http://www.dream-elite.net/forum/showthread.php?10438-New-Update-DE-3.0-ver.010r3&p=61900#post61900Check update availability in Menu'>information>info
To update: Menu'>Configuration>software manager>software update
Some Dream Elite fix
Update drivers to 16/02/2012
Update plugins to 17/02/2012
Autotimer fix
USB Loader fix for 7020
Note: if you have Dream Elite image on Barry Allen update first the flash image.
- updated translations
- some storage manager optimization
- fixed possible epgcache crash
- fixed teletext subtitle crash
- optimized teletext subtitle render quality
- fixed common interface assignment plugin bug
- fixed teletext subtitle selection screen
- fixed skipping backward from live to timeshift
- added expert option "Rotor is exclusively controlled
by this dreambox" to fix slow zapping times between
rotor and non-rotor lnbs (enabled by default)
- fixed tuner resource leak on signal loss
- fixed displaying of multilingual epg descriptions
- improved transponder search speed (skip transponders without usable services)
- fixed possible crash on enigma2 shutdown
- fixed scrollabel for texts longer than a whole page
- updated default favourite list and astra default services
- fixed possible problem with multiple CIs for the same service/provider/caid
enigma2-defaultservices: update astra 19.2 default services
dreambox-dvb-modules: update OE1.6 dreambox hw drivers 20120706
- fixed not working "dm7020hd" remote control with dm800se and dm500hd after fp update
- fixed demux bug
- small CI fix
А я все жду 4 версию на новом ядре.
На форуме разработчиков пишут что проблема в барри аллене 7.1.
Ничего нового, только исправили ЕПГ для итальянцев.Dream Elite staff wants to propose a new update for the DE 4.0 with enigma 2.0
In this update you will find an EPG patch to make up for the lack of EPG for the Italian providers, awaiting that Dream-Multimedia fix definitively the problem, both for the EPG and DTT using USB tuner.
Therefore Dream Elite staff has create this patch using DE-EPG, to allow you to use the EPG on the Italian providers.
