-----====== HDMU 12692 enigma2 Git 3062 ======-----
12692 e88b802 bonkel, Sun Aug 10 18:29:49 2014 +0200: Merge remote-tracking branch 'plineu/master'
12691 6c1e24e bonkel, Sun Aug 10 18:29:33 2014 +0200: fix
12690 2db31ea littlesat, Sun Aug 10 17:26:33 2014 +0200: Move pictureviewer resolution to enigma2 configs
12689 ba60981 bonkel, Sun Aug 10 14:41:57 2014 +0200: update skin stuff
12688 95c86b8 bonkel, Sun Aug 10 14:33:43 2014 +0200: update skin stuff
12687 1863009 bonkel, Sun Aug 10 14:22:00 2014 +0200: update skin stuff
12686 5f49684 littlesat, Sun Aug 10 14:15:41 2014 +0200: Solve GSOD at NumberZap due to a non existing skin in skin_display.xml
12685 329074e littlesat, Sun Aug 10 13:49:16 2014 +0200: Upgrade the VFD skin for the VU+Duo2 and Extrend ET10000
12684 d60fe13 Erik Slagter, Sun Aug 10 12:13:05 2014 +0200: ServiceScan: add missing DVB-C FEC value
12683 b8d488f bonkel, Sun Aug 10 12:06:44 2014 +0200: Merge remote-tracking branch 'plineu/master'
12682 f68272f littlesat, Sun Aug 10 12:06:35 2014 +0200: Show full screen pin input for entering protected user bouquets
12681 014ef7c littlesat, Sun Aug 10 11:58:21 2014 +0200: Finetuning around parentalcontrol notifications
12680 9c64352 littlesat, Sun Aug 10 10:40:49 2014 +0200: Finetuning in parental control for bouquets
12679 c27cc7a bonkel, Sun Aug 10 03:40:08 2014 +0200: fix update
12678 a698349 littlesat, Sun Aug 10 01:50:10 2014 +0200: Use cancel instead of close when pin is required on bouquet
12677 44f420f littlesat, Sun Aug 10 01:36:54 2014 +0200: Enable parental control for userbouquets
12676 a37bc7a bonkel, Sat Aug 9 18:10:59 2014 +0200: fix build
12675 a8dbdd8 Mike Looijmans, Sat Aug 9 15:48:25 2014 +0200: Use CFile in a few more places
12674 3cd7a22 bonkel, Sat Aug 9 15:24:03 2014 +0200: update skin
12673 77051a6 Mike Looijmans, Sat Aug 9 15:12:38 2014 +0200: MovieList: Add groupwise sort mechanism and set it to be default.
12672 dbca299 Mike Looijmans, Sat Aug 9 14:28:15 2014 +0200: Show progress while initalizing or checking harddisk
12671 ac25a6b bonkel, Sat Aug 9 15:17:52 2014 +0200: fix merge
12670 c9d9598 bonkel, Sat Aug 9 15:14:43 2014 +0200: update skin
12669 4239aa6 bonkel, Sat Aug 9 15:04:16 2014 +0200: fix
12668 bc79911 bonkel, Sat Aug 9 15:03:10 2014 +0200: fix
12667 6e9798a littlesat, Sat Aug 9 14:26:35 2014 +0200: Make software update disclaimer text translatable
12666 b68bbc8 littlesat, Sat Aug 9 14:22:01 2014 +0200: SoftwareUpdate: Introduce a update disclaimer
12665 d3f4884 littlesat, Sat Aug 9 12:04:20 2014 +0200: TimerList: Solve position issue for alternatives
12664 6f9feec littlesat, Sat Aug 9 11:50:09 2014 +0200: Standby: Ensure to stop service when time is known when startup to standby
12663 abc93da littlesat, Sat Aug 9 11:35:24 2014 +0200: Revert "Standby: Use timerhandler.ready() to check if time is valid"
12662 59e4cec littlesat, Sat Aug 9 11:32:59 2014 +0200: Standby: Use timerhandler.ready() to check if time is valid
12661 ce48aa9 littlesat, Sat Aug 9 11:04:03 2014 +0200: Standby: stop service as soon valid time is received by transponder
12660 dccb56c bonkel, Sat Aug 9 02:03:50 2014 +0200: :Merge remote-tracking branch 'plineu/master'
12659 27a6f77 daddelfalk, Fri Aug 8 18:19:04 2014 +0200: ServiceScan: add missing DVB-C FEC values
12658 4514242 bonkel, Fri Aug 8 14:09:26 2014 +0200: fix
12657 47970b1 bonkel, Fri Aug 8 13:23:36 2014 +0200: Merge remote-tracking branch 'plineu/master'
12656 bde9aa8 bonkel, Fri Aug 8 13:22:24 2014 +0200: update default picon
12655 b1ab828 Erik Slagter, Fri Aug 8 10:54:39 2014 +0200: httpstream: reintroduce d318d544cf76ea58c4f12bccc0541d888af7570c: handle chunked transfers for statuscode 200
12654 cf125e6 Erik Slagter, Fri Aug 8 10:51:57 2014 +0200: httpstream: fix comparison for transfer-encoding
12653 fb5f258 bonkel, Thu Aug 7 21:50:44 2014 +0200: fix
12652 a5608bc Mike Looijmans, Thu Aug 7 18:42:27 2014 +0200: Skip building DVDBurn plugin
12651 f125879 bonkel, Thu Aug 7 18:44:06 2014 +0200: update
12650 98bf08c Mike Looijmans, Thu Aug 7 18:29:06 2014 +0200: Remove uninstallable Modem plugin
12649 bfa4891 bonkel, Thu Aug 7 01:55:57 2014 +0200: Merge remote-tracking branch 'plineu/master'
12648 12543dc bonkel, Thu Aug 7 00:47:43 2014 +0200: add py
12647 07f66f2 littlesat, Wed Aug 6 18:17:22 2014 +0200: Do not go automatically to deepstandby when internal harddisk is running
12646 8e514b7 bonkel, Wed Aug 6 17:26:06 2014 +0200: fix
12645 025f1d3 Tech, Mon Aug 4 20:57:23 2014 +0200: Small translation fixes
12644 99738c5 daddelfalk, Tue Jul 29 17:14:02 2014 +0200: ScanSetup.py and Transponder.py: Refresh fec for DVB-C
12643 047d1dd daddelfalk, Tue Jul 29 16:51:07 2014 +0200: frontend and frontendparms: sync fec given eDVBFrontendParametersCable
12642 84e378a littlesat, Tue Aug 5 19:38:05 2014 +0200: From setup menu in channelselection go back to channelselection
12641 98c4bb9 littlesat, Tue Aug 5 18:54:13 2014 +0200: Add + and ~ key in Virtual keybord for English language
12640 089ec70 littlesat, Tue Aug 5 18:40:59 2014 +0200: Also try to adjust OSD to 1280x720 for overscan testscreen
12639 35f13ff littlesat, Tue Aug 5 17:52:30 2014 +0200: Reintroduce find current service for pipzap
12638 d5ad034 bonkel, Tue Aug 5 11:59:45 2014 +0200: Merge remote-tracking branch 'plineu/master'
12637 5633f8a ims, Tue Aug 5 10:52:11 2014 +0200: cosmetic - resize brightnes text
12636 daced97 bonkel, Mon Aug 4 23:28:39 2014 +0200: Merge remote-tracking branch 'plineu/master'
12635 d7a58ba littlesat, Mon Aug 4 20:34:15 2014 +0200: Only search service in current userbouquet
12634 da99256 littlesat, Mon Aug 4 19:50:40 2014 +0200: Ensure that the testscreens are always displayed on a full OSD
12633 6b6ac07 littlesat, Mon Aug 4 19:19:51 2014 +0200: Add overscan testscreen in VideoFinetune
12632 a5abc1e bonkel, Mon Aug 4 18:15:47 2014 +0200: Merge remote-tracking branch 'plineu/master'
12631 c84a5cd littlesat, Mon Aug 4 17:52:13 2014 +0200: Disable find currently played service when we are in pipzap mode
12630 3251207 bonkel, Mon Aug 4 01:41:50 2014 +0200: fix
12629 25c9447 littlesat, Sun Aug 3 22:49:56 2014 +0200: Change hotkeys in channelselection contectmenu to align linux style
12628 fc7b1fe littlesat, Sun Aug 3 22:27:05 2014 +0200: Do not save root when root is changed by numberZap in ChannelSelection
12627 195b107 littlesat, Sun Aug 3 18:51:32 2014 +0200: New dutch translations, thanks Tech
12626 e69669d bonkel, Sun Aug 3 15:19:19 2014 +0200: test
12625 bee7440 bonkel, Sun Aug 3 15:15:51 2014 +0200: Merge remote-tracking branch 'plineu/master'
12624 c8a2ded littlesat, Sun Aug 3 12:12:22 2014 +0200: Fix some issues with hotkeys in ChannelSelection Context Menu
12623 029101b littlesat, Sun Aug 3 00:27:21 2014 +0200: Do completely block numberzap in movemode
12622 9e047e5 littlesat, Sun Aug 3 00:22:44 2014 +0200: Block find current service, rename and remove when in movemode
12621 a42bac1 littlesat, Sat Aug 2 23:23:42 2014 +0200: Do not numberZap in channel selection when service selected in movemode
12620 9a91679 bonkel, Sat Aug 2 17:42:26 2014 +0200: Merge remote-tracking branch 'plineu/master'
12619 071a7c9 littlesat, Sat Aug 2 12:19:59 2014 +0200: Remove not required double declaration of GUI_WIDGET in progress renderer
12618 f3dc899 littlesat, Sat Aug 2 10:35:56 2014 +0200: Correct channel number when coming from ChannelSelectionRadio
12617 541e6ff littlesat, Sat Aug 2 10:19:53 2014 +0200: Correctly show and hide infoscreen in radio channel selection
12616 b21bd69 littlesat, Sat Aug 2 10:02:41 2014 +0200: Enable numberzap in radio and simple service selection
12615 7ca920f littlesat, Sat Aug 2 08:40:49 2014 +0200: Introduce numberzap functionality in channelselection screen
