4.0.0.0
- code migration to Delphi 2007, for later unicode support
- removed XP visual styles (there were some problems after migration to Delphi 2007)
- added theming for some components
- added channel numbers in bouquet panel
- added new hints in main list and bouquet details, now with picon
and service reference
- added option to assign and remove picons
- added cleanup function for local picon directory (which removes all unused picons) to tools menu
- added option for automatic picon upload to FTP window (Note: unzip command on your dreambox is required)
- added configurable per profile picon path to options panel
- added quick profile selection in statusbar
- added enhanced filter expressions (SQL style):
use % as substitute for zero or more characters
(e.g. %sky% shows all channels with "sky" in name),
use _ as substitute for exactly one character (e.g. _sky_ in package
filter shows channels of provider "BSkyB")
use \ as escape character (e.g. %\%% shows all channels with "%" in name)
if you don't use above filter characters the filters will only show exact matches
- changed TV service types defaults (now including HDTV service types)
- fixed error message when saving alternatives bouquet with parental lock
- fixed error message after reading radio service alternatives
- fixed bouquet change is now disabled while picons are loading to prevent errors
- fixed alternative service names are now written in UTF-8 instead of ANSI
- fixed alternatives are now deleted if service is removed from main service list
- fixed alternatives are now handled for each user bouquet seperately
- fixed translation problem in alternatives panel
- fixed problem with incorrect filename if you tried to add alternatives for a
data service, adding alternatives
for data channels is not allowed, please set proper service types in advanced
options first
- fixed keep filters when adding alternatives for a service
- fixed missing picons when using cut&paste or drag&drop
- fixed display of proper bouquet name when bouquet has been renamed
- fixed display of picons when adding services to an empty bouquet
- removed "input selection" in main service list as it didn't work as expected
4.0.0.0
- Миграции кода на Delphi 2007, для последующего Поддержка Unicode
- Удалить XP Visual Styles (там были некоторые проблемы после перехода на Delphi 2007)
- Добавил тематизации по некоторым компонентам
- Добавил номера каналов в букет панели
- Добавлены новые подсказки в главном списке и букет детали, теперь с Пикон и справочной службы
- Добавлена возможность назначать и удалять picons
- Добавлена функция очистки для локального каталога Пикон
(которая удаляет все неиспользуемые picons) в меню "Сервис"
- Добавлена опция для автоматического Picon загрузить на FTP окно
(Примечание: распаковать команду на Dreambox требуется)
- Добавил настраивается на пути профиля Picon на панели параметров
- Добавил быстрого выбора профиля в StatusBar
- Добавил расширение выражений фильтра (SQL стилю):
Используйте% в качестве заменителя нуля или более символов
(например,%% небо показывает все каналы с "неба" в названии),
Используйте _ как замена одного символа
(например, _sky_ в пакете фильтра каналов показывает
провайдера "BSkyB")
использовать \ как управляющий символ (например,% \%% показывает
все каналы с "%" в названии)
если вы не используете выше фильтр символов фильтров будут отображаться только точные совпадения
- Изменена телевидения типов по умолчанию (в настоящее время, включая типы HDTV службы)
- Исправлено сообщение об ошибке при сохранении букет альтернатив с
родительский замок
- Исправлено сообщение об ошибке после прочтения альтернативы
Radio Service
- Исправлено изменение букет теперь отключается во время picons загружаете, чтобы предотвратить ошибки
- Исправлена альтернативных имен службы в настоящее время записан
в UTF-8 вместо ANSI
- Исправлена альтернативы в настоящее время удален, если сервис
будет удален из основного списка службы
- Исправлена альтернативы в настоящее время обрабатывается для каждого пользователя отдельно букет
- Исправлена проблема перевода в панель альтернатив
- Исправлена проблема с неправильным имя файла, если вы пытались
добавить альтернатив для услуг передачи данных, добавив альтернативы
для данных каналов не допускается, пожалуйста, установите
соответствующих видов услуг в дополнительные параметры первого
- Исправлена сохранить фильтры при добавлении альтернатив для службы
- Исправлено отсутствие picons при использовании вырезать и вставить
или перетащить и падение
- Исправлено отображение имя собственное, когда букет букет был
переименован
- Исправлено отображение picons при добавлении услуги пустой букет
- Удалены "выбор входа" в главном списке службу, поскольку она не
работает, как ожидалось
