NEU V10920 : OCTAGON SF1018 HD ALLIANCE V10920 от 17.06.11
- Upgrades & Imporvements :
--> Plugin is capable to download from one's web server
--> Menü - Utilities - Plugin : Blue Button - Download
--> Server URL : Menu - Installation - Network Setting : Firmware upgrade Server
--> Multipicture mosaic funtion bug : Amended (Blue Button)
--> Blind Scan search wrong : Amended
--> Duplicated channel or other bugs in Blind scan : Solved
--> Sky portal CH problem : Solved
--> Hang-up when make 10 min pause during playback rec file : Solved
--> EPG Daily Recording Bug : Solved
--> Working Screen saver during Radio service playback : Solved
--> Can not delete specific Rec file Bug(file name include / or special character) : Solve
--> Unstable Signal Quality : Solved
--> Background black issue in the info Banner's event name : Solved
--> Recording name saved as previous event name in event scheduled recording : Solved
--> Hang-up issue after Factory reset : Solved
--> Hang-up by Data Transfer Menu : Solved
--> When changing service up/down, loop supported in one tuner : Supported
--> Logical channel number (LCN) function off : Amended
--> Audio click noise : Solved
--> Lost descramble in Recording of the specific channel : Solved
--> Can not Recording in Service nemed in Turkish : Solved
--> Service find option in Service list manager : Added (Yellow Button)
--> Menu display spilit or broken : Solved
--> Screen Turns into Black&White in Resolution change mode : Solved
--> Flickering and spot in the screen with Scart in Resolution change mode : Solved
Online SW Update : octagon-germany.de
Online Plugin & SW upgrade : octagon-forum.com/develop
