yupiter
Несканируется Eutelsat 36 градусов,толко на этой прошивке,что может быть,прошивка PKT_IP99_E2_HAARP_v3c
---------- Сообщение добавлено в 20:13 ---------- Предыдущее сообщение размещено в 20:11 ----------
А ну там ести уже готовые спутники.Как их удалить?
Нет уже после прошивке вбито
В какой прошивке??? Может Вы просто чей то бэкап заливали?? Прросканируйте заново 36Е, а перед этим замените файл спутников как рекомендуют в посте №185
dormidont1981
Вышла новая прошивка от поляков для 99 серии. Скачать можно тут http://satforum.info/.
Added by PKT:
[ALL] migration to OpenPLI
[ALL] add more than 100+ plugins to download
[ALL] fixed aspect ratio selection in A/V setting.
[ALL] fix network setup
[ALL] transparency fix if any window opend while infobar is dimming
[ALL] added recording setup to menu
[ALL] PermanentClock : added progress bar & other small fixes
[ALL] fix subservices reload
[ALL] fix green key support in infobar
[ALL] Basic HD skin removed - it is already as default
[ALL] fix opkg
[ALL] add djcrash Updater v1.2.5
[ALL] update Backup Manager v1.7
- add /media/Points for backup
- add backup of timer
[ALL] converters update
[ALL] new approach to control of FrontPanel
[ALL] fix SCART Output
[ALL] add missing: subtitle setup & autolanguage setup to main menu
[ALL] fix GS when subtitled was selected by Audio Menu
[ALL] GraphMultiEPG -fixed compatibility to other skins ( without our fonts )
[ALL] 1st boot wizard fix
[ALL] Languages: 1st is English, 2nd - Polish, others is alphabetical order
[ALL] fix Backup Aurorestore - now 100% working
[ALL] FrontPanel Setup extended to Time&Name, Time&Number
[ALL] video settings optimization
[ALL] update skins for PIG support
[ALL] fix some STB's for PIG support
[STI7111&7105] Fix CEC support
[OCT1008+] fix picture viewer and videoplayback
[GM7162] VFD icons support
[GM7162] VFD Icons: 2nd record Icon, Full HD, HD, Disk Icon while REC.
[GM7162] added CAM activation if is Disabled in Standby mode.
[GM7162] fix icons off in standby/deepstandby
[GM7162] keymap support Portal key
[UFS910] fix restart network interface
[SFXXX] added support of LongEPG key
[IPBOX] optimization evremote
[ALL] increase stability
[...] and many many other changes not included in chagnelog.
Known Issues:
[Cuberevo] some STBs hang on if skin with PIG is used so we do not recommended such skins.
[SF1008/SE] not tested so use at your own risk.
[IPBOX] we're not sure about the TVN HD and other HD channels problems are solved
Dodane przez PKT:
[Wszystkie] migracja do OpenPLI
[Wszystkie] dodane ponad 100 pluginów do pobrania
[Wszystkie] naprawione ustawianie formatu obrazu w menu ustawień A/V.
[Wszystkie] naprawione ustawienia sieci
[Wszystkie] naprawiona przeźroczystość okien przy wygaszaniu paska info
[Wszystkie] dodane ustawienia nagrywania do menu
[Wszystkie] PermanentClock : dodany pasek postępu i inne drobne poprawki
[Wszystkie] naprawione przeładowanie serwisów
[Wszystkie] naprawiona obsługa zielonego klawisza przy wywołaniu z paska info
[Wszystkie] Basic HD skin usunięty - występuje teraz jako domyślny
[Wszystkie] naprawa opkg
[Wszystkie] dodany plugin djcrash Updater v1.2.5
[Wszystkie] aktualizacja Backup Manager v1.7
- dodane archiwum /media/Points
- dodane archiwum timera
[Wszystkie] aktualizacja konwerterów
[Wszystkie] nowe rozwiązanie obsługi FrontPanela
[Wszystkie] naprawa obsługi wyjścia SCART
[Wszystkie] uzupełnione w menu: napisy i język automatyczny
[Wszystkie] naprawiony GS gdy zostały wywołane przez menu Audio
[Wszystkie] graficzne EPG - ustawiona kompatybilność ze skinami ( nie posiadającymi naszych fontów )
[Wszystkie] naprawiona grafiak Wizard'a przy pierwszym uruchomieniu
[Wszystkie] języki: pierwszy - angielski, drugi - polski, pozostałe w kolejności alfabetycznej
[Wszystkie] naprawa Backup Aurorestore - 100% sprawny
[Wszystkie] FrontPanel Setup rozszerzona obsługa o Czas i nazwę kanału, Czas i numer Kanału
[Wszystkie] optymaizacja ustawień obrazu
[Wszystkie] aktualizacja skinów o funkcje PIG (Obraz w grafice)
[Wszystkie] naprawa działania PIG w niekórych dekoderach
[STI7111&7105] naprawa obsługi CEC
[OCT1008+] naprawa przegłądarki zdjęć i otwarzacza video
[GM7162] dodana obsługa ikon VFD
[GM7162] ikony VFD: ikona drugiego nagrywania, Full HD, HD, ikona dysku przy nagrywaniu.
[GM7162] dodana aktywacja EMU gdy jest ustawione wyłączanie go w trybie czuwania.
[GM7162] naprawa wygaszania ikon przy przechodzeniu w tryb czuwania i głębokiego czuwania
[GM7162] dodana obsługa klawisza Portal - wywołuje BluePanel
[UFS910] naprawiony restart kart sieciowych
[SFXXX] dodana obsługa długiego naciśnięcia klawiszy
[IPBOX] optymalizacja komunikacji pilota
[Wszystkie] poprawa stabilności
[...] i wiele więcej innych zmian nie opisanych tutaj.
Znane problemy:
[Cuberevo] niektóre dekodery zawieszają się na skinach z PIG, wiec nie zalecamy ich stosowania
[SF1008/SE] nie testowany, wiec uzywasz na wlasne ryzyko.
[IPBOX] nie jesteśmy pewni czy rozwiązaliśmy problem z TVN HD i innymi HD.
Special THX to TDT and all betatesters.
Specjalne podziękowania za wkład dla TDT i betatesterów.
FTP login: root, passwd: pkteam
---------- Сообщение добавлено в 14:37 ---------- Предыдущее сообщение размещено в 14:31 ----------
еще бы кто написал как ее ставить )))
ugis
Эта и есть usb ,попробовал на ipbox 55 ,но NEBULA v3 лучше работает,на этой Pli версии работает nStreamVOD_OE1.6 .
ugis
yupiter...Hyperion image нету в flash. Смотры в прошлой сообщ., добавыл ссылку на NEBULA v3. Хорошо работает.Прошивается давольно долго.Не угробь рессивер.
ugis
Да ставил ее 36 градусов несканирует
LOF/H ставил 10750 - сканирует 36e
---------- Сообщение добавлено в 13:19 ---------- Предыдущее сообщение размещено в 13:13 ----------
Народ подскажите пошагово как в 99 й прошить Hyperion, что бы на флешку
19 пост в этой теме почитайте,устанавливается через плагин multiboot-это самый простой вариант.
