Вышел новый софт:
V10778 NEU EMU SW : OCTAGON_SF1018_HD_ALLIANCE_V10778__01_12_09
Readme_OCTAGON_SF1018_HD_ALLIANCE_V10778__01_12_09
for Octagon HD SF 1018 HDTV - ALLIANCE :
Changes :
- Add. EPG Information in CH.List (OK Button)
--> Menu - Configuration - Display Setting : OSD Type : Transparent
- Add. possibility zap. CH. Cursor Button (up/down)
--> Menu - Configuration - Display Setting : Simple Service List On/Off
- Add. Alarm Confirm Message Function for Timer Recording
--> Menu - Configuration - Recording Option : Alarm Confirm Message : On/Off
- S02 SmartCard improved (Pls. test longer time)
- In EPG (top left) EPG Event Name font enhanced
--> Menu OSD size & Fonts will enhanced soon !
- New designed File List(- combination FileList supported.) playback modus
--> New Icons (TS, Mp3, Jpeg etc.)
- Not activating when move from network standby on mode to run condition fix.
--> Not working WiFi by activating from standby to run when using WiFi in Standby Power On/Off mode fix.
- Changed RECALL Button function
--> one time - Recall List
--> two times - Recall
- Fix. loss user setups after rebooting
- Correcture German OSD Language Translation
- Correcture Polish OSD Language Translation
- New OSD Language add. : Persian
- Some bugs related to Format fix.
- Cam Modul Info Message Popup bug fix.
- LINUX OS , internal updates fix. :
--> API Version
--> Data Version
--> Kernel Version
--> Driver Version
--> Root File System Version
Online SW upgrade : oud.gmc.to
IMPORTANT : Advice for Software and Setting Update
Please save/copy Swoftware & Setting files in MAIN Directory from your USB Stick !
Please make after SW update Factory Reset (System Recovery) !
SmartCard Activate :
Pls. Press Menü --> Utilities --> CAS --> OK Button --> Enter PIN 1018
--> SmartCard ON/OFF
CAM Start/Stop :
--> Start : Menu + Red Button
--> Stop : Menu + Blue Button
Storage Setup`s (Save/Store to STB) :
Menu --> Installation --> System Recovery --> Press OK Button :
--> System restore to stored Position (recover/restore Backup)
--> Store System Data (Backup Store)
Storage Setup`s to USB Stick/Storage :
Menu --> System Tools --> Data Transfer --> Press OK Button :
--> Transfer All System Data to USB Storage
--> Transfer Service Data to USB Storage (Channel list)
--> Data Download from USB Storage
Sky Premiere Portal (Multifeed) - Taste --> Blue Button
Master Password : 1018
Connection STB to PC :
- Connect STB with LAN Cable to PC
- Menu --> Installation --> Netzwork Settings --> change DHCP off and ON
--> Pls. wait until your IP nummer showing
--> Workstation in PC --> In Address Bar \\ (flashx2) give \\IP number and Press ENTER
--> You can see : Root (LINUX) & Storage (Speicher SATA HDD + USB1 + USB2) !
--> Also can use Samba and FileZila Program !
Date 01 December 2009
!good!
