vom 08.09.2009
new structural and constructive!
var/etc is mounted on boot after /etc. rw in it and everything is so can be processed!
now are 4 partitions: kernel root usr var
var usr + rw are thus freely editable!
is nich complete usr / usr instead, usr/lib/eniga2/python all of which contain important what one wants to change or supplement to hire ma! However, as always, with all applicable:
paperboard moving up too full or it might burst and not boot Thereby. always with df-h and see how much space is still available and always a free pad of mind 150kb left (must have e2 !!!).
flash is easy:
stick with fat32 format
to create folder:
/ kathrein/ufs922
therein save the *. img and updatescript.sh
ufs922 off
stick forward purely
Switch
Record button (left button under frontusb) gedrьckhalten until something like this ... "utp2" appears in the display
then briefly stop button (right button on frontusb) press.
and re-flashing
Total duration approximately 10 minutes,
anything more about this in the enclosed readme!
swapram has been disabled because of a technical error exists in ufs922.
It is therefore recommended swappart or swapfile to use (default: swapoff)
with default swapoff is no teletext, ts, record!
Just for swapfile on the media partition to create a folder named: swap to put swapfile on, off, on, done. telnet: Free should now show when swap not 0 more!
epg for saving to hdd there a folder: epg create and put it on usb / hdd epg save the setup!
for the record, ts, etc., as usual folder on the media partition (sda5 create):
mp3
Record
pictures
timeshift
own_movies
epg
swap
more infos about this gives you the var / etc / automount.ini
as the orig mediapartiton only has 10gb is little space for recording and mp3.
It is recommended the ENTIRE hdd partitonieren re using fdisk (in e2), and format to include all newly created partitions to ext2.
fdisk is self-kan, and you can format as follows:
mkfs.ext2-L XSYS1 / dev/sda1
mkfs.ext2-L XSYS2 / dev/sda2
mkfs.ext2-L XSYS3 / dev/sda3
mkswap / dev/sda4
-L is the label name that defines how the hdd to mount by label in parts of mnt / usb appears. they are freely chosen but must be identsich nich!
one uses ne swappart (sda4 in the example) you can then also on swappart in evo-setup ask.
shall be the timeshift hdd so new to it there as described above, the folder, epg, record, swap .... Create
mtd aufteilung the newly revised (smaller kernel, root a little smaller, and less for the same size as var usr added)
in the kernel are now NOT longer included but can be recharged via osd module as:
cifs, fuse, smb, ntfs (rw will not read properly but stable!)), pl2303, ftdi, usbserial, nfsd ...
PLEASE READ BEFORE FLASHING BACKUP YOUR ORIGINAL! HOW IS THE IS THE BACK_TO_ORIG.TXT FLASH FROM THE PACKAGE!!
will again be back to orig then this is also possible in the same way!
back_to_orig.txt as your insurance will make use of flash stick, new updatescript.sh. completed (just read the description in txt exactly!)
Many many thanks to TDT for the base image
riesendankeschцn solala to create one for the update script
a fat thx to obiwan, nit, max for the support for the Realization of the flash images and test it!
