Пользовался я такой связкой
я вас и спросил поэтому
Виснет при загрузке или при работе
Нет доступа по фтп и летит мимо шаринг. В бутаргах: флеш- мод, остальное- вся энигма.
Bootargs backup from 192.168.1.11 prepared 15.04.2013
boot_param_version=22
board=stb7100ref_27
bootdelay=1
ethaddr=00:1D:EC:01:2F:5A
bootargs=console=ttyAS0,115200 root=/dev/mtdblock3 mem=41m bigphysarea=2984 coprocessor_mem=2m@0x04000000,2m@0x04200000
stdin=serial
stdout=serial
stderr=serial
autoload=n
ipaddr=192.168.1.11
serverip=192.168.1.1
gateway=192.168.1.1
gatewayip=192.168.1.1
netmask=255.255.255.0
bootcmd=bootm a0030000
bootdesc_0=----Flash----
bootcmd_0=run bootargs_0; bootm a0040000
bootargs_0=set bootargs console=ttyAS0,115200 root=/dev/mtdblock2 ip=192.168.1.11:192.168.1.1:192.168.1.1:255.255.255.0:kathrein:eth0
ff mem=64m coprocessor_mem=4m@0x10000000,4m@0x10400000 rootdelay=0 nwhwconf=device:eth0,hwaddr:00:1D:EC:01:2F:5A init=/bin/devinit
bootdesc_9=----MINI1----
bootcmd_9=usb reset;ext2load usb 0:2 a5000000 /boot/uImage;run bootargs_9;bootm a5000000
bootargs_9=set bootargs console=ttyAS0,115200 root=/dev/sda2 rw ip=192.168.1.11:192.168.1.1:192.168.1.1:255.255.25 5.0:kathrein:eth0
ff mem=64m coprocessor_mem=4m@0x10000000,4m@0x10400000 rootdelay=6 nwhwconf=device:eth0,hwaddr:00:1D:EC:01:2F:5A init=/bin/devinit
bootdesc_8=----MINI2----
bootcmd_8=usb reset;ext2load usb 0:3 a5000000 /boot/uImage;run bootargs_8;bootm a5000000
bootargs_8=set bootargs console=ttyAS0,115200 root=/dev/sda3 rw ip=192.168.1.11:192.168.1.1:192.168.1.1:255.255.25 5.0:kathrein:eth0
bootdesc_7=----MINI3----
bootcmd_7=usb reset;ext2load usb 0:5 a5000000 /boot/uImage;run bootargs_7;bootm a5000000
bootargs_7=set bootargs console=ttyAS0,115200 root=/dev/sda5 rw ip=192.168.1.11:192.168.1.1:192.168.1.1:255.255.25 5.0:kathrein:eth0
bootdesc_6=----MINI4----
bootcmd_6=usb reset;ext2load usb 0:6 a5000000 /boot/uImage;run bootargs_6;bootm a5000000
bootargs_6=set bootargs console=ttyAS0,115200 root=/dev/sda6 rw ip=192.168.1.11:192.168.1.1:192.168.1.1:255.255.25 5.0:kathrein:eth0
bootdesc_5=----MINI5----
bootcmd_5=usb reset;ext2load usb 0:7 a5000000 /boot/uImage;run bootargs_5;bootm a5000000
bootargs_5=set bootargs console=ttyAS0,115200 root=/dev/sda7 rw ip=192.168.1.11:192.168.1.1:192.168.1.1:255.255.25 5.0:kathrein:eth0
bootdesc_4=----MINI6----
bootcmd_4=usb reset;ext2load usb 0:8 a5000000 /boot/uImage;run bootargs_4;bootm a5000000
bootargs_4=set bootargs console=ttyAS0,115200 root=/dev/sda8 rw ip=192.168.1.11:192.168.1.1:192.168.1.1:255.255.25 5.0:kathrein:eth0
bootdesc_3=----MINI7----
bootcmd_3=usb reset;ext2load usb 0:9 a5000000 /boot/uImage;run bootargs_3;bootm a5000000
bootargs_3=set bootargs console=ttyAS0,115200 root=/dev/sda9 rw ip=192.168.1.11:192.168.1.1:192.168.1.1:255.255.25 5.0:kathrein:eth0
bootdesc_2=----MINI8----
bootcmd_2=usb reset;ext2load usb 1:1 a5000000 /boot/uImage;run bootargs_2;bootm a5000000
bootargs_2=set bootargs console=ttyAS0,115200 root=/dev/sdb1 rw ip=192.168.1.11:192.168.1.1:192.168.1.1:255.255.25 5.0:kathrein:eth0
bootdesc_1=----MINI9----
bootcmd_1=usb reset;ext2load usb 1:2 a5000000 /boot/uImage;run bootargs_1;bootm a5000000
bootargs_1=set bootargs console=ttyAS0,115200 root=/dev/sdb2 rw ip=192.168.1.11:192.168.1.1:192.168.1.1:255.255.25 5.0:kathrein:eth0
bootmenutimeout=2
rootdelay=2
front=4
backupper=4
backlower=2
hdd=no
bootdesc_default=0
Имиджи на флешке рабочие абсолютно, хромает только мод.
