появилось после 0000 (часики были и только) испробовал все способы востановить.заставка и поверх ''IDENT Error--UNINITIATE!" . Е2 работает .востановительные имеджи загружаются а толку нет. лог снимаю с ресивера и ошибки :
Board: STx7111-Mboard (MB618) [32-bit mode]
info: Disregarding any EPLD
U-Boot 1.3.1 (Nov 15 2010 - 17:57:53) - stm23_0043 - YW 1.0.018 Rel
DRAM: 128 MiB
NOR: 8 MiB
NAND: 512 MiB
In: serial
Out: serial
Err: serial
IdentID : 09 00 0b 00 00 65 76
Hit ESC to stop autoboot: 3
Force command mode:Select boot (current boot system : spark):
1. spark(up key)
2. enigma2(down key)
3. RS232 Upgrade u-boot(left key)
4. Force into factory mode(right key)
Input Select:
set bootargs to bootargs_spark
Unprotecting Flash...
.. done
Un-Protected 2 sectors
Erasing Flash...
.. done
Erased 2 sectors
Writing to Flash...
........ done
Protecting Flash...
.. done
Protected 2 sectors
0
## Booting image at a0080000 ...
Image Name: Kernel-Ramdisk-Image
Image Type: SuperH Linux Multi-File Image (gzip compressed)
Data Size: 5867346 Bytes = 5.6 MiB
Load Address: 80800000
Entry Point: 80801000
Contents:
Image 0: 2970083 Bytes = 2.8 MiB
Image 1: 2897250 Bytes = 2.8 MiB
Verifying Checksum ... OK
Uncompressing Multi-File Image ... OK
found phy at addres = 1
stmac_phy_get_addr(): id1 = 0x7, id2 = 0xc0f1
stb_id = 90b006576
Loading Ramdisk to 80d3c000, length 002c3562 ... OK
Starting kernel console=ttyAS1,115200 rw ramdisk_size=6144 init=/linuxrc root=/d
ev/ram0 ip=192.168.0.69:192.168.3.119:192.168.3.1:255.255.0.0:lh:eth0
ff stmmac
eth=msglvl:0,phyaddr:1,watchdog:5000 bigphysarea=4000 nwhwconf=device:eth0,hwadd
r:24:00:0B:00:65:76 Manufacture=Spark-Project STB_ID=09:00:0B:00:00:65:76 - 0x00
53d000 - 2897250 ...
[MAIN] YWIDENT_Init error,errCode=0xff03
ASSERT!! /home/d03ljf/workspace/spark_app_ret_duo_A34/src/main/main.c (3207)
[MAIN] init finish,errCode=0
[ YWDBASEv_GetData][ 578] error 0x1f40006
[ YWDBL_CommGetVolume][ 288] YWDBLi_CommGetByFldNoWithDefault COMM_VOLUME errTy
pe = 0X1F40006 Unknown
[YWDBLi_ScGetByFieldNo][ 101] YWDBL_GetSysCfgField uFieldNo = 15[YWDBL_ScGetRes
olution][ 496] YWDBLi_ScGetByFieldNo SYSCFG_DEFINITE errType = 0X1F40006 Unknow
n
########################## uiCompSize[0X00AE8BCC]================
ресивет GI8120. может не тот u-boot залил? если есть поделитесь родным u-boot .
всем спасибо.
