kromarem
Вот нашел коды на каналы а как их поставить неврубаюсь че делать как мутить обьясните нубу плиз у мну Svec A8 все каналы на lmi1_ku настроены как мне добавить новый канал почитал тему нефига непонял пааамагите!!!
если кто знает пишите на [email protected] или в аську 409271200
Arriadia 2 ( Sport channel)
SAT: HOTBIRD 7
Position: 13° East
Transponder: 98
Frequency: 12.673
Polarity: Vertical
Symbol Rate: 27500
SID: 241 (00F1)
VPID: 3842 (0F02)
BISS Key: 1234560065432100
Fox tv - 42°
Frequency (12021:05380:H)
Biss key: 1000000000000000
TVE Hispasat 1D 12149 V BISS NEW
TVE La Primera Ceuta
TVE La 2 Ceuta
1F FF
BISS=1133559955331199
NBA TV
Intelsat 907 at 27.5°W
11517 V 5632 3/4
Provider ID: 000001(SID: 1)
key (00): 1A 2B 3C 81 4D 5E 6F 1A
ATV BL - Express3A 11 west
Index hex key
1F FF 00 00 00 00 00 00 02 00
Frequency (11518 /V/4630 3/4)
TV N Caledonie - 180°E
Index HEX key
1F FF 1A 2B 3C 81 4D 5E 6F1A
Frequency (11136/V/ 23150-3/4)
National Geographic Turkish (16°E)
National Geographic German (16°E)
1F FF 27 12 10 00 20 85 17 00
SAT2000(13°E)
Index HEX key
1F FF 20 00 20 00 00 20 00 00
DVTRK Dalnevostochnaya - 90.0°E
Index HEX key
1F FF 03 27 02 2C 10 62 51 C3
Frequency (3730/L/ 4285-3/4)
TV Wallis - 180°E
Index HEX key
Telekanal Rossiya Tver - 90.0°E
Index HEX key
Frequency (3923/L/ 3570-3/4)
Index HEX key
1F FF03 27 02 2C 10 62 51 C3
Minsk TV (Stolicnoe TV) - 53°E
Index HEX key
1F FF 10 09 19 32 36 24 62 BC
Frequency (11158/V/ 5788-3/4)
SPORT - 90°E
Index HEX key
1F FA 26 08 39 67 1204 38 4E
Frequency (3645/L/ 28000-3/4)
Imedi TV - 42°E
Index HEX key
1F FA 10 00 00 00 0000 00 00
Frequency (12609/V/ 3700-3/4)
PSC feed (WC matches) - 30.5°E
Index HEX key
1F FF11 11 11 11 11 11 11 11
Frequency (12533/H/ 3000-3/4)
Russian channels (in C-band) - 40°E
Index HEX key
Frequency (3675/R/ 33484-7/8)(3873/R/ 4340-3/4)(4112/R/ 4285-3/4)
INTERCOM (radio channel) - 42°E
Index HEX key
1F FF11 11 11 00 11 11 18 00
Frequency (11954/V/ 8800-3/4)
Rustavi 2 - 42°E
Index HEX key
1FFF DB A5 45 00 FD E3 62 00
Frequency (12595/V/ 2500-5/6)
RTL9 - 23.5°E
Index HEX key
1F FF AB CD EF 67 FE DC BA 94
Frequency (10788/H/ 22000-5/6)
Abu Dhabi TV Europe -26°E
Index HEX key
1F FF 1A 2B 3C 00 4D 5E 6F 00
Frequency (11862/V/ 27500-3/4)
BN Space Channel - 30.5°E
Index HEX key
1F FF 20 06 20 00 06 20 06 00
Frequency (12582/V/ 4220-3/4)
ENTV (PROGRAMME NATIONAL) - 22°w
Index HEX key
1F FF 11 00 00 00 00 00 00 00
Frequency (12735/H/ 16640-3/4)
5KANALAS - 4°W
Index HEX key
1F FF 00 00 00 00 00 00 00 00
Frequency (11423/H/ 2894-3/4)
ENTV (PROGRAMME NATIONAL) - 22°W
Index HEX key
Earth TV - 15°W
Index HEX key
1F FFBB EF 01 AB E6 7E 20 84
Frequency (12645/H/ 3255-3/4)
Canal 4 - 30°W
Index HEX key
1F FF 84 D1A6 FB 22ED F0 FF
Frequency (11731/H/28126-5/6)
NTS ABS 1 ( LM1 ) / 75.0°E
Index HEX key
1FFF 12 D9 68 53 F4 A2 59 EF
Frequency (12704 V 3900 )
2M National, Atlantic bird 1 12 WEst
Index HEX key
1F FF / 1F FA
KEY 21 0598 BE 00 00 00 00
Frequency (12584 , H, 2625, 3/4)
TDA(Bouquet) - 22°W
Index HEX key
1F FF11 00 00 00 00 00 00 00
Music now BADR 3 26° East
Index HEX key
1FFF
Key:A1 C3 B2 16 D4 F5 E6 AF
Frequency (11107 V 14470 3/4)
AXN Portugal 30°W
Index HEX key
1F FF 23 00 00 23 23 00 00 23
Frequency (11615 H MPEG-2 27500 3/4)
13E Rai (Africa ve Asia)
Frequency 10992 V 27500
Key: 30 19 63 AC 26 51 94 0B
Added: tonytr Added Time: 25.04.2007 01:20
НТН (channel 1)39E
111111111111
Disney
Eutelsat W1 at 10.0°E
12729 H 3100-7/8
CA E5 17 AB DF B8 46 BC
dad-5 telstar 15°W biss key
( NBC/CNBC/MSNBC Feeds )
11519 h 3744 7/8
key01 20 15 36 83 53 00 d6
XyLigan
В ресиверах SVEK -A8 c новой программой ввод ключа производиться после двойного нажатия на кнопку INFO
Подскажи что не так , я вожу BISS ключ чере нажатия 2 раза кнопки info и после нажатия кнопки сохранить поивляется надпись "сохранение" и все он повисает не на че не риагирует. ввожу ключи на закодированом конале
Кидал
Может памяти уже нет, вот он и подвисает! Зайди в редактор ключей и поудаляй ненужные ключики!
kirill25
я прошивал загрузчиком Svec aII TooIs прога UP DAE -106A70 и где этот копировальщик не пойму если можно обясните мне чайнику по подробнее
trank999
kromarem. Если софт уже залит,приступаем к следующей операции.
Начнём с СТС.
Заходим в закладку Бисс.
Вместо 1FFF Устанавливаем идент1647,для STS+7.
затем привязка к градусу 090.
Привязка к частоте 11058.
Для STS+4, идент 1646.
Привязка к градусу 090.
Привязка к частоте 11094.
Проверяем,что СТС-ы открылись.
Далее, опишу на примере Домашнего.
Выбираем новый спутник.
В установках частоты гетеродина,вместо 9750.
Устанавливаем 9740.Соответственно пересчитываем частоты.
11058-10=11048.
11094-10=11084.
Добавляем пересчитанные частоты в список транспондеров.
Сканируем.
Теперь удаляем все отсканированные каналы,на этом спутнике за исключением Домашний+4 и Домашний+7.
Добавляем новый или используем ненужный,например дискавери турция.
Прописываем идент 0000, прописываем ключ Домашнего.
Привязка к частоте 090.
Привязка к уже пересчитанной частоте,в данном случае 11048и 11084.
Выходим из эмулятора и проверяем.
Должны работать СТС+4,СТС+7,Домашний+4,Домашний+7.
В случаи необходимости привязать ещё каналы,процедуру повторяем.
Только теперь частоту,гетеродина устанавливаем 9730.
Ну и делаем соответствующии перерасчеты.
11058-20=11038.
11094-20=11074.
Таким образом можно привязать большое количество каналов,с одного транспондера.
Удачи.
Добавлено через 13 часов 37 минут
это такие глючные ресы на новом проце (612...) и сик 03, и их надо перепрошивать, но прошивка и прога пока платная на телесате.
trank999
кто знает где найти родное ПО
прошивка с шарингом по этой ссылке http://trank999.mylivepage.ru/file/1208/7403_прошивки_с_шарой_без_активатора.rar но нужен LPT порт для заливки нового бута, софт можно залить через ком порт, но есть и родной софт, который заливается свегалом через ком порт кабелем 2-2, 3-3, 5-5 )обращаться http://trank999.mylivepage.ru/forum/909/9887_Китайские_ресиверы
Добавлено через 21 минуту
vec s5800n как и чем можно его прошить
прошивка данного апарата очень сложная, в нем нет ком порта (нужен преобразователь RX и TX на max 232 )но можно прошить дампом через LPT порт (прошивка черех LPT займет около часа ( через преобразователь 2 мин)) и еще, ресиверы бывают двух типов с тюнером FF1 и FF2 поэтому и прошивки разные, если есть желание и LPT в компе, я могу выслать инструкции,инструменты, прошивку с шарой на данный аппарат. обращаться по ссылке: http://trank999.mylivepage.ru/forum/909/9887_Китайские_ресиверы
Добавлено через 30 минут
добрый день у меня с рес Svec A8 такая фигня при слепом поиске забился каналами и всё встало с пульта не реагирует прошил не родной прошивкой
этот аппарат надо прошить родной прошивкой или прошивкой с шарингом ( если он собран на процесоре NEC 61110) на проце 61216 прошивок и прог нет.
kirill25
добрый день я понимаю что 232 надо шить но на самом аппарате разъём четыре штырька какая там схема расположения ножек Svec s5800n
trank999
если требуется прошить один рес, то можно обойтися без компорта. Прошей дампом через житаг (прога житаг ТТ) шьет 40мин, но надо описывать железо какой стоит тюнер FF1 или FF2 потому-что прошивки разные. Дамп я вышлю.
By Skorik
всем привет подскажите пожалуйста как настроить орт на svec A8 я живу в актобе. заранее спосибо.:unsure:
Берем тарелку 1.20 офсет, типа Арион (СВЕК-не брать!!!!), покупаем пушку Ку универсальную. Настраиваем на спутник Экспресс АМ22 (53-й градус, http://www.lyngsat.com/eam22.html).
Вылавливаем ОРТ-СНГ, смотрим. Только так.
При первой возможности выбрасываем СВЕК с 14-го этажа. Покупаем нормальный рес, типа Опена. Хотя умельцы уже подружили SVEC A8 с шарой. Но это равноценно мазохизму (кому-то нравится)
dark_wolf89
помогите с тюнером svec-A8.поставил ku голову на 75Е,настроили на другом тюнере а когда на моём начали частоты вбивать находит левые 5 каналов и всё,а нужных нету,кто сталкивался с этой проблемой подскажите!!!!!!!1
Lcf-93
Здравствуйте! Я купил себе Svec A8. Но не как не могу его настроить. к нему еще прилагается какая-то карточка, а для чего она я не знаю! там еще написан серийный номер. Что с ним делать? Как настроить каналы.? Я нахожусь В городе Карталы(Челябинской области)).:) Заранее спасибо за помощь!!!!
iehsuf
привет подскажите как залить бисс ключи выхожу на бисс но провайдеров нет
wiktor50
svec a 8
На свек-а8,ключи можно забивать и с пульта.Жмём меню,Конфигурация,ОК,Input code,ОК.
Выбираем кодировку,курсором вправо-влево.
Далее смотри подсказку в бегущей строке.
И подсказки к цветным кнопкам.
Add-Добавить.Save-Сохранить.Delete-Удалить.
Набираем градус спутника.
Набираем частоту.
Набираем ключ.
Сохраняем.
SVEС -A8
Через меню входим в конфигурацию .Находим там input code и в кодировках находим BISS ( Menu -->Конфигурация ---> input code --> BISS ) .
в провайдерах выбираем нужный канал,через OK вместо 1FFF ставим 0000 потом ОК и вводим ключ .
Затем MENU потом INFO( На некоторых пультах кнопка T/R ) и производим привязку к частоте канала снова MENU и кнопка ERG( синия кнопка) и выход.
Все готово . теперь переключаем на бесплатный канал и снова на платный все работает .
В ресиверах SVEС -A8 c новой программой ввод ключа производиться после двойного нажатия на кнопку INFO(T/R)
lexsis7
Привет всем! У меня проблема? Перевезли антену с одного места на другое начал подключать а он не показывает каналы. ресивер svec a8 на экране высвечивает типа нету программы хотя антена почти 80% верхняя полоса а нижняя нуль. Помогите пожалуйста что делать пошагово, а то я в этом не то что чайник полный ноль? Зарание благодарствую!
GangsterSSS
Ресивер Changhong DVB-S6000R !!!Помогите!!!
Можно ли его прошить? Чтоб смотреть некоторые закодированные каналы? На форуме не смог найти ни чего про эту модель... :( Заранее спасибо!!!
peet6
Всем привет, подскажите пожалуйста можно ли на свек а8 принимать приколор?
папараци
это имя знают все ...
В полном объёме нет,только открытые .Триколор,ТВ3,Европа + и т.д.В ресивере нет картоприёмника и для него нет ПО под ш@ринг.
peet6
А как открытые настраивать, я когда его купил попробовал поиском ничего сразу не получилось, забросил. Сейчас возникла необходимость в другой комнате смотреть тв.
