Gemini2 v4.3
Enigma vom 12.06.2009
An overview over most functions can be found here
Gemini-Wiki
Function Buttons:
* BLUE - Blue Panel (BP)
* BLUE long - Picture in Picture (DM7025)
* 2x BLUE - BP -> Gemini Extras
* BLUE RED - File-Manager
* RED - Recording (not for DM8000)
* GREEN - Quickbutton / Subservices
* YELLOW - Timeshift (not for DM8000)
Extras:
* Addon and Plugin Server
* Cryptinfos of the channel or Cam, Stick Cam to certain channels
* Function for managing many daemons / server (BP -> Services/Daemons)
* optical enhancements like HD-skin, additional icons or modification of the channel list
* Manager for format, setup or mount devices (BP -> Device-manager)
* Additional EPG-functionality like Autosave, Refresh or different EPG-format view
* Particular addons like Dreamnetcast, Jukebox, Calendar, eMail or eTorrent, just to name some of them
* Quickbutton, to define functionality of the Green button via menun
* Detailled information about your Dreambox (Menu -> Information)
* File-Manager, which can handle different format-types, regardless whether it is a picture-, audio-, videoformat, playlists, torrent, scripts or DVD-files (BP -> File-Manager)
* complete handling of hard disks, DVD-drives, USB-Sticks changed to udev (system handels those devices by itself)
Information about many other functions, like "the GP2 Controlr", Rezapp or the other settings can be found at the IhaD-Board or our Wiki.
New:
* Jukebook updated -> search for ID3-Tag or file name
* folder of BSOD-Logs can be edited (BP -> Settings -> General)
* brightness of the Power-LED (DM8000) can be adjusted (BP -> Settings -> General)
* multiple units can be released in the network with NFS-Server
* Skin of Samba, Crond and NFS standardized
* static Webinterface for mobile devices => /mobile/
* Online-Test can be configured (Server and Intervall) (BP -> Services)
Fixes + Updates:
* many fixes in case with udev (thx to all user that helped us)
* USB-Stick with partitions should be listed now correctly.
* see CVS
Important:
* if you want to use the nfs-server you must install the fix from the BP-Addon-Server
This image doesn't contain any keys or softcams!
Backups or other modified images are not released by us
and won't be supported in any way!!!
