Вопросы от новичков!!!
Вот что у меня катрайн выделывает..если всё верно прописать..
Kathrein UFS910 - Kernel 2.6.17.14_stm22_0037 (11:03:49).
kathrein-ufs910 login: root
Password:
BusyBox v1.2.1 (2007.10.12-18:30+0000) Built-in shell (ash)
Kathrein UFS-910 ROOTDIR
# killall mgcamd
# cd /data/emu
# ./mgcamd
tuxbox mgcamd v1.28 by mixvt (compiled Feb 5 2008 15:05:15)
[mg] Net:1:7:2:5s Show ecm:1, emm:2 Up:5 Au:1 Dir:0 Osd:no:80:0 Cache:0 Log:2:12
7.0.0.1:28007 Reread:0
[mg] Ecm cache time: 15
Box type: stapi
Conax.Key error 2: No such file or directory
Keys readed
# [config] newcamd route = ЛОГИН:IP адресс:ПОРТ server cardserv
newcamd keep alive: 0, incoming port: 0
[mgcam] emm thread started
[mgcamd] tps update started.
[newcamd] Connecting to IP адресс:ПОРТ...
[mg0] service 2779 index 0 pmt pid 0 (1)
ECM: CaID: 0x0500 -> CaPID: 0x1775 ProvID: 020710
ECM: CaID: 0x0500 -> CaPID: 0x0BBD ProvID: 030600
ECM: CaID: 0x0500 -> CaPID: 0x0FA5 ProvID: 023700
[mg0] No viaccess key(s) found for id 20710 keynr 08
[mg0] network can't decode
[mg0] pid 0x1775 failed to decode.
/data/keys/tps.au error 2: No such file or directory
[mg0] No viaccess key(s) found for id 30600 keynr 06
[mg0] pid 0x0BBD failed to decode.
[mg0] No viaccess key(s) found for id 23700 keynr 08
[mg0] pid 0x0FA5 failed to decode.
[mgcamd] emm started
EMM: CaID: 0x0500 -> CaPID: 0x03EB ProvID: 030600
EMM: CaID: 0x0500 -> CaPID: 0x03E8 ProvID: 023700
EMM: CaID: 0x0500 -> CaPID: 0x03EA ProvID: 020710
[mgcamd] emm stopped
[newcamd] Login to IP адресс:ПОРТ as ЛОГИН accepted (282ms)
[newcamd] Card data from IP адресс:ПОРТ (600ms):
Userid 114 caid 500 providers 4
Idents: 020710 022C00 023800 023100
[mg0] -> ECM to newcamd IP адресс:ПОРТ
[mg0] <- CW from newcamd IP адресс:ПОРТ (693ms)
[mg0] 693 msec -- Tue Jun 10 11:04:39 2008
===== Viaccess ECM on CaID 0x0500, pid 0x1775 ======
prov: 020710
cw0:0 E3 BF FF A1 1C 0E 00 2A пошли ключи с инета..
cw1:0 0F A1 C7 77 FF FE 00 FD
у меня чётко видно что сервер принял мой логин и дал допуск..
Где то у вас есть ошибка в настройках..
пи.си..у меня и на камд3(протокол ньюкамд!!!!!!) также конектится и работает!!
Может у вас сервер работает по протоколу камд3????А вы пробуете по ньюкамду???
tornado1973
у меня с camd3 тоже геморой..., не работает хоть тресни
через польский интерфейс заинсталить нельзя отсутсвует файл awk, при установке вручную
не стартует, скрипты правил ,права прописывал логи смотрел фиг
4 часа проплясал с бубном,3 раза перешивал по новой...
сетинги нифига не подходят...с ааф, тупо не видит спутники... и даже если видит и есть уровень сигнала даже на открытых каналах малевич,плюнул
и откатился на ааф 1.05 ,без русского но зато все работает...
для меня не варинат использовать мжкамд так что вот так
удачи
Deesy
tornado1973, awk файл видел в одной из сборок. можно скопировать оттуда либо посмотреть у себя (лежит не по путю)
oleg1981
tornado1973,У меня без проблем заработал камд3 на рудбокс 1.05.Закинул бинарник камд3,настроил конфиги запустил вручную все заработало,после этого поправил файлы автозапуска,всюда где стояло название мгкамд переправил на камд3,и теперь камд3 запускается автоматом
tornado1973
делал так же ,фиг ..завтра буду пробовать еще -)))
на свежую голову
satgenerator
Донастраивался, теперь и ТПС-ы не кажут :(
Current timestamp not found in /data/keys/tps.au mgcamd
alexeyr
ПОдскажите пожалуйста как посмотреть Pmt Pid конкретного канала на Кате?
alexeyr, зайдите через тотал коммандер в папку тмр --там они есть..если имидж РКТ то через ОСД меню можна увидеть..
grigori
проблема с изображением помогите пожалуйста
у меня пригает картинка только на 2 каналах евроспорт hd и swisse hd остальные показывают класно я понёс и в другом месте у друга подключил там тоже пригает перепрыгивает странно всё попробывали и почистили разные имеджи залили ничего не помогает .помогите пожалуйста кто может буду очень блогадарен
toyo
grigori, Как и к какому телевизору подключали? Дружит ли ваш ТВ с разрешением 1080i ?
grigori
toyo bolshoe spasibo chto otvetili,u menja toshiba lcd,ne bilo ni kakix problem vsegda vsje rabotalo,daje neznaju chto delat ni kto neznaet chto delat,vse drugie kanali hd i ni hd pokazivajut
Добавлено через 3 минуты
a pochemu nelzja novichkam sprashivat straano kakaja raznica novichok ili net ne poimu ,est problema i navernoe est ljudi u kogo toje bila takaja problema,neujeli ne ludshe pomogat takim obrazom ljudjam ,a kto ploxo vedjet udaljat,s uvajeniem grigori
dtv02, может вас послать изучать правила?
Мне лично самому интересно и любопытно узнать ..почему....по моему тема заслуживает внимания..к сожалению у меня нету доступа к этим каналам..
toyo
grigori, Новичкам спрашивать можно Не проблема. Но есть тема http://forum.sat-expert.com/kathrein-ufs-910/6647-voprosy-ot-novichkov.html . От сюда и выплывает нарушение правил, которое влечёт за собой как минимум несметное количество тем однодневок.
каналах евроспорт hd и swisse hd вы смотрите как? Он открытые или с оф карточки. Или через шаринг?
toyo, мы потом перенесём..
Я смотрю у поляков подобная тема рассматривается на их форуме http://forum.dvhk.pl/forumdisplay.php?f=94
Пока тоже не могу понять причину..одни пишут,что всё ок..другие --аналогично как и у товарища..
Хотелось бы понять в чём тут проблема --глюк имиджа или что то с настройками..почему то они ещё пишут и о немецком орф хд..
Кто смотрит и в курсе этой проблемы--отпишитесь..
grigori
roditeli toje tak smotrjat ponjes u nix proverit moju katju i tam toje takaja je problema ixnie kodi vjel toje samoe ,a u nix pokazivaet
Добавлено через 1 минуту
mi ego pochistili zanovo,i raznie imedji stavili vsje ravno ne pomagaet,spasibo bolshoe chto staraetes pomoch i izvinite za bespokoistva
Добавлено через 4 минуты
ja imeju vvidu roditelei kathrein pokazivaet normalno
