PKT IP9900/IP99/IP55 E2 HAARP v3c Image
Enigma2 OpenSource SH4 Duckbox Project GIT-3297 PKT SVN-1360 HAARP v3c Image
Image is designed for installation in SATA/Flash device
Support receiver: IP9900/IP99/IP55
Kernel stm24-207
Added by sh4 Duckbox Team:
- [eplayer3] playback aac-he streams with aac-lc
- fix timing problem in filepush
- [Player2 179/191] possible fix for chopped DTS sound on some files
- [e2 nightly-0]introduce 3D Mode for OSD ( paint OSD twice in Side by Side or Top and Bottom )
- [libeplayer3] support for OSD 3D modes for subtitles
- [libeplayer2, libeplayer3] Close directory file handles after looking for subtitle files
- new BusyBox 1.19.3
- extend streamproxy to support linuxdvbapi5
- [player2_191/player2_179]resturucture dts fix. The fix now only applys to DTS streams and the playback time is only corrected on time differences up to 50ms this MAY fix some issues with async sound
- [player191] adoptions from p179; bugfix for 710x receiver (HD channel problems)
- [player2_191] fsynth bugfix
- fix ufs910 audio on scart
- use utf8 as python default
- adapt wrong page_offset and improve mem
- [stmfb] fix wrong alpha behaviour
- [tuxtxt] add freezer work on hd
- update: boost 1.48.0 and ffmpeg 0.8.7
- update: curl v7.23.1
- [player191] readd orfhd sound fix
Added by PKT:
- new function "live ecm" in infobar
- show Channel Number on Front Pannel + ON/OFF in setup menu
- upgrade CrossEPG svn 268
- fix qwerty VirtualKeyboard
- fix Backup/Autorestore function | LABEL=RECOVERY required
- fix channel number showing on VFD if long channel name
- set home directory to /root
- EPG description on channel list -> ON
- change reading of ecm.info
- new converters and skins modifications
- fix dimmer action when channel switch
- fix parsing PROV, CAID, PID
- moving EPG support to KeyMapper
- ReferencePKT optimization
- set PKTGoldHD as default skin
- fix CIFS mount if passwd is empty
- MPlayer fix GS of EOF
- upgrade formating device in Install Manager
- update EmuManager v1.0.6
- add sh4Cam support & gbox fix
- font FIX moved to Skin setup
- remove unnused files or BP menu settings modification
- fix showing processes
- res_emu in standby add in BP->Settings
- tune and fix sys_info
- add showing /Loaded modules/ in BP ->Menu ->System
- update WIFI scripts:
* add detecting of supported USB WLAN adapters
* user is informed about unsupported device
* optimize selecting WLAN driver
* optimize starting WLAN driver
- fix show event-progress in channel selection
- fix crossEPG
- PKT InstallManager 1.2.2
- PKT KeyMapper 1.5
- update Permanent Clock
- fix EMUManager russian translate
- add green button support in Media Player
- fix streamproxy after reboot
- add support for fake cccam
+ change only in HAARP V3c version
- picons update
- added BPanel activation in MoviePlayer ( key blue )
- added compatibility to standard non PKTeams skins
- fix dot on VFD if channel number is not available
- fix for radio mode wallpaper
- fix showing picons on channels list, when are located in /hdd/picon folder
- added /media/usb/picon to picons search folders
- 2nd generation of speed up channels zap
- add standby smooth extingushing TV
- channel list update
- display quality improvement
- new BluePanel 2D v3.1.21 with graphic interface:
-- added function to check update is needed
-- added color & numeric keys actions support to immidiate plugin/function/menu activation
-- 1st row - keys: 1, 2, 3, 4
-- 2nd row - keys: 5, 6, 7, 8
-- 3rd row - keys: red, green, yellow, blue
-- added menu key action support
-- added changelog information menu
-- added synchronization of local time and date from NTP server
-- added on/Off the smooth extinguish TV while switching to standby mode
- fix missing reference.dat
- fix international fonts switch in Skin Setup
- screenshot OSD fix
- fix GS on GlassHD skin
- upgrade e2 to 2011-09-13-experimental
- fix exception on hddtemp running on box with no sata port
- fix GS in TimeShift path Menu
- fix sata HDD sleep in standby
- add new Webinterface v1.6.8
- add WebMedia 4.0
- add new Multimedia items in BP
- fix firmware update checking
- [ALL] extinguishing fix
- [ALL] MediaPlayer GS fix - RuntimeError
- [ALL] fix crash system after Factory reset
- [ALL] probably sleeping hdd fix in standby
- [ALL] set default highSR=OFF
- [ALL] fix Left/Right Key action in KeyMapper
- [ALL] add % loaded e2 process while BOX have VFD display
- [ALL] fix exit from CutListEditor
- [ALL] fix HelpMenu
- [ALL] add warning of incompatible STB for DTS Downmix
- [ALL] ReplaceFont fix + other small fixes
- [ALL] remove e2 progress at first start
- [IP99] fix 2nd DVB-S2 tuner
- [IP55] fix timeshift
FTP login: root, passwd: pkteam
9900
SATA
http://www.2shared.com/file/iYHM20rn/PKT_IP9900_E2_HAARP_v3c_Image.html
FLASH
http://www.2shared.com/file/zedblDOs/PKT_IP9900_E2_HAARP_v3c_Image_.html
99
SATA
http://www.2shared.com/file/Bed3m91s/PKT_IP99_E2_HAARP_v3c_Image.html
FLASH
http://www.2shared.com/file/h8kFj_pY/PKT_IP99_E2_HAARP_v3c_Image_Fl.html
55
FLASH
http://www.2shared.com/file/UCTpYhC8/PKT_IP55_E2_HAARP_v3c_Image_Fl.html
