% ×(Re)start USB...
Front USB: scanning bus for devices... 3 USB Device(s) found
scanning bus for storage devices... 1 Storage Device(s) found
262144000 root.img
3012747 uimage
2 file(s), 0 dir(s)
reading uImage
ret=> 3012747
Wait [1]
Wait [2]
Wait [3]
Wait [4]
Wait [5]
Wait [6]
ext2fs_check_if_mount: Can't check if filesystem is mounted due to missing mtab
file while determining whether /mnt/root.img is mounted.
/mnt/root.img: clean, 5909/64000 files, 115797/256000 blocks
mount root
INIT: version 2.88 booting
insmod: can't insert '/lib/modules/e2_proc.ko': invalid module format
init frontpanel
insmod: can't insert '/lib/modules/nuvoton.ko': invalid module format
[mountvirtfs] Mount /dev in tmpfs
[mountvirtfs] Copying device nodes to /dev
Starting portmap daemon....
Loading autofs
Starting autofs
[mountall] Mounting local filesystems...
mount: mounting LABEL=RECORD on /hdd failed: No such file or directory
Cleaning /tmp.
Hostname: 1008PSE+.
init stmfb
/etc/init.d/rcS: line 667: can't create /dev/vfd: No such device or address
LOADING MODULES
load firmware
copLoadFile (file /boot/audio.elf)
ustslave: Kernel Version: 24
base_address 0x40400000
seeking to 0
seeking to 5e00
seeking to 12460
seeking to 1ab60
seeking to 154300
seeking to 154338
seeking to 154370
seeking to 191a58
seeking to 191a60
seeking to 191a68
seeking to 191a70
seeking to 1aae40
seeking to 1aaf00
copLoadFile (file /boot/video.elf)
base_address 0x40000000
seeking to 0
seeking to 60980
seeking to 148478
seeking to 1484b0
seeking to 1484e8
seeking to 158858
seeking to 158864
seeking to 158880
seeking to 184d94
seeking to 186e00
init embx
init AVS
skip mpeg2
insmod: can't insert '/lib/modules/lnb.ko': unknown symbol in module, or unknown
parameter
insmod: can't insert '/lib/modules/stv090x.ko': unknown symbol in module, or unk
nown parameter
insmod: can't insert '/lib/modules/stmdvb.ko': unknown symbol in module, or unkn
own parameter
insmod: can't insert '/lib/modules/player2.ko': unknown symbol in module, or unk
nown parameter
insmod: can't insert '/lib/modules/sth264pp.ko': unknown symbol in module, or un
known parameter
insmod: can't insert '/lib/modules/stmalloc.ko': unknown symbol in module, or un
known parameter
/etc/init.d/rcS: line 667: can't create /proc/stb/video/videomode: nonexistent d
irectory
vBoxType: 0
Selected Remote: (null)
Frontpanel Map:
- 693632056 üW) -
- sh4/st40-300/ - 808744051
-300/ - - 693632128
¤ÃV) - - 1
- ž¨V) - 9
Supports Long KeyPress: 28
processComplex >
showSinglePic /boot/bootlogo.mvi
VIDEO_SET_FORMAT failed (Bad file descriptor)
Deconfiguring network interfaces... ifdown: interface eth0 not configured
ifdown: interface wlan0 not configured
done.
Setting up IP spoofing protection: rp_filter.
Configuring network interfaces... udhcpc: started, v1.26.0
udhcpc: sending discover
/etc/init.d/rcS: line 667: /sbin/set_was_timer_wakeup: not found
cat: can't open '/proc/stb/video/plane/psi_tint': No such file or directory
Invalid card number.
Usage: amixer <options> command
Available options:
-h,--help this help
-c,--card N select the card
-D,--device N select the device, default 'default'
-d,--debug debug mode
-n,--nocheck do not perform range checking
-v,--version print version of this program
-q,--quiet be quiet
-i,--inactive show also inactive controls
-a,--abstract L select abstraction level (none or basic)
Available commands:
scontrols show all mixer simple controls
scontents show contents of all mixer simple controls (default command)
sset sID P set contents for one mixer simple control
sget sID get contents for one mixer simple control
controls show all controls for given card
contents show contents of all controls for given card
cset cID P set control contents for one control
cget cID get control contents for one control
Available options:
-h,--help this help
-q,--quiet be quiet
Available commands:
Available options:
-h,--help this help
-q,--quiet be quiet
Available commands:
starting e2->
/usr/local/bin/enigma2: error while loading shared libraries: libglcddrivers.so.
2: cannot open shared object file: No such file or directory
e2 ended <- RTV: 127
INIT: Switching to runstarting e2->
INIT: Sending processes the TERM signal
udhcpc: received SIGTERM
Sending all processes the TERM signal...done.
Sending all processes the KILL signal...done.
Deactivating swap...umount: tmpfs busy - remounted read-only
done.
Unmounting local filesystems...umount: tmpfs busy - remounted read-only
umount: can't unmount /mnt: Invalid argument
done.
Restarting ...
