Cvovacom, Попробуйте мои настройки:
# EMM messages
# 00 don't show any EMMs (default)
# 01 show only valid EMMs
# 02 show valid and bad EMMs with complete data display
M: { 01 }
# ECM messages
# 00 don't show anything about ecm
# 01 normal mode, show pids processed, decoded ecm and cw
# 02 verbose mode, show valid and bad ECMs with data
C: { 01 }
# AU
# 00 disable, no emm pids processed
# 01 enable, emm pids always processed for soft-au and shared cards
# 02 auto, emm started only if channel cant be decoded
# 03 process emm pids for network cards update only
A: { 00 }
# key update (sum 01 or 02 with 04)
# 01 update only new keys, default setting
# 02 update all keys (used for valid PMK checking)
# 04 enable TPS au
# + tps SID, which pmt pid contains au pid
U: { 01 }
# config files folder (softcam, autoroll, ignore/priority)
# 00 files in /var/keys
# 01 files in /tmp
T: { 00 }
# network mode, use summ for several clients
# 00 no network (default)
# 01 newcamd netclient
# 02 radegast netclient
# 04 camd3 netclient
# 08 gbox netclient
# 32 cccamd netclient, card list saved as /tmp/cccamd.info
# (ECM only, supported server version up to 2.1.1, later not work)
G: { 01 }
# network retry, use summ for several options
# 00 disable
# 01 retry every new ecm
# 02 try to connect to offline shares every Q: seconds
# 04 try to detect and fast reconnect to lost (and not used atm) server
# + XX messages number and YY seconds to reconnect
# mg will reconnect to server, if no answer to last XX ecm/keepalive or
# if no answer for last ecm or keepalive sent for YY seconds
# set to 0 to disable
N: { 01 } 5 30
# network ecm timeout in seconds
K: { 07 }
# newcamd dead routes connect retry, sec
Q: { 150 }
# network shares priority
# 00 gbox, newcamd, cccamd, radegast, camd3 (default)
# 01 camd3, radegast, cccamd, gbox, newcamd
# 02 cccamd, newcamd, camd3, gbox, radegast
P: { 02 }
# on screen display type
# 00 No OSD (default)
# 01 neutrino
# 02 enigma
# 03 relook
# + user password for http auth
O: { 00 } username password
# on screen display Options, summ of:
# 01 show emu ecm
# 02 show network shares messages
# 04 show decoding failed / fta
# 08 show emm keys update
# + web port to use for osd
S: { 03 } 80
# Log option, summ of:
# 00 off
# 01 network udp log
# 02 log to console
# 04 file, appended ! delete it by yourself, before it eat all your hdd
# + IP udp-port log-file-name
L: { 01 } 172.16.1.1 28007 /tmp/mgcamd.log
# keep ecm cache, seconds
# every cache entry takes 28 bytes, so 24h cache will take *only* 240-400kb of memory,
# for openbox/elanvision users with remote shares make sense to set it higher than default value,
# to not hammer cards while timeshifting or playing crypted recordings.
E: { 00 }
# cache option, summ of:
# 00 Off (default)
# 01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
# 02 Ecm data cache, remember CW for (E
time
# 04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
H: { 07 }
# reread files, summ of:
# 00 No (default)
# 01 reread config file on channel change (including priority and ignore, but not replace/cache)
# 02 reread SoftCam.Key on channel change
# 04 reread SoftCam.Key if file changed
R: { 00 }
# debug, summ of
# 00 off (default)
# 01 debug ecm
# 02 debug emm
# 04 debug network ecm
# 08 debug network emm
# 16 debug network login
# 32 show mem/cpu stats every 1 min
# 64 add timestamp to log messages
D: { 04 }
# box type
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
# 06 dreambox/mips
# 08 stapi/kathrein
# 09 stapi/ipbox
# 11 stapi/openbox
B: { 11 }
# map all 180x nagra caids to 1801
# default is 01
F: { 00 }
priority list
S: { 00 68 }
X: { 18 03 }
X: { 01 00 }
#NTV+ ETELSAT 36.0?E
V: { 04 06 00 }
V: { 03 06 00 } #[font color="Red"]????????? ??? ??? ? ???? ???????? c HD!!![/font],
V: { 040600 } #���+ SD
V: { 050B00} #���+ HD
#????????? HB 13.0?E
V: { 03 25 00 } #Private Spice
V: { 04 17 00 } #Red Hot Sex
V: { 04 27 00 } #Satisfaction
V: { 04 38 00 } #Redlight HD
#RTVi HB 13.0?E
V: { 04 23 00 }
#AL Jazeera Sport HB 13.0?E
V: { 04 24 00 }
#Bis TV HB 13.0?E
V: { 04 28 00 }
#SRG SSR HB 13.0?E
V: { 02 38 00 }
#Nova HB 13.0?E
I: { 00 14 }
I: { 00 5a } #Private
I: { 00 5b } #Playboy
#Cyfra+ HB 13.0?E
S: { 00 00 68 }
#Cyfrowy Polsat HB 13.0?E
X: { 18 03 }
#Sky Italay HB 13.0?E
X: { 09 cd }
#VIASAT(NDS) SIRIUS 5.0?E
X: { 09 0f }
X: { 09 3e }
#TRK UKR+Futbol 5.0?E
V: { 02 31 00 }
V: { 02 47 00 }
#Akta Satelit 5.0?E
V: { 02 4f 00 }
ignore list
# ignore seca providers
S: { 00 65 }
X: { 18 01 }
G: { 01000065 }
G: { 18007001 }
G: { 18007101 }
#ignore viaccess providers
V: { 000000 }
V: { 050A00 }
V: { 030600 }
V: { 050100 }
V: { 040620 }
V: { 040610 }
V: { 042740 }
V: { 02 37 00}
V: { 04 06 10}
V: { 04 06 20}
V: { 05 01 00}
V: { 00 80 00}
V: { 04 21 00}
X: { 4A E0 }
# ignore irdeto providers
I: { 2e 9a }
I: { EF F8 }
I: { EF EC }
I: { EF EA }
I: { 00 13 }
I: { EF E2 }
I: { EF DC }
I: { EF DA }
I: { EF D8 }
I: { EF F6 }
I: { 00 06 }
I: { EF F4 }
I: { 0000 }
I: { 0002 } #Bulsatcom 39E
I: { 0003 } #Bulsatcom 39E
I: { 0004 } #Bulsatcom 39E
I: { 0005 }
I: { 0006 } #Bulsatcom 39E
I: { 0007 }
I: { 0008 }
I: { 0009 }
I: { 000A }
I: { 000C }
I: { 000D }
I: { 000E } #Bulsatcom 39E
I: { 000F }
I: { 0010 }
I: { 0011 }
I: { 0012 }
I: { 0013 }
I: { 0037 }
I: { 0070 }
I: { 0071 }
I: { 0072 }
I: { 0073 }
I: { 0074 }
I: { 0075 }
I: { 0076 }
I: { 0079 }
Работает без проблем.Они несколько отличаются от Ваших.!good!
