Operation Temperature 0 ~ 40℃
Product size 280*233*55mm
Gift box size 296*76*310mm
CE, RoHs, EuP LPC,
janigor
attachment.php
attachment.php
700HD_V1.09.17210_24-11-2016_A.bin
(English, Hungarian, Polish, Russian, Czech, Slovak, Ukrainian)
Changelog EN:
this is a first version of software!
  • 700HD_V1.09.17210_24-11-2016_A.rar
    4 MB · Просмотры: 42
    77 KB · Просмотры: 58
    173,1 KB · Просмотры: 56
janigor
700HD V1.09.17769
(English, German, Hungarian, Polish, Russian, Czech, Slovak, Ukrainian, Greek, Bulgarian, Romanian, Turkish, Netherland-Dutch, Arabic, French, Finnish, Spanish, Portugal, Italian)
EN: Download the RAR file, unpacking and please read carefully the attached TXT file.
Changelog EN:
  • new only one software with all languages
  • fixed youtube - youtube.cfg file needs to be updated
  • fixed stolen ECM data from server in soft standby
  • fixed 2 STBīs on same LNB, picture was stopped while one of STB was going to/from deep standby. Actually picture works again after 3-4 seconds.
  • edited provider Skylink Slovensko moved to 1st position in Fastscan menu
  • fixed not display auto fastscan message after reboot STB, if auto fastscan is off
  • fixed mixing channels after use move function
  • fixed install backup file in 700HD. Middle sw needs to be updated first (700HD_V1.09.17769_07-01-2017_MID_SW.bin)!
  • fixed Flix TV card is working in 700HD
  • 700HD_SW_patch_1.09.17769_07-01-2017.rar
    8,1 MB · Просмотры: 68
janigor
Загрузите RAR файл, разархивируйте и внимательно прочитайте TXT файл.
Обновите сначала свой ресивер промежуточным софтом "700HD_V1.09.17769_07-01-2017_MID_SW.bin" !
Затем обновите последним софтом, нажав кнопку "Media" на пульте ДУ.
Затем обновите файл youtube.cfg для корректной работы Youtube.
Зачем нужен youtube.cfg?
  • Файл youtube.cfg это файл настроек для приложения Youtube, которое присутствует в софте ресиверов AB CryptoBox 6XX и 7XX.
  • Этот файл нужно записать в ресивер при обновлении для правильной работы приложения youtube.
Почему файл youtube.cfg необходимо инсталлировать отдельно от всего софта?
  • Причина в том, что Youtube постоянно меняет свою структуру и чтобы по этой причине не было необходимости выпускать новый софт, мы сможем быстро изменить настройки Youtube и получить работающее приложение без необходимости менять весь софт.
Как инсталлировать youtube.cfg?
  • Актуальный файл youtube.cfg всегда найдете на FTP и прямо оттуда из меню ресивера сможете его установить.
  • Выкладываем ниже инструкцию как активировать satupdate FTP в ресивере, если адрес обновления уже не прописан в софте ресивера
ENGLISH: -----------------------------------------------------------------------------------------------------------------
Switch official soft for PATCH:
- In the receiver go to the: Menu -> Settings -> Software Update
- And fill data needs for FTP connections:
Pre 700HD insert:
host: ftp.700.satupdate.net
port: 21
meno: 700.satupdate.net
heslo: sat
Pre 652HD Combo insert:
host: ftp.652.satupdate.net
port: 21
meno: 652m.satupdate.net
heslo: sat
For 650HDC insert:
host: ftp.650C.satupdate.net
port: 21
meno: 650C.satupdate.net
heslo: sat
For 650HD insert:
host: ftp.650.satupdate.net
port: 21
meno: 650.satupdate.net
heslo: sat
For 600HD insert:
host: ftp.600.satupdate.net
port: 21
meno: 600.satupdate.net
heslo: sat
For 600HD mini insert:
host: ftp.600m.satupdate.net
port: 21
meno: 600m.satupdate.net
heslo: sat
For 550HDC insert:
host: ftp.500C.satupdate.net
port: 21
meno: 500C.satupdate.net
heslo: sat
For 550HD insert:
host: ftp.550.satupdate.net
port: 21
meno: 550.satupdate.net
heslo: sat
For 500HD insert:
host: ftp.500.satupdate.net
port: 21
meno: 500.satupdate.net
heslo: sat
For 500HD mini insert:
host: ftp.500m.satupdate.net
port: 21
meno: 500m.satupdate.net
heslo: sat
- Receiver was successfully connected to FTP, where you see two directories:
SOFTWARE
SETTINGS
- Select directory "SOFTWARE" and select the latest version SW. Let it install.
- Installation is complete when reciver is restarted.
- Done.
When you will install another new version of software, you don't need insert FTP data to the receive. FTP Data are already in the receiver saved for next time.
I wish you much success.
Можно ли установить файл youtube.cfg при помощи USB?
  • Да.
  • Актуальную версию файла необходимо скопировать на USB и затем установить из меню ресивера.
  • youtube.rar
    111 байт · Просмотры: 34
janigor
После прошивки ресивера новым софтом, рекомендую сделать сброс на заводские установки.
Иногда не отображаются некоторые пункты меню и "сброс" помогает это исправить.
janigor
Выяснилась еще одна проблема с последним софтом.
При втыкании в ресивер 700 или 6хх официальной карты Xtra TV ресивер начинает перегружаться постоянно.
Разработчикам софта о проблеме сообщили.
На предыдущих прошивках карта работает нормально.
janigor
Youtube.cfg 06032017
  • youtube.rar
    115 байт · Просмотры: 19
janigor
700HD V1.09.18034_Patch V1.09.18034_18-04-2017
EN:
- fix STB reboot with Antik Conax card
- window of EPG extended info (showed by 2x pressing info button) is larger
- if STB isn´t connected to any network, than DHCP is off, there are default values displayed
- added Youtube.cfg can be generated when USB is connected to STB. Go to USB menu, press yellow button and choose "Youtube cfg"
File will be added to STB and USB as well.
  • 700HD_V1.09.18034_18-04-2017.rar
    4,2 MB · Просмотры: 26
janigor
Youtube.cfg 26042017
  • youtube.rar
    91 байт · Просмотры: 5
janigor
Сегодня случайно выяснил, что последний софт V1.09.18034 показывает мультистрим зеонбуда.
Но не весь. Сканируется и показывает половина каналов с частоты 12341Н
Итальянцы и французы с 5W тоже показывают.
janigor
Youtube.cfg 04072017
  • youtube.rar
    105 байт · Просмотры: 6
janigor
youtube.cfg
update 12-09-2017
  • youtube_new.rar
    114 байт · Просмотры: 7
janigor
Редактор каналов для 7хх.
  • STBEditor_V1.6_7x0HD.rar
    214 KB · Просмотры: 31
janigor
700HD_V1.09.18815_16-11-2017
Changelog EN:
Strictly recommend factory default!!!
  • added - in Skylink Fast Scan added Auto FST message. If it is turned off, STB automatically update new FST table if there is detected new version
  • added - in Skylink Fast Scan added possiblity to change search type without turn off auto FST firstly
  • added - Fast Scan "FlixTV Slovak" a "FlixTV Czech"
  • added - Fast Scan "Digi SK", "Digi CZ" a "MagioSat".
  • added - it keeps channels from other providers when auto FST update is done. These channels are sorted at the end of channel list.
  • fix - subtitles are possible turn on manually, even they are turned off in OSD menu
  • fix - resize window of EPG extended info by twice pressing "info" button of RCU
  • fix - resize EPG grid of daily EPG for 2 hours. Can be seen after pressing EPG and green buttons of RCU
  • fix - CEC System Audio in HDMI CEC is OFF after reboot STB still
  • fix - Youporn works again
  • fix - Pantelio CAM faster switching channels
  • fix- Freezing picture when smart card was inserted and web sharing using (newcamd) in same time
  • add - youtube.cfg file will be downloaded and updated to STB automatically when Youtube starts
  • fix - Youtube search history has saved one word only
  • added - Support of Unicable II LNB type
  • fix - Rename Cyfra+ HD to NC+ fast scan
  • fix - FastScan NC+ works again
  • fix - Deleted TNK SD and TNK HD FastScan
  • added - Belintersat 51,5E satellite
  • added - auto update Biss emu. It is turned Off as default, but there is possible turn it on in Settings menu.
Known issues:
  • Cccam sharing is still debugging.
  • After switch to 108xx frequency sometimes has signal lost on few seconds.
  • 700HD_V1.09.18815_16-11-2017.rar
    4,3 MB · Просмотры: 20
janigor
Свежий файл
  • youtube1010.rar
    106 байт · Просмотры: 22
janigor
7xxHD_V1.10.19126_25-01-2018 V1.10.19126
Changelog EN:
1. edited - removed Viaccess key
Known issues:
  • 700HD_V1.10.19126_25-01-2018.rar
    4,3 MB · Просмотры: 32
  • 750HD_V1.10.19126_25-01-2018.rar
    4,2 MB · Просмотры: 22
janigor
752HD Combo V1.11.19323
Changelog EN:
  • this is a first version of software!
  • 752HD COMBO_V1.11.19323_29-03-2018.rar
    4,2 MB · Просмотры: 57
planer1903
AbCom Cryptobox 750HD
1)дамп
2)ключи с фаворитами для 4W-4.9E-13E-19E
3)отдельный софткам (PVU - не проверял)
  • -750HD.zip
    4,4 MB · Просмотры: 33
janigor
7xxHD V1.11.19423_09-05-2018
Changelog EN:
fix - STB totally hangs on some channels
fix - HDMI CEC with TV RCU support. After turn on HDMI CEC is reboot STB needed. TV isn´t able wakes up STB from deep standby.
added - improved mcas database
added - youtube.cfg file is automatically downloaded by starting Youtube
fix - auto BISS update didn´t work well
fix - only black screen was on TV while STB wakes up after few hours in fake standby while sharing card
fix - STB reboots itself while cc**m sharing randomly while it wakes up
fix - Dailymotion didn´t work
fix - STB reboots itself while fast forward in Youporn
fix - recordings of IPTV are playable
added - PIN code of CAM is automatically saved on adult channels. STB doesn´t ask enter PIN code on adult channels again. In CI menu there is option to remove saved PIN code.
fix - in Digi CAM entering PIN code on adult channels causes rebooting STB
fix - on VDSL routers problem with network apps
fix - non working audio track AD (Audio description)
fix - while showed TXT window it wasn´t possible adjust audio volume
fix - initializing cam message was displayed on TV while switching channel by using cams Skylink Irdeto Neotion and Skylink Viaccess CAM701
fix - in Viaccess CAM701 wasn´t possible enter PIN code because window was hidden too fast
fix - if PIN code was entered successfully to Viaccess CAM701 on adult channels, picture wasn´t showed on TV
added - region option in weather app
added - submenu name has used larger font
added - in item "Front Panel Display" was added new option "Channel name" = channel number will not be displayed, but only name
change - CI message is ON as default after factory reset
  • 700HD_V1.11.19423_09-05-2018.rar
    4,1 MB · Просмотры: 33
  • 750HD_V1.11.19423_09-05-2018.rar
    4,2 MB · Просмотры: 15
  • 752HD_V1.11.19423_09-05-2018.rar
    4,4 MB · Просмотры: 41
