[ 45.740000] SMP863x: VIDEO_PLAY
[ 45.750000] MBUS: error previous command is pending (0:4) ...
[ 45.750000] tango2_bmide: fail to setup dma, fallback to pio
[ 45.760000] SMP863x: STC PLAY
[ 45.760000] SMP863x: VIDEO_CONTINUE
[ 45.770000] MBUS: error previous command is pending (0:4) ...
[ 45.790000] SMP863x: VIDEO_CLEAR_BUFFER
[ 45.800000] tango2_bmide: fail to setup dma, fallback to pio
[ 45.840000] MBUS: error previous command is pending (0:4) ...
[ 45.840000] tango2_bmide: fail to setup dma, fallback to pio
[ 45.890000] MBUS: error previous command is pending (0:4) ...
[ 45.890000] tango2_bmide: fail to setup dma, fallback to pio
[ 45.940000] MBUS: error previous command is pending (0:4) ...
[ 45.940000] tango2_bmide: fail to setup dma, fallback to pio
[ 45.970000] MBUS: error previous command is pending (0:4) ...
[ 45.970000] tango2_bmide: fail to setup dma, fallback to pio
[ 46.020000] SMP863x: VIDEO_STOP
[ 46.020000] MBUS: error previous command is pending (0:4) ...
[ 46.020000] tango2_bmide: fail to setup dma, fallback to pio
[ 46.040000] SMP863x: STC STOP
[ 46.040000] SMP863x: VIDEO SELECT SOURCE: DEMUX
[ 46.040000] SMP863x: CURRENT STC MODE: MEMORY
[ 46.060000] SMP863x: NEW STC MODE: SAT
[ 46.070000] MBUS: error previous command is pending (0:4) ...
[ 46.090000] tango2_bmide: fail to setup dma, fallback to pio
[ 46.130000] MBUS: error previous command is pending (0:4) ...
[ 46.130000] tango2_bmide: fail to setup dma, fallback to pio
[ 46.150000] MBUS: error previous command is pending (0:4) ...
[ 46.150000] tango2_bmide: fail to setup dma, fallback to pio
[ 46.210000] MBUS: error previous command is pending (0:4) ...
[ 46.210000] tango2_bmide: fail to setup dma, fallback to pio
[ 46.240000] MBUS: error previous command is pending (0:4) ...
[ 46.240000] tango2_bmide: fail to setup dma, fallback to pio
[ 46.250000] MBUS: error previous command is pending (0:4) ...
[ 46.260000] tango2_bmide: fail to setup dma, fallback to pio
[ 46.300000] MBUS: error previous command is pending (0:4) ...
[ 46.300000] tango2_bmide: fail to setup dma, fallback to pio
[ 46.320000] MBUS: error previous command is pending (0:4) ...
[ 46.330000] tango2_bmide: fail to setup dma, fallback to pio
[ 46.350000] MBUS: error previous command is pending (0:4) ...
[ 46.350000] tango2_bmide: fail to setup dma, fallback to pio
[ 46.390000] MBUS: error previous command is pending (0:4) ...
[ 46.390000] tango2_bmide: fail to setup dma, fallback to pio
[ 46.430000] MBUS: error previous command is pending (0:4) ...
[ 46.430000] tango2_bmide: fail to setup dma, fallback to pio
[ 49.090000] SMP863x: FBIO ACCEL INIT
[ 49.100000] SMP863x: FBIO GET ACCEL BLEND_SUPPORT
[ 49.150000] SMP863x manual blit 1
[ 49.150000] New FB OSD resolution [1280:720] , virtual [1280:1440], bpp 32
[ 49.180000] SMP863x: OSD: dst_surf = 2007b1f8, size = 3686400
[ 49.190000] SMP863x FB PAN: 0 0
[ 50.040000] cx24116_initfe: FW version 1.22.82.0
[ 55.020000] MBUS: error previous command is pending (0:4) ...
[ 55.020000] tango2_bmide: fail to setup dma, fallback to pio
[ 55.110000] MBUS: error previous command is pending (0:4) ...
[ 55.130000] tango2_bmide: fail to setup dma, fallback to pio
[ 62.610000] MBUS: error previous command is pending (0:4) ...
[ 62.610000] tango2_bmide: fail to setup dma, fallback to pio
[ 62.640000] MBUS: error previous command is pending (0:4) ...
[ 62.650000] tango2_bmide: fail to setup dma, fallback to pio
[ 68.020000] MBUS: error previous command is pending (0:4) ...
[ 68.020000] tango2_bmide: fail to setup dma, fallback to pio
[ 68.090000] MBUS: error previous command is pending (0:4) ...
[ 68.090000] tango2_bmide: fail to setup dma, fallback to pio
[ 69.040000] SMP863x: RFNum 36 PwrMode 1 SysMode 1 Sound 0
[ 69.050000] SMP863x: RFNum 36 PwrMode 1 SysMode 1 Sound 0
[ 69.060000] SMP863x: RFNum 36 PwrMode 1 SysMode 1 Sound 0
[ 69.070000] SMP863x: RFNum 36 PwrMode 1 SysMode 1 Sound 0
[ 73.650000] MBUS: error previous command is pending (0:4) ...
[ 73.650000] tango2_bmide: fail to setup dma, fallback to pio
[ 73.680000] MBUS: error previous command is pending (0:4) ...
[ 73.700000] tango2_bmide: fail to setup dma, fallback to pio
[ 75.110000] Status code returned 0xc000006d NT_STATUS_LOGON_FAILURE
[ 75.120000] CIFS VFS: Send error in SessSetup = -13
[ 75.190000] Status code returned 0xc000006d NT_STATUS_LOGON_FAILURE
[ 75.220000] CIFS VFS: Send error in SessSetup = -13
[ 75.220000] CIFS VFS: cifs_mount failed w/return code = -13
[ 75.300000] Status code returned 0xc000006d NT_STATUS_LOGON_FAILURE
[ 75.330000] CIFS VFS: Send error in SessSetup = -13
[ 75.420000] Status code returned 0xc000006d NT_STATUS_LOGON_FAILURE
[ 75.440000] CIFS VFS: Send error in SessSetup = -13
[ 75.480000] CIFS VFS: cifs_mount failed w/return code = -13
[ 75.890000] SMP863x: end kChangeMode
[ 76.220000] MBUS: error previous command is pending (0:4) ...
[ 76.220000] tango2_bmide: fail to setup dma, fallback to pio
[ 76.270000] MBUS: error previous command is pending (0:4) ...
[ 76.270000] tango2_bmide: fail to setup dma, fallback to pio
[ 76.290000] MBUS: error previous command is pending (0:4) ...
[ 76.290000] tango2_bmide: fail to setup dma, fallback to pio
[ 76.300000] MBUS: error previous command is pending (0:4) ...
[ 76.310000] tango2_bmide: fail to setup dma, fallback to pio
[ 76.350000] MBUS: error previous command is pending (0:4) ...
[ 76.350000] tango2_bmide: fail to setup dma, fallback to pio
[ 76.390000] MBUS: error previous command is pending (0:4) ...
[ 76.390000] tango2_bmide: fail to setup dma, fallback to pio
[ 76.420000] MBUS: error previous command is pending (0:4) ...
[ 76.420000] tango2_bmide: fail to setup dma, fallback to pio
[ 76.450000] MBUS: error previous command is pending (0:4) ...
[ 76.460000] tango2_bmide: fail to setup dma, fallback to pio
[ 76.480000] MBUS: error previous command is pending (0:4) ...
[ 76.480000] tango2_bmide: fail to setup dma, fallback to pio
[ 76.520000] MBUS: error previous command is pending (0:4) ...
[ 76.520000] tango2_bmide: fail to setup dma, fallback to pio
[ 76.550000] MBUS: error previous command is pending (0:4) ...
[ 76.550000] tango2_bmide: fail to setup dma, fallback to pio
[ 76.630000] MBUS: error previous command is pending (0:4) ...
[ 76.630000] tango2_bmide: fail to setup dma, fallback to pio
[ 76.690000] MBUS: error previous command is pending (0:4) ...
[ 76.690000] tango2_bmide: fail to setup dma, fallback to pio
[ 76.700000] MBUS: error previous command is pending (0:4) ...
[ 76.710000] tango2_bmide: fail to setup dma, fallback to pio
[ 76.740000] MBUS: error previous command is pending (0:4) ...
[ 76.740000] tango2_bmide: fail to setup dma, fallback to pio
[ 78.940000] MBUS: error previous command is pending (0:4) ...
[ 78.940000] tango2_bmide: fail to setup dma, fallback to pio
[ 78.980000] MBUS: error previous command is pending (0:4) ...
[ 78.980000] tango2_bmide: fail to setup dma, fallback to pio
[ 79.020000] MBUS: error previous command is pending (0:4) ...
[ 79.030000] tango2_bmide: fail to setup dma, fallback to pio
[ 79.060000] MBUS: error previous command is pending (0:4) ...
[ 79.090000] tango2_bmide: fail to setup dma, fallback to pio
[ 79.210000] MBUS: error previous command is pending (0:4) ...
[ 79.210000] tango2_bmide: fail to setup dma, fallback to pio
[ 79.250000] MBUS: error previous command is pending (0:4) ...
[ 79.250000] tango2_bmide: fail to setup dma, fallback to pio
[ 81.210000] SMP863x: AUDIO SET_MIXER
[ 81.220000] SMP863x: AUDIO SET_MIXER
[ 81.820000] cx24116_initfe: FW version 1.22.82.0
[ 81.920000] SMP863x: Source: fe[0] demux[0] ?
[ 84.050000] SMP863x: AUDIO PAUSE
[ 84.050000] SMP863x: AUDIO PLAY
[ 84.060000] SMP863x: VIDEO SELECT SOURCE: DEMUX
[ 84.070000] SMP863x: VIDEO_GET_SIZE
[ 84.070000] SMP863x: VIDEO_SET_STREAMTYPE (0)
[ 84.080000] SMP863x: VIDEO_PLAY
[ 84.090000] SMP863x: VIDEO SLOWMOTION 0
[ 84.090000] SMP863x: VIDEO FAST FORWARD 0
[ 84.100000] SMP863x: VIDEO_CONTINUE
[ 84.100000] SMP863x: AUDIO CONTINUE
[ 84.110000] SMP863x: bP[1]bA[1]bV[1]bPS[0]bAS[0]bVS[0]id[0]s[0]k[ (null)]bP[0]
[ 84.120000] SMP863x: init [A|V|P][VCXO]
[ 84.530000] SMP863x: VIDEO SLOWMOTION 0
[ 84.540000] SMP863x: VIDEO FAST FORWARD 0
[ 84.540000] SMP863x: VIDEO_CONTINUE
[ 84.550000] SMP863x: AUDIO CONTINUE
[ 84.560000] SMP863x: bP[0]bA[0]bV[0]bPS[0]bAS[0]bVS[0]id[0]s[0]k[ (null)]bP[0]
[ 84.560000] SMP863x: Ignore call
[ 84.650000] SMP863x-CA: CSA New decoding 0 , demux id 0...
[ 84.660000] SMP863x-CA: <PID ALLREADY STARTED> index = 0 pid 0x141
[ 84.670000] SMP863x-CA: <PID ALLREADY STARTED> index = 0 pid 0x192
[ 84.680000] SMP863x-CA: <PID ON WAIT> index = 0 pid 0x193
[ 84.910000] MBUS: error previous command is pending (0:4) ...
[ 84.910000] tango2_bmide: fail to setup dma, fallback to pio
[ 84.960000] MBUS: error previous command is pending (0:4) ...
[ 84.970000] tango2_bmide: fail to setup dma, fallback to pio
[ 85.020000] MBUS: error previous command is pending (0:4) ...
[ 85.030000] tango2_bmide: fail to setup dma, fallback to pio
[ 85.170000] SMP863x: SatEnableChannel
[ 85.350000] SMP863x: start channel->kVcxoRegulate
[ 111.240000] MBUS: error previous command is pending (0:4) ...
[ 111.240000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.290000] MBUS: error previous command is pending (0:4) ...
[ 111.290000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.300000] MBUS: error previous command is pending (0:4) ...
[ 111.310000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.360000] MBUS: error previous command is pending (0:4) ...
[ 111.360000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.380000] MBUS: error previous command is pending (0:4) ...
[ 111.390000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.420000] MBUS: error previous command is pending (0:4) ...
[ 111.420000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.450000] MBUS: error previous command is pending (0:4) ...
[ 111.460000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.480000] MBUS: error previous command is pending (0:4) ...
[ 111.490000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.500000] MBUS: error previous command is pending (0:4) ...
[ 111.510000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.530000] MBUS: error previous command is pending (0:4) ...
[ 111.530000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.550000] MBUS: error previous command is pending (0:4) ...
[ 111.560000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.580000] MBUS: error previous command is pending (0:4) ...
[ 111.580000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.610000] MBUS: error previous command is pending (0:4) ...
[ 111.620000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.660000] MBUS: error previous command is pending (0:4) ...
[ 111.660000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.690000] MBUS: error previous command is pending (0:4) ...
[ 111.700000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.750000] MBUS: error previous command is pending (0:4) ...
[ 111.750000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.790000] MBUS: error previous command is pending (0:4) ...
[ 111.800000] tango2_bmide: fail to setup dma, fallback to pio
[ 111.820000] MBUS: error previous command is pending (0:4) ...
[ 111.830000] tango2_bmide: fail to setup dma, fallback to pio
[ 121.390000] MBUS: error previous command is pending (0:4) ...
[ 129.030000] MBUS: error previous command is pending (0:4) ...
[ 129.030000] tango2_bmide: fail to setup dma, fallback to pio
[ 129.100000] MBUS: error previous command is pending (0:4) ...
[ 129.100000] tango2_bmide: fail to setup dma, fallback to pio
[ 129.170000] MBUS: error previous command is pending (0:4) ...
[ 129.170000] tango2_bmide: fail to setup dma, fallback to pio
[ 130.290000] SMP863x-CA: <PID REMOVING ACTIVE> index = -1 pid 0x141
[ 130.300000] SMP863x-CA: <PID REMOVING ACTIVE> index = -1 pid 0x192
[ 130.320000] SMP863x-CA: <PID REMOVING> index = -1 pid 0x193
[ 130.340000] SMP863x-CA: CSA Removing decoding 0, demux id 0 ...
[ 130.380000] SMP863x: VIDEO_STOP
[ 130.380000] SMP863x: AUDIO STOP
[ 130.390000] SMP863x: AUDIO CONTINUE
[ 130.390000] SMP863x: bP[0]bA[0]bV[0]bPS[1]bAS[1]bVS[1]id[0]s[0]k[9553f5e0]bP[0]
[ 130.400000] SMP863x: ending [A|V|P][VCXO]
[ 130.530000] SMP863x: end kVcxoRegulate
[ 130.710000] SMP863x: AUDIO PAUSE
[ 130.720000] SMP863x: AUDIO PLAY
[ 130.720000] SMP863x: VIDEO SELECT SOURCE: DEMUX
[ 130.730000] SMP863x: VIDEO_SET_STREAMTYPE (0)
[ 130.740000] SMP863x: VIDEO_PLAY
[ 130.750000] SMP863x: VIDEO SLOWMOTION 0
[ 130.750000] SMP863x: VIDEO FAST FORWARD 0
[ 130.760000] SMP863x: VIDEO_CONTINUE
[ 130.770000] SMP863x: AUDIO CONTINUE
[ 130.770000] SMP863x: bP[1]bA[1]bV[1]bPS[0]bAS[0]bVS[0]id[0]s[0]k[ (null)]bP[0]
[ 130.780000] SMP863x: init [A|V|P][VCXO]
[ 130.840000] SMP863x: VIDEO_GET_SIZE
[ 131.470000] SMP863x: VIDEO SLOWMOTION 0
[ 131.470000] SMP863x: VIDEO FAST FORWARD 0
[ 131.490000] SMP863x: VIDEO_CONTINUE
[ 131.490000] SMP863x: AUDIO CONTINUE
[ 131.490000] SMP863x: bP[0]bA[0]bV[0]bPS[0]bAS[0]bVS[0]id[0]s[0]k[ (null)]bP[0]
[ 131.520000] SMP863x: Ignore call
[ 131.670000] SMP863x-CA: CSA New decoding 0 , demux id 0...
[ 131.670000] SMP863x-CA: <PID ALLREADY STARTED> index = 0 pid 0x145
[ 131.680000] SMP863x-CA: <PID ALLREADY STARTED> index = 0 pid 0x19a
[ 132.240000] SMP863x: SatEnableChannel
[ 132.410000] SMP863x: start channel->kVcxoRegulate
[ 163.530000] MBUS: error previous command is pending (0:4) ...
[ 163.530000] tango2_bmide: fail to setup dma, fallback to pio
[ 163.550000] MBUS: error previous command is pending (0:4) ...
[ 163.560000] tango2_bmide: fail to setup dma, fallback to pio
[ 227.020000] MBUS: error previous command is pending (0:4) ...
[ 227.020000] tango2_bmide: fail to setup dma, fallback to pio
[ 227.030000] MBUS: error previous command is pending (0:4) ...
[ 227.040000] tango2_bmide: fail to setup dma, fallback to pio
[ 227.050000] MBUS: error previous command is pending (0:4) ...
[ 227.060000] tango2_bmide: fail to setup dma, fallback to pio
root@azboxhd:~#
