вот такой хэлп выводится на консоль если запускать без параметров
Usage1: trprocess [+]<html_file or filemask> [options]
Usage2: trprocess [+]<dll_file or filemask>.dll [options]
Usage3: trprocess [+]<xml_file or filemask>.xml [options]
Usage4: trprocess [+]<ini_file or filemask>.ini [options]
Usage5: trprocess <URL_pointed_to_HTML> [options]
Usage6: trprocess !<site_id>!<sat_position> [options]
Usage7: trprocess !<site_id>![<positions_range>] [options]
Usage8: trprocess @<list_of_urls_or_files_to_process> [options]
Options:
/ConvCircular<+|-> - Convert L/R polarization to H/V (or not)
/ConvCBand<+|-> - Convert C band frequences to Ku (or not)
/Proxy=<http_proxy_host>:<http_proxy_port>
/Proxya=<proxy_user>:<proxy_password>@<http_proxy_host>:<http_proxy_port>
/KeepHTML<+|-> - Keep downloaded files
/DSS<+|-> - Accept DSS transponders (or not)
/DVBS2<+|-> - Accept DVBS2 transponders (or not)
/Feeds<+|-> - Accept transponders with feeds (or not)
/Data<+|-> - Accept transponders with data services (or not)
/Ku<+|-> - Accept Ku band transponders (or not)
/C<+|-> - Accept C band transponders (or not)
/Linear<+|-> - Accept transponders with linear polarization (or not)
/Circular<+|-> - Accept transponders with circular polarization (or not)
/MinSR=<min_symbolrate> - Specify minimum symbolrate to process
/MaxSR=<max_symbolrate> - Specify maximum symbolrate to process
/ProvInfo<+|-> - Add providers info to INI file (or not)
/Format=<i1|i2|i3|x|d|t|k> - Format of file with transponders (INI, XML, DLL,TRP
or Kathrein UFS 910 data files )
/S - Save CFG File
Options by default:
/DVBS2- /DSS-
/ConvCircular- /ConvCBand-
/KeepHTML- /Feeds+ /Data+ /Ku+ /Linear+ /Circular+
/Format=i1 /ProvInfo-
Examples :
trprocess astra19.html /Data-
trprocess +*.html /Ku- /Linear-
trprocess !l!130
trprocess !s!192
trprocess !k!160
trprocess !l![300w-970e]
trprocess *.ini /MaxSR=10000 /Format=t
trprocess satellites.xml /Format=d
trprocess @satlist.txt /Format=x
trprocess @satlist.txt /Format=k
trprocess
http://www.flysat.com/hotbird.php
trprocess
http://www.satcodx1.com/0130/usa/
trprocess
http://www.telesputnik.ru/television/freq-tab.pl?sat=30
trprocess
http://www.lyngsat.com/hotbird.html /proxy=10.0.0.1:3128
trprocess
http://en.kingofsat.net/pos-23.5E.php /DVBS2+
Examples of list file
-8<-----------8<-------
satellite.dll
!l!900
!l!3300
!l!130
!l!800 /C-
!l!900 /Ku-
Здесь описано какие бывают ключи
зачем они и примеры использования
Для случая с 36 градусами
я не уверен что ресивер понимает круговую поляризацию.
Поэтому, для генерации setting'ов
на 5E+13E+192E+36E
лучше использовать следующий файл список
satlist.txt
!l!130
!l!192
!l!48
!l!360 /Linear- /ConvCircular+
здесь указывается что для 36 градусов
линейную поляризацию не учитывать (учитывать только круговую)
а круговую ковертировать в линейную L->H R->V
а программу запускать
trprocess @satlist.txt /format=k
и ещё
частоты гетеродинов везде ставятся
под универсальный конвертер
9750,10600,11700
так что, под нтв+
правьте сами частоты в ресивере.
