tolik501
Dreambox DM8000 В КОНЦЕ СЕНТЯБРЯ
Нарыл на оруме - http://ufs910.hdtvinfo.eu/component/option,com_fireboard/Itemid,26/func,view/catid,40/id,5951/#5951
что Dreambox DM8000 будет В КОНЦЕ СЕНТЯБРЯ по цене 899 ЕВРО .
Lünen, 18. August 2008. Dream Multimedia, the leading supplier of Linuxbased
set-top boxes, will be presenting the DM8000 HD PVR DVD at the IFA
show in Berlin, the absolute top-of-the-range solution for digital TV reception.
The new HDTV receiver will be available to the trade at the end of September,
at that stage review units will also be made available to the media.
The DM8000 functions as a home server, combining TV, DVD as well as PC
and recording functions all in one unit, via LAN or WLAN. The high quality of
reception, fast channel switching times and user-friendly operation are
already typical hallmark features of all Dreamboxes. What is new here is the
option to install a DVD player or recorder in the DM8000. Naturally, this latest
Dreambox can be expanded to become a PVR, using SATA and commercially
available hard drive options.
Two DVB S2 tuners provide timeshift as well as parallel television viewing and
recording of two different programmes. In addition, two additional tuners can
be easily brought on line via plug-and-play. Four slots for Common Interface
modules as well as two Smartcard readers provide all the options a Pay-TV
fan could desire.
Two USB 2.0 connections, one slot each for CF and SD cards, as well as digital
optical and coaxial sound output options ensure that every possible wish is
fulfilled in terms of connectivity. The DVI interface ensures loss-free
transmission of the digital image to the television set. In addition, the
DM8000 comes equipped with a YUV as well as with two Scart connections.
The DM8000 HD PVR DVD by Dream will be launched on the market at a RRP
of 899 Euros (excluding hard drive and DVD).
Напишу,чтоб потом не было куча мала разочарованных своим счастьем..и никто не сказал..
1.За эти деньги я б советовал лучше купить моторолер и поездить круг дома..ей богу больше увидете и узнаете.
2.Ситуация ныне такова ,чтоб что то смотреть вам интересное и шара не помощник..приходится просто докупать офф.тюнер с картой..где оф.тюнер привязан к карте..дрим отдыхает
3.Деньги офигенно не малые и эффект практически нулевой..смотреть открытые каналы можна на любом дешёвом тюнере и с таким же качеством..Просто посмотрите и подумайте..почему я такой ,что пользуюсь оф. тюнерами и картой???И подумайте насколько вы ..
el Diamante
Дела с 8 сотым Дримом такие:
Но те, которые выпущены в июне и июле, зависают на HD каналах примерно через пол часа работы.
На каких именно каналах зависает поточнее можно? Как протестить? У меня первые цифры серийника 86, гонял вчера 2 часа подряд на HD каналах Luxe TV c 9E - так и не завис. !good!
PS. Источник информации об отзыве ресиверов можно указать?
читай эту тему: http://www.allrussian.info/thread.php?threadid=99103&page=1 смотри 1/3 виснет, 2/3 не виснет...
____
публикуется с разрешения -tigekala
____
dmkbox
Что, получается что ВСЕ приемники за июнь-июль - БРАК? Или просто в этих партиях возможен брак? У меня 86xxx. Проверить пока не могу - идет ремонт в квартире. Написал в поддержку Дриммультимедиа, сказали - шлите тюнер, отремонтируем-поменяем. Только мне из России в Германию слать, а обратно еще раз таможню оплачивать, что ли?
не все брак, возможен брак в этих сериях. проверте сначало
____
____
dmkbox
блин, проверил бы - тока там где тарель повиснет - сейчас строительные леса.
dmkbox
Да, вот еще вопрос такой - установил BA, через него имидж NABILO. Ставлю в BA загрузка NAbilo. Тюнер при старте зависает и если вынуть флэшку - стартует, если ее тут же вставить - то запускается Набило. В чем косяк?
И еще один попутно вопрос - у меня тарель emme esse 85 + Titanium TSX. Все висит на мотоподвесе. Так вот, как бы не настраивал - максимум качества 25% по дримбоксу (сила сигнала - 99). Это на хотберде, W4... При 10% на Экспрессе АМ1 сыпет, а на Астре при тех же показателях - нет. Локация - Москва. Вопрос - это такая шкала в Дриме или у меня плохо настроено?
Wzor
тоже поставил офф имидж release-dm800_20080605.nfi установил ВА 4.5.7 скачанный выше ставлю gemini2-370-dm800-200807222128.nfi при загрузке зависает, поставил ВА 4.6.3 при загрузке не работает меню выбора имиджа .... Подскажите плизз что может быть ? Заранее спасибо
dmkbox
Wzor, я решил проблему только путем установки последней прошивки ozoon во флэш. Теперь все как часы.
alexeyf
Здравствуйте
Не пинайте пожалуйста , а что такое ВА и можно ли его не ставить , а поставить только Джемени 3.7 ?
Заранее спасибо
No_Va
Alexandr39
http://www.i-have-a-dreambox.com/wbb2/database.php?sid= Новый имидж вышел для тех кто любит Гемини!good!Перевод с оригинала... Gemini2 v3.8: Технический Infos: * Engima от: 26.09.2008 * Busybox 1.0.1 * Tuxtxt 1.95 Кнопки Функции: * СИНИЙ - Синяя Группа (BP) * долго СИНИЙ-> Пип (DM7025) * 2x СИНИЙ - BP-> Отдельно оплачиваемые предметы/параметры настройки * КРАСНЫЙ - Отчет * ЗЕЛЕНЫЙ - Quickbutton / Подуслуги * Желтый - Добавления Сдвига времени: * Собственный Сервер добавления через Интернет. * Загрузка и установка дополнительных особенностей через Интернет от сервера Близнеца. * Использование Ваш собственный Личный сервер добавления (формируют это в/etc/useraddon.xml). * Создают Ваш собственный Satellites.xml, который только включает спутники, в которых Вы нуждаетесь. Camd: * Назначают различный Camds на Станции/поставщиков (Автокулак). * Изменение названия и различных функций по собственному меню. Демон / Сервер / Клиенты: * Dreambox может использоваться как printserver (BP-> Параметры настройки Устройства-> Принтер (LPD), ЧАСТО ЗАДАВАЕМЫЕ ВОПРОСЫ в базе данных). * Dropbear (ssh) теперь переключаемый (BP-> Отдельно оплачиваемые предметы-> SSH). * Сервер Upnp / Клиент * автокрепление, примеры в/etc/automount.conf. Устройства, NFS или СИФЫ автоматически установлены. Идеально для DVD - или Сеть - Двигатели (Редактор может быть найден в BP-> Отдельно оплачиваемые предметы-> Автокрепление). * Inadyn (Демон для различных DYNDNS-услуг). * небольшой Апач (HTTP-сервер, основанный на HTTPD). * СЕРВЕР NFS (основанный на NFS-Kernel-Modul). * Редактор, чтобы формировать Cron-Deamon Infobar / OSD: * Поставщика и Спутник покажут в Infobar (в зависимости от кожи). * EMM, ECM или переключаемый Показ "ExpertInfos". * Picon (показывает станционную эмблему) * Показ Onlinestatus, когда Коробка связана с Интернетом (должен быть активизирован в BP-> Отдельно оплачиваемые предметы/параметры настройки/онлайн) * Прядильщик (время ответа, теперь приспосабливаемое, 0, выключено) * Picons может быть изменен между Близнецом и форматом DMM *, положение infobar может быть изменено * HDTV-эмблема в Infobar (DM80..) Файлы / Устройства: * Менеджер Устройства (формат, повысьтесь и другие функции), * Поддержка CD-ROM/DVD независимо от того, если это - ЯЗЬ Ур USB * температура HDD-и работа, видимая в меню. * ценности HDPARM для диска жестких дисков могут быть изменены меню. * установка ОБМЕНА и начало автоматически. * Hotplug для USB-устройств (показаны в OSD - Может быть установлен, используя Менеджера устройства), EPG: * EPG-автосохранение - Сохраняет данные EPG в определенное время * дополнительный EPG-Infos (BP-> Информация) * Продолжительность текущего Случая в programm кратком обзоре (BP-> Информация-> EPG) * EPG-Serch. Поиск Названием, описанием или собственным текстом. Дополнительный: * Dreamnetcast (shoutcast-игрок) с Streamripper (прямая регистрация от сервера и кодирование в mp3s). * Погодный Плагин с 10 днями предсказан. * читатель RSS/RDF с ГЛАВНЫМ списком от RSS-бойскаута. * Webcam-зритель со способом FullScreen. * Будильник (играет mp3s в неподвижное время), * Информация Системы: Многие дополнительный приемник infos как нормы потока, ядро - память - и processinfos. * Собственные Подлинники могут быть начаты через Синюю Группу. * Ядерные модули могут быть, перезаряжают отдельно. * Пароль может быть изменен меню. * Тайник EPG и Освежительный напиток EPG (обновляет EPG ночью), приспосабливаемый по BP. * вспыхивающие часы, делая запись в резерве. * Календарь для формата iCalendar + Напоминание (поддержанный MAC, KDE, Тандербердом, календарем Google, Rainlendar …), Стандартная папка-/etc/ical. * eTorrent - клиент потока, основанный на ctorrent. Может управляться completly по OSD * Шашка электронной почты (Краткий обзор Вашего POP3 или счетов IMAP + SSL) * краткий обзор различных систем Борьбы, которые использует текущая станция. * Quickbutton * Превращение картин, также автоматически данными EXIF. * "GP2 Controlr" Расширение Firefox, чтобы получить доступ к функциям Коробки. * ReZapp, Выключатель назад на канал на неподвижном времени (BP-> Экстра-> ReZapp) * Резюме HDTV-каналов в Channellist-> Спутники (DM80..) Новый: * предварительно установленный HD-Skin * Многие (частично внутренний) изменения, которые позволяют, очищать все меню полностью Затруднительное положение + Обновления: * RSS-читатель * Погодный Плагин * краткий обзор Крепления теперь с изображениями * видит CVS Это, Изображения не содержат ключей, ни softcams. Резервные копии или другие измененные Изображения не от нас и не будут поддержаны! Загрузка через Базу данных Большое спасибо и весело проводит время Ваша Команда Близнеца <http://www.i-have-a-dreambox.com>
