<?xml version="1.0" encoding="utf-8"?>
<openpli>
<enigma2>
<crashdate>Sat Jan 1 01:13:59 2000</crashdate>
<compiledate>May 7 2012</compiledate>
<contactemail>somebody who cares</contactemail>
<!-- Please email this crashlog to above address -->
<skin>skin.xml</skin>
<sourcedate>2012-03-17</sourcedate>
<branch>(no branch)</branch>
<rev>945aeb9</rev>
<version>3.0.0</version>
</enigma2>
<image>
<stbmodel>octagon1008</stbmodel>
<kernelversion>
<![CDATA[
Linux octagon1008 2.6.32.57_stm24_0210 #1 PREEMPT Mon May 7 20:50:57 CEST 2012 sh4 GNU/Linux
</kernelversion>
<kernelcmdline>console=ttyAS1,115200 root=/dev/sda2 rw mem=128m ip=192.168.1.165:192.168.1.107:192.168.0.20:255.255.255.0:AT700:eth0
ff coprocessor_mem=4m@0x10000000,4m@0x10400000 rootdelay=5 nwhwconf=device:eth0,hwaddr:00:1E:B8:01:0B:69 init=/bin/devinit</kernelcmdline>
<nimsockets>NIM Socket 0:</nimsockets>
<imageversion>
<![CDATA[
version=0350200905300000
</imageversion>
<imageissue>
<!-- No such file or directory -->
</imageissue>
</image>
<crashlogs>
<enigma2crashlog>
<![CDATA[
+ (1) Background File Eraser
+ (5) Tuxtxt
+ (8) graphics acceleration manager
STMFB accel interface available
+ (9) GFBDC
12288k total video mem
4188k usable video mem
2568kB available for acceleration surfaces.
resolution: 720 x 576 x 32 (stride: 2880)
+ (9) gLCDDC
eDBoxLCD::eDBoxLCD >
config -> (w 320, h 240)
lcd buffer 0x2a92e008 153600 bytes, stride 640
eDBoxLCD::eDBoxLCD (w 320, h 240, depth 16)<
+ (9) Font Render Class
[FONT] initializing lib...
[FONT] loading fonts...
[FONT] Intializing font cache, using max. 4MB...
+ (10) gRC
RC thread created successfully
+ (15) eWindowStyleManager
+ (20) DVB-CI UI
eDVBCI_UI >
eDVBCI_UI <
+ (20) UHF Modulator
couldnt open /dev/rfmod0!!!!
+ (20) RC Input layer
+ (20) misc options
+ (20) AVSwitch Driver
couldnt open /dev/dbox/fp0 to monitor vcr scart slow blanking changed!
+ (21) input device driver
Input device "TDT RC event driver" is a remotecontrol
failed to open /dev/input/event1
Input device "" is a mouse
failed to open /dev/input/event2
Input device "" is a remotecontrol
failed to open /dev/input/event3
Input device "" is a keyboard
Found 4 input devices!
+ (22) Hdmi CEC driver
+ (30) eActionMap
+ (35) CI Slots
scanning for common interfaces..
CI Slot 0: reset requested
deleteSessions >
deleteSessions <
CI Slot 1: reset requested
deleteSessions >
deleteSessions <
stat on /dev/dvb/adapter0/ci2 failed
CI Slot 0 setSource(0)
CI Slot 1 setSource(0)
eDVBCIInterfaces->setInputSource(0, 0)
eDVBCIInterfaces->setInputSource(1, 1)
cannot open /proc/stb/tsmux/input2
cannot open /proc/stb/tsmux/input3
done, found 2 common interface slots
+ (35) CA handler
+ (36) Stream server
[SERVERSOCKET] ERROR on bind() (Address already in use)
+ (40) eServiceCenter
settings instance.
+ (41) eServiceFactoryDVD
+ (41) eServiceFactoryM2TS
+ (41) eServiceFactoryMP3
+ (41) eServiceFactoryFS
+ (41) eServiceFactoryDVB
reached rl 70
---- opening lame channel db
reading services (version 4)
loaded 6818 services
scanning for frontends..
opening frontend 0
detected satellite frontend
close frontend 0
found 1 adapter, 1 frontends(1 sim) and 2 demux, boxtype 20
RTC not ready... wait for transponder time
[EPGC] Initialized EPGCache (wait for setCacheFile call now)
Loading spinners...
found 4 spinner!
setIoPrio best-effort level 3 ok
main thread is non-idle! display spinner!
couldn't open fp
[Harddisk] enumerating block devices...
new Harddisk sda -> /dev/sda -> /dev/sda
[ePopen] command: ('sdparm', 'sdparm', '--set=SCT=0', '/dev/sda')
Reading satellites.xml
sec config cleared
setSlotInfo for dvb frontend 0 to slotid 0, descr Availink AVL2108 DVB-S2, need rotorworkaround No, enabled Yes, DVB-S2 Yes
slot: 0 configmode: advanced
add 90 to 1
add 360 to 2
sec config completed
[InfoBar] Failed to load resumepoints: [Errno 2] No such file or directory: '/home/root/resumepoints.pkl'
loading bouquet... /etc/enigma2/bouquets.tv
loading bouquet... /etc/enigma2/userbouquet.ntv___tv_.tv
181 entries in Bouquet userbouquet.ntv___tv_.tv
loading bouquet... /etc/enigma2/userbouquet.ntv__hd__tv_.tv
16 entries in Bouquet userbouquet.ntv__hd__tv_.tv
loading bouquet... /etc/enigma2/userbouquet.platforma_hd__tv_.tv
13 entries in Bouquet userbouquet.platforma_hd__tv_.tv
loading bouquet... /etc/enigma2/userbouquet.___trikolor_hd__.tv
17 entries in Bouquet userbouquet.___trikolor_hd__.tv
loading bouquet... /etc/enigma2/userbouquet.platforma_cd.tv
24 entries in Bouquet userbouquet.platforma_cd.tv
loading bouquet... /etc/enigma2/userbouquet.trikolor.tv
160 entries in Bouquet userbouquet.trikolor.tv
loading bouquet... /etc/enigma2/userbouquet._eutelsat_9a__9_0e__.tv
33 entries in Bouquet userbouquet._eutelsat_9a__9_0e__.tv
loading bouquet... /etc/enigma2/userbouquet._eutelsat_36a_36b__36_0e__.tv
8 entries in Bouquet userbouquet._eutelsat_36a_36b__36_0e__.tv
loading bouquet... /etc/enigma2/userbouquet.favourites.tv
0 entries in Bouquet userbouquet.favourites.tv
9 entries in Bouquet bouquets.tv
loading bouquet... /etc/enigma2/bouquets.radio
loading bouquet... /etc/enigma2/userbouquet.favourites.radio
0 entries in Bouquet userbouquet.favourites.radio
1 entries in Bouquet bouquets.radio
[eDVBLocalTimeHandler] enable sync local time with transponder time!
add dreampackage scanner plugin
added
[FONT] adding font /usr/local/share/fonts/nmsbd.ttf...OK (Regular)
[FONT] adding font /usr/local/share/fonts/andale.ttf...OK (Fixed)
[FONT] adding font /usr/local/share/fonts/tuxtxt.ttf...OK (Console)
[FONT] adding font /usr/local/share/fonts/ae_AlMateen.ttf...OK (Replacement)
[FONT] adding font /usr/local/share/fonts/time.ttf...OK (BMCTime)
588kB available for acceleration surfaces.
resolution: 1280 x 720 x 32 (stride: 5120)
[FONT] adding font /usr/local/share/enigma2/Concinnity0816/fonts/lcd.ttf...OK (LCD)
[FONT] adding font /usr/local/share/enigma2/Concinnity0816/fonts/ae_AlMateen.ttf...OK (Replacement)
[FONT] adding font /usr/local/share/enigma2/Concinnity0816/fonts/tuxtxt.ttf...OK (Console)
[FONT] adding font /usr/local/share/enigma2/Concinnity0816/fonts/nmsbd.ttf...OK (Regular)
[FONT] adding font /usr/local/share/enigma2/Concinnity0816/fonts/nmsbd.ttf...OK (Arial)
[FONT] adding font /usr/local/share/fonts/valis_enigma.ttf...OK (Subs)
[FONT] adding font /usr/local/share/fonts/nmsbd.ttf...OK (FdLcD)
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 25] Inappropriate ioctl for device >
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 19] No such device: '/dev/input/event3' >
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 19] No such device: '/dev/input/mouse3' >
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 19] No such device: '/dev/input/js3' >
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 19] No such device: '/dev/input/event2' >
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 19] No such device: '/dev/input/mouse2' >
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 19] No such device: '/dev/input/js2' >
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 19] No such device: '/dev/input/event1' >
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 19] No such device: '/dev/input/mouse1' >
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 19] No such device: '/dev/input/js1' >
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 22] Invalid argument >
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 19] No such device: '/dev/input/mouse0' >
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 19] No such device: '/dev/input/js0' >
Selected keymap does not exist!
Activating language Русский
[SETTING] getFlushSize= 0
[ePopen] command: ip -o addr show dev eth0
eDBoxLCD::getInstance
eDBoxLCD::setLCDBrightness
eDBoxLCD::setInverted
--> applying pep values
couldn't apply pep values.
[NetworkBrowser] set language to ru
LINE # automatically generated by enigma 2
LINE
[AutoMount.py] self.automounts without mounts {}
[NetworkBrowser] fallback to default translation for NetworkBrowser
[NetworkBrowser] fallback to default translation for Search for network shares
[NetworkBrowser] fallback to default translation for MountManager
[NetworkBrowser] fallback to default translation for Manage network shares
getModeList for port Component
getModeList for port Scart
getModeList for port HDMI
getModeList for port HDMI-PC
hotplug on dvi
-> setting aspect, policy, policy2, wss 16:9 panscan letterbox auto
setMode - port: HDMI mode: 1080i rate: 50Hz
updateColor: HDMI
loadSkin: Screen already defined elsewhere: HDMU_MainMenu
loadSkin: Screen already defined elsewhere: HDMU_SoftcamControl
loadSkin: Screen already defined elsewhere: HDMU_OverclockControl
/usr/lib/python2.6/site-packages/twisted/spread/pb.py:30: DeprecationWarning: the md5 module is deprecated; use hashlib instead
/usr/lib/python2.6/site-packages/twisted/python/filepath.py:12: DeprecationWarning: the sha module is deprecated; use the hashlib module instead
loadSkin: Screen already defined elsewhere: DMC_MainMenu
loadSkin: Screen already defined elsewhere: MC_Settings
loadSkin: Screen already defined elsewhere: MC_FavoriteFolders
loadSkin: Screen already defined elsewhere: MC_AudioPlayer
loadSkin: Screen already defined elsewhere: MC_AudioPlaylist
loadSkin: Screen already defined elsewhere: AudioPlayerSettings
loadSkin: Screen already defined elsewhere: Lyrics
loadSkin: Screen already defined elsewhere: MC_WebRadio
loadSkin: Screen already defined elsewhere: MC_WebDown
loadSkin: Screen already defined elsewhere: MC_VideoPlayer
loadSkin: Screen already defined elsewhere: BonkelPlayer
loadSkin: Screen already defined elsewhere: MC_PictureViewer
loadSkin: Screen already defined elsewhere: MC_PicSetup
loadSkin: Screen already defined elsewhere: MC_VLCServerlist
loadSkin: Screen already defined elsewhere: MC_VLCMedialist
loadSkin: Screen already defined elsewhere: MC_VLCFavoriteFolders
loadSkin: Screen already defined elsewhere: MC_WeatherInfo
loadSkin: Screen already defined elsewhere: WeatherSetup
Media Center: Import VLC Stuff failed
[eSocketMMIHandler] created successfully
Plugin Extensions/WebInterface failed to load: No module named plugin
Plugin probably removed, but not cleanly in /usr/lib/enigma2/python/Plugins/Extensions/WebInterface
starting hotplug handler
adding Resource DiseqcTester
resources: {'DiseqcTester': <function DiseqcTesterMain at 0x118eaac>}
[EPGC] setCacheFile read/write epg data from/to '/hdd/epg.dat'
not showing fine-tuning wizard, config variable doesn't exist
showtestcard is false
[SKIN] Parsing embedded skin <embedded-in-'Dummy'>
setValue 50
Setvolume: 50 50 (raw)
Setvolume: 32 32 (-1db)
[SKIN] No skin to read...
[Skin] SKIN ERROR in screen 'ChannelSelection' widget 'widget': {skin.xml}: component with name 'boquet' was not found in skin of screen 'ChannelSelection'!. Please contact the skin's author!
[Skin] SKIN ERROR in ChannelSelection: No module named SingleEpgList
warning, skin is missing element key_yellow in <class 'Screens.ChannelSelection.ChannelSelection'>
warning, skin is missing element key_blue in <class 'Screens.ChannelSelection.ChannelSelection'>
warning, skin is missing element key_green in <class 'Screens.ChannelSelection.ChannelSelection'>
warning, skin is missing element key_red in <class 'Screens.ChannelSelection.ChannelSelection'>
warning, skin is missing element UnhandledKeyPixmap in <class 'Screens.UnhandledKey.UnhandledKey'>
warning, skin is missing element From in <class 'Screens.Dish.Dish'>
warning, skin is missing element Goto in <class 'Screens.Dish.Dish'>
warning, skin is missing element posGoto in <class 'Screens.Dish.Dish'>
warning, skin is missing element posFrom in <class 'Screens.Dish.Dish'>
warning, skin is missing element turnTime in <class 'Screens.Dish.Dish'>
RemovePopup, id = ZapError
[Picon] adding path: /usr/share/enigma2/picon/
child has terminated
pipes closed
[ePopen] command: route -n | grep eth0
pipes closed
poll: unhandled POLLERR/HUP/NVAL for fd 30(16)
poll: unhandled POLLERR/HUP/NVAL for fd 32(17)
pipes closed
192.168
0.0.0.0
nameservers: [[192, 168, 1, 20]]
read configured interface: {'lo': {'dhcp': False}, 'eth0': {'dhcp': True}}
self.ifaces after loading: {'eth0': {'preup': False, 'predown': False, 'ip': [192, 168, 1, 165], 'up': True, 'mac': '00:1e:b8:01:0b:69', 'dhcp': True, 'bcast': [192, 168, 1, 255], 'netmask': [255, 255, 255, 0], 'gateway': [192, 168, 1, 20]}}
[OpenWebif] loading external plugins...
[OpenWebif] no plugins to load
[OpenWebif] started on 80
poll: unhandled POLLERR/HUP/NVAL for fd 34(16)
action -> InfobarChannelSelection switchChannelDown
action -> OkCancelActions ok
action -> OkCancelActions cancel
action -> InfobarMenuActions mainMenu
loading mainmenu XML...
TimerEdit TimerEditList
PluginBrowser PluginBrowser
action -> DirectionActions downUp
okbuttonClick
ParentalControlSetup ParentalControlSetup
okbuttonClick
NetworkSetup NetworkAdapterSelection
InputDeviceSetup InputDeviceSelection
RecordPaths RecordPathsSettings
LanguageSelection LanguageSelection
no Service found
okbuttonClick
Satconfig NimSelection
ScanSetup ScanSimple
ScanSetup ScanSetup
okbuttonClick
Creating setup
action -> SetupActions left
unknown action SetupActions/left! typo in keymap?
Creating setup
action -> SetupActions ok
sec config cleared
slot: 0 configmode: simple
diseqcmode: diseqc_a_b_c_d
playing None
getResolvedKey config.plugins.crashlogautosubmit.sendAnonCrashlog failed !! (Typo??)
getResolvedKey config.plugins.crashlogautosubmit.addNetwork failed !! (Typo??)
getResolvedKey config.plugins.crashlogautosubmit.addWlan failed !! (Typo??)
</enigma2crashlog>
</crashlogs>
</openpli>
