Valery192
HDMU_12783_E2_hs7810a_215_git_3168 mp3 теперь играет но замирает каждые 3-4 сек.картинка со спутника.
На форуме HDMU идет опрос пользователей на предмет наличия ресиверов. Просьба по возможности проголосовать за свой ресивер. :) Опрос заканчивается 1.10.2014. Можно выбрать несколько ресиверов.
На некоторые ресиверы доступны новые имиджи HDMU_12810_E2_******_215_git_3194_nodebug_mix_USB. :)
-----====== HDMU 12810 enigma2 Git 3194 ======-----
12810    b4f7205 bonkel, Mon Sep 8 08:30:12 2014 +0200: Merge remote-tracking branch 'plineu/master'
12809    d2a00f9 littlesat, Sun Sep 7 22:10:54 2014 +0200: Add option "Network scan" yes/no for Automatic scan
12808    0598678 bonkel, Sun Sep 7 21:56:53 2014 +0200: Merge remote-tracking branch 'plineu/master'
12807    ae1a88f Taapat, Sun Sep 7 18:25:53 2014 +0300: Enable remove services from all bouquets
12806    bbacea5 littlesat, Sun Sep 7 17:08:23 2014 +0200: Downloader: replace import of urlparser
12805    14c8546 Mike Looijmans, Sun Sep 7 15:06:36 2014 +0200: ChoiceList: Only load PNG when key is defined
12804    94047c8 bonkel, Sun Sep 7 14:38:45 2014 +0200: Merge remote-tracking branch 'plineu/master'
12803    a4302d9 littlesat, Sun Sep 7 13:42:01 2014 +0200: Satconfig: solve issue when using wizard
12802    487894d bonkel, Sun Sep 7 10:33:59 2014 +0200: fix
12801    f4b2955 pieterg, Sat Sep 6 22:55:06 2014 +0200: eDVBScan: fix compile error
12800    992235b pieterg, Sat Sep 6 18:22:02 2014 +0200: eDVBDB: avoid storing System_DVB_T_T2 in the lamedb
12799    11ead38 pieterg, Sat Sep 6 18:19:28 2014 +0200: eDVBScan: fix T->T2 fallback
12798    c1473bd pieterg, Sat Sep 6 17:57:14 2014 +0200: eDVBScan: fix NULL pointer segfault
12797    ff65ad6 pieterg, Sat Sep 6 17:58:11 2014 +0200: Revert "frontend: prefer DVB-T2 when both are available."
12796    14da57c dima73, Sat Sep 6 15:07:18 2014 +0200: frontend: prefer DVB-T2 when both are available.
12795    ce19b7f Tech, Sat Sep 6 13:25:34 2014 +0200: added et7x00 rc
12794    bf0851c ims, Sat Sep 6 12:21:27 2014 +0200: added missing import urlparse in downloader.py
12793    ff5e459 Littlesat, Fri Sep 5 17:50:44 2014 +0200: Downloader: Adjust for new twisted
12792    911fcc7 blzr, Thu Sep 4 20:38:53 2014 +0200: pl.po: translations update
12791    72232ff bonkel, Fri Sep 5 05:40:18 2014 +0200: fix
12790    5eedbb4 littlesat, Thu Sep 4 18:49:21 2014 +0200: Update the software update disclaimer
12789    11ab0aa littlesat, Thu Sep 4 18:43:50 2014 +0200: Introduce preview mode on OK button in ChannelSelection
12788    59c7b41 littlesat, Wed Sep 3 21:02:53 2014 +0200: Hopefully last try to solve wake in lan for VU
12787    8d8ca42 daddelfalk, Mon Sep 1 15:51:24 2014 +0200: scan.cpp:  perform T2 and T scan only, when frontend is actually supporting DVB-T2.  This will also fix USB DVB-T full service scan and tunein issues with  -1 entries in lamedb.
12786    bc84a8f littlesat, Mon Sep 1 18:46:00 2014 +0200: Revert "Move Wake On LAN config to NetworkSetup"
12785    3b6343e littlesat, Mon Sep 1 18:45:37 2014 +0200: Revert "NetworkSetup: ensure that wakeOnLan config is saved"
12784    d82794c littlesat, Mon Sep 1 18:44:29 2014 +0200: Revert "NetworkSetup: only save wakeOnLAN config when feature exists"
ВИД-57
spartak73, Что-то не получилось у меня зарегистрироваться там.... Здесь будут выкладываться имиджи?
HDMU_12810_E2_hs7810a_215_git_3194 этот имидж без вопросов.
Ты о чем? :pardon:
Нет, их собирают слишком часто... Мне тогда нужно только сутками сидеть и загружать :rofl:. Могу выкладывать только по просьбе пару имиджей. :)
  • HDMU_12810_E2_1008g+se+_215_git_3194_nodebug_mix_USB.zip
    39,4 MB · Просмотры: 48
druc
spartak73,
Если не затруднит и я попрашу ссылку на open S4 - sh7110. Вне зависимости спасибо.
  • HDMU_12810_E2_hs7110_215_git_3194_nodebug_mix_USB.zip
    39,4 MB · Просмотры: 25
druc
yuramuzika
Попробуйте, в предыдущем сообщении spartak73 нажать кнопку -спасибо-. Возможно, для вас появится необходимое вам.
vova7778
Установил имидж HDMU_12810_E2_1008g+se+_215_git_3197_nodebug_mix_USB все нормально запустился, но на дисплее только надпись BOOT и все, не показывает ни номер карала ни название, даже когда выключаю ресивер тоже надпись BOOT. Как с этим бороться подскажите пожалуйста.
aheles
HDMU_12815_E2_ установил , вот что наверно шрифты сменили , на панели ресивера отоброжение канала идет , шрифт изменен , да привыклечение ресивера в ждущий режим , отоброжени часов на панели ресивера как то не коректно отображает , как и где сменить шрифт
Тема закрыта! !closed! Далее продолжаем здесь! :)
