<?xml version="1.0" encoding="utf-8"?>
<openpli>
<enigma2>
<crashdate>Птн Мар 8 11:20:49 2013</crashdate>
<compiledate>Apr 27 2013</compiledate>
<contactemail>forum at www.opensat4all.com</contactemail>
<!-- Please email this crashlog to above address -->
<skin>PLi-HD/skin.xml</skin>
<sourcedate>2013-04-26</sourcedate>
<branch>(no branch)</branch>
<rev>fc7743e</rev>
<version>3.0.0</version>
</enigma2>
<image>
<stbmodel>premium</stbmodel>
<kernelversion>
<![CDATA[
Linux azboxhd 3.3.1-opensat #1 PREEMPT Fri Mar 29 05:12:06 CET 2013 mips GNU/Linux
</kernelversion>
<kernelcmdline>mem=107m console=ttyS0,115200</kernelcmdline>
<nimsockets>NIM Socket 0:</nimsockets>
<imageversion>
<!-- No such file or directory -->
</imageversion>
<imageissue>
<![CDATA[
openrsi 3.0 %h
</imageissue>
</image>
<crashlogs>
<enigma2crashlog>
<![CDATA[
+ (1) Background File Eraser
+ (5) Tuxtxt
+ (8) graphics acceleration manager
+ (9) GFBDC
8174k video mem
- double buffering available!
974kB available for acceleration surfaces.
resolution: 1280 x 720 x 32 (stride: 5120)
+ (9) gLCDDC
found OLED display!
lcd buffer 0x7d57e0 8448 bytes, stride 132
LCD resolution: 132 x 64 x 8 (stride: 132)
+ (9) Font Render Class
[FONT] initializing lib...
[FONT] loading fonts...
[FONT] Intializing font cache, using max. 4MB...
+ (10) gRC
RC thread created successfully
+ (15) eWindowStyleManager
+ (20) DVB-CI UI
+ (20) UHF Modulator
+ (20) RC Input layer
+ (20) misc options
+ (20) AVSwitch Driver
couldnt open /dev/dbox/fp0 to monitor vcr scart slow blanking changed!
+ (21) input device driver
Input device "dreambox remote control (native)" is a remotecontrol
Found 1 input devices.
+ (22) Hdmi CEC driver
+ (30) eActionMap
+ (35) CI Slots
scanning for common interfaces..
cannot open /proc/stb/tsmux/input2
eDVBCIInterfaces->setInputSource(0, 0)
eDVBCIInterfaces->setInputSource(1, 1)
done, found 1 common interface slots
+ (35) CA handler
+ (36) Stream server
+ (40) eServiceCenter
settings instance.
+ (41) eServiceFactoryDVD
+ (41) eServiceFactoryM2TS
+ (41) eServiceFactoryMP3
+ (41) eServiceFactoryFS
+ (41) eServiceFactoryDVB
reached rl 70
---- opening lame channel db
reading services (version 4)
loaded 0 services
scanning for frontends..
opening frontend 0
close frontend 0
boxtype detection via /proc/stb/info not possible... use fallback via demux count!
found 1 adapter, 1 frontends(1 sim) and 3 demux, boxtype 1
Use valid Linux Time
(RTC?)
[EPGC] Initialized EPGCache (wait for setCacheFile call now)
Loading spinners...
[ePNG] couldn't open /usr/share/enigma2/skin_default/spinner/wait5.png
found 4 spinner!
setIoPrio best-effort level 3 ok
Failed to open /dev/dbox/fp0
[Harddisk] enumerating block devices...
main thread is non-idle! display spinner!
Reading satellites.xml
sec config cleared
setSlotInfo for dvb frontend 0 to slotid 0, descr Conexant CX24116/CX24118, need rotorworkaround No, enabled Yes, DVB-S2 Yes
slot: 0 configmode: advanced
sec config completed
loading bouquet... /etc/enigma2/bouquets.tv 1
loading bouquet... /etc/enigma2/userbouquet.favourites.tv 1
0 entries in Bouquet userbouquet.favourites.tv
1 entries in Bouquet bouquets.tv
loading bouquet... /etc/enigma2/bouquets.radio 1
loading bouquet... /etc/enigma2/userbouquet.favourites.radio 1
0 entries in Bouquet userbouquet.favourites.radio
1 entries in Bouquet bouquets.radio
[FONT] adding font /usr/share/fonts/nmsbd.ttf...OK (Regular)
[FONT] adding font /usr/share/fonts/andale.ttf...OK (Fixed)
[FONT] adding font /usr/share/fonts/tuxtxt.ttf...OK (Console)
[FONT] adding font /usr/share/fonts/ae_AlMateen.ttf...OK (Replacement)
[FONT] adding font /usr/share/fonts/lcd.ttf...OK (LCD)
[FONT] adding font /usr/share/fonts/valis_enigma.ttf...OK (Subs)
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 25] Inappropriate ioctl for device >
Activating keymap: Default (US)
[ePopen] command: loadkmap < /usr/share/keymaps/default.kmap
Activating language Русский
[ePopen] command: ip -o addr show dev eth0
[ePopen] command: ip -o addr show dev wlan0
setLCDBrightness 25
[LCD] can't open /dev/dbox/fp0
setLCDBrightness 127
[AutoBackup] fallback to default translation for Automatic settings backup
Plugin Extensions/WebInterface failed to load: No module named plugin
Plugin probably removed, but not cleanly in /usr/lib/enigma2/python/Plugins/Extensions/WebInterface
[Foreca Ver. 3.0.8] Debug disabled
[Foreca Ver. 3.0.8] Collating sequence undeterminable; default used
[Foreca Ver. 3.0.8] Setup...
-->205<----
[FONT] adding font /usr/lib/enigma2/python/Plugins/Extensions/cScVOD/cMRegular.otf...OK (cRegularIP)
[FONT] adding font /usr/lib/enigma2/python/Plugins/Extensions/cScVOD/cnmsbd.ttf...OK (cRegular)
No module named servicewebts
ERROR servicewebts STREAM *******************************************************
loadSkin: Screen already defined elsewhere: Playlist
loadSkin: Screen already defined elsewhere: IPTVplayer
loadSkin: Screen already defined elsewhere: VODplayer
loadSkin: Screen already defined elsewhere: TasksScreen
loadSkin: Screen already defined elsewhere: SelectorQuality
loadSkin: Screen already defined elsewhere: SelectorAudio
loadSkin: Screen already defined elsewhere: Plugin_menu
loadSkin: Screen already defined elsewhere: Security_menu
loadSkin: Screen already defined elsewhere: SelectSearch
loadSkin: Screen already defined elsewhere: MainPrScreen
loadSkin: Screen already defined elsewhere: VirtualKeyBoardRUS_FIXED
getModeList for port DVI-PC
remove DVI-PC because of not existing modes
hotplug on dvi
getModeList for port YPbPr
getModeList for port Scart
-> setting aspect, policy, policy2, wss 16:9 panscan letterbox auto
==>> input video scan mode
1
==>> interlaced progressive algorithm
1
==>> updateAudioMode
OK
setMode - port: DVI mode: 720p rate: multi
[NetworkBrowser] fallback to default translation for NetworkBrowser
[NetworkBrowser] fallback to default translation for Search for network shares
[NetworkBrowser] fallback to default translation for MountManager
[NetworkBrowser] fallback to default translation for Manage network shares
[NetworkBrowser] fallback to default translation for Mount again
[NetworkBrowser] fallback to default translation for Attempt to mount shares again
starting hotplug handler
wasTimerWakeup failed!
[CacheFlush] fallback to default translation for pagecache
[CacheFlush] min_free_kbytes is 1024 kB
[CacheFlush] set min_free_kbytes to 1024 kB
[SKIN] Parsing embedded skin <embedded-in-'CacheFlushAutoScreen'>
Applying RSI Configuration Options
[KEYMAP BY PingFlood]
[EPGC] setCacheFile read/write epg data from/to '/hdd/epg.dat'
[EPGC] time updated.. start EPG Mainloop
[EPGC] /hdd/epg.dat not found, try /epg.dat
[SKIN] Parsing embedded skin <embedded-in-'Screensaver'>
[Skin] SKIN ERROR in SecondInfoBar: 'HasHBBTV'
[ePNG] failed to get png header
ePixmap::setPixmapFromFile: loadPNG failed
[ePNG] couldn't open /usr/share/enigma2/ico_dvb_s-fs8.png
[ePNG] couldn't open /usr/share/enigma2/ico_dvb_c-fs8.png
[ePNG] couldn't open /usr/share/enigma2/ico_dvb_t-fs8.png
[ePNG] couldn't open /usr/share/enigma2/ico_service_group-fs8.png
warning, skin is missing element From in <class 'Screens.Dish.Dish'>
warning, skin is missing element Goto in <class 'Screens.Dish.Dish'>
OPTION: 1 classic
OPTION: 1 classic
setValue 45
Setvolume: 100 100 (raw)
Setvolume: 0 0 (-1db)
Setvolume: 45 45 (raw)
Setvolume: 35 35 (-1db)
RemovePopup, id = ZapError
[Skin] SKIN ERROR in InfoBar: 'HasHBBTV'
EXCEPTION IN PYTHON STARTUP CODE:
Traceback (most recent call last):
File "/usr/lib/enigma2/python/mytest.py", line 594, in <module>
runScreenTest()
File "/usr/lib/enigma2/python/mytest.py", line 478, in runScreenTest
runNextScreen(session, screensToRun)
File "/usr/lib/enigma2/python/mytest.py", line 472, in runNextScreen
session.openWithCallback(boundFunction(runNextScreen, session, screensToRun[1:]), screen, *args)
File "/usr/lib/enigma2/python/mytest.py", line 294, in openWithCallback
dlg = self.open(screen, *arguments, **kwargs)
File "/usr/lib/enigma2/python/mytest.py", line 307, in open
self.execBegin()
File "/usr/lib/enigma2/python/mytest.py", line 205, in execBegin
c.execBegin()
File "/usr/lib/enigma2/python/Screens/Screen.py", line 82, in execBegin
File "/usr/lib/enigma2/python/Screens/InfoBarGenerics.py", line 176, in __onExecBegin
File "/usr/lib/enigma2/python/Screens/InfoBarGenerics.py", line 185, in ScreenSaverTimerStart
File "/usr/lib/enigma2/python/Components/config.py", line 1577, in __getattr__
KeyError: 'screen_saver'
open /dev/dbox/fp0 for wakeup timer clear failed!(No such file or directory)
(exit code 5)
getResolvedKey config.plugins.crashlogautosubmit.sendAnonCrashlog failed !! (Typo??)
getResolvedKey config.plugins.crashlogautosubmit.addNetwork failed !! (Typo??)
getResolvedKey config.plugins.crashlogautosubmit.addWlan failed !! (Typo??)
</enigma2crashlog>
</crashlogs>
</openpli>
