Внутренний SATA HDD в Kathrein UFS 910
kedr-0
Пытаюсь подключить СF kart SATA адаптер и ничего не получается
лог гипер терминала:SMSC: <--Smsc911x_init(), result=0
SMSC: Interface Name = "eth0"
SMSC: <-- init_module()
nwhw_config: device not found
ata1: SATA max UDMA/133 cmd 0xB9209000 ctl 0xB9209820 bmdma 0x0 irq 170
ata1: SATA link up 1.5 Gbps (SStatus 113)
ata1: PIO error
ata1: dev 0 failed to IDENTIFY (I/O error)
scsi0 : sata_stm
Generic ST boards onboard flash device: 0x01000000 (16.0Mb) at 0x00000000
Onboard_Flash: Found 1 x16 devices at 0x0 in 16-bit bank
Onboard_Flash: Found 1 x16 devices at 0x800000 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Onboard_Flash: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 2
CF :ultron
а вот с енигмой на усб савсем не стартует лог :
Verifying Checksum ... OK
Uncompressing Standalone Application ... OK
selected Image to start: ----Flash----
selected Image to start: ----USB-1----
selected Image to start: ----USB-2----
loading from usb 0:3
1563735 bytes read
## Booting image at a5000000 ...
Starting kernel console=ttyAS0,115200 root=/dev/sda3 rw ip=192.168.178.28:192.16
8.178.29:192.168.178.1:255.255.255.0:kathrein:eth0:eek:ff mem=64m coprocessor_mem=4
m@0x10000000,4m@0x10400000 rootdelay=6 nwhwconf=device:eth0,hwaddr:00:1D:EC:00:F
7:3A init=/bin/devinit - 0x00000000 - 0 ...
