gavr-aleksandr
Подскажите пожалуйста, как в PB-VX-BETA-3.3.0-Azboxhd-2011-10-24 изменить путь для записи, т.е. куда сохранять записанные передачи. По умолчанию пишет в media/hdd/movie
Разобрался сам. Может кому пригодится - стоит скин hdglass - в главном меню - настройка - система несколько пунктов объединены на одном правом нижнем значке. В том числе и пункт "Recording Path". Там все и нашлось
allllex
Очередное обновление:
PB-Powerboard Enigma II VX für Azboxhd Release 2011-12-05
For our english spoken community:
Beside the known things, we created the possibility to install camd manually.
During the process of installing oscam, you can now choose to let it act as a standalone camd or alongside another camd (e.g. CCcam).
Copy the cam-binary to /tmp/camdinstall. Goto pb-center and use the camdinstaller to install it.
An example for oscam-CCcam:
Install CCcam via Addonbrowser. Copy the oscam-binary to /tmp/camdinstall. Goto pb-center and use the camdinstaller to install it "add oscam to other cam". Now you can choose this combination in the cam-manager.
Skins and plugins can be installed onto a USB device. Please, do not use a device with moving parts, i.e.an USB HDD. Therefore you have to put the cursor on the device and push menu-button in the device-manager.
If a larger DOM is installed, it can be used for "outsourcing" too in the same way. You only have to choose the DOM and push the menu-button.
NFS-Server and Samba-Server could be installed by the Addon-Browser.
The "fstab-bug" is not solved until now - it is part of a driver, so we have no method to fix it.
So - after one ore more reboot - you have to put the fstab provided in the image-packet to /etc onto the box, reboot and mount the devices with the devicemanager in the pb-center
Important: Flashing is defenitly necessary !!!!
http://anonym.to/?http://www.pb-download.com/images/PB-VX-AZBOXHD-20111204.tar.gz
