twman
Покажите кто нибудь конфиг с лебедем.Редактировать его замучался .Плюсы и 3к работают , а лебедь никак.На Матрикс 2 работает с теми же параметрами.Лог с викарда просто молчит если канал не пашет.Ещё некоторые каналы сплюсов не работаю .Например 5 канал Украина у него
случае есм не 2710?
Настройки пербирал разные переписывал в итоге сейчас так:
[global]
active = 1
debug = 3
syslog = 3
log_udp = 192.168.1.100:514
daemon = 1
[webif]
port = 8081
debug = 0
[dvb]
#rule = caid=0D00,2600;accept
rule = caid=0500;ident=040600;accept #NTV+
rule = caid=0500;ident=050b00;accept #NTV+HD
rule = caid=4ae1;ident=0,11,15;ident:=0;accept # tricolor
rule = caid=2710;ident=0,000006;accept #Lybid
[reader]
name = cardreader
type = tuxbox
device = /dev/sci0
debug = 0
[reader]
active = 1
name = funcard
type = funcard
fw_file = /var/keys/FunCard.a90
extee_file = /var/keys/ee.bin
extee_size = 64
intee_file = /var/keys/int_ee.bin
auto_update = 1
debug = 3
[filter]
name = dvb
rule = caid=4ae1;ident=11;limit=1,10,0,0;accept=funcard
rule = caid=0500;ident=040600,042700,023100,042300,043800,041700,042400,042800,040810;accept #NTV_SD all viaccess
rule = caid=0500;ident=050B00;sid=2f45,2f46,2f47,2f48,2f49,2f4a,3715,3716,3717,3718,3719,371A,4E85,4E86,4E87,4E88,4E89,4E8A,4E8B;accept #NTV_HD
rule = reject
[reader]
active = 1
name = A
type = newcamd525
account = ..........:10000:0102030405060708091011121314
reconnect_delay = 5
keepalive = 120
debug = 1
filter = dvb
[reader]
active = 1
name = B
type = newcamd525
account = ...........:10850
reconnect_delay = 3
emm_cache = 1
ecm_ttl = 5000
filter = Lybid
keepalive = 300
roman5
У моей катерины так. Ваш конфиг желательно удалить, простите...
[global]
active = 1
log_udp = 192.168.x.xx:514
log_size = 30
syslog = 1
debug = 1
daemon = 0
[webif]
active = 0
port = 8081
[dvb]
active = 1
type = DVBAPI3
filter = dvb
rerequest_not_decoded = 1
cadev_offset = 1
debug = 1
sdt = 1
ecm_info = 1
auto_update = 1
[filter]
name = dvb
rule = caid=0500;ident=040600,040620;accept=ntv_hd
rule = caid=4ae1;ident=000011;accept=tricolor
rule = caid=2710;ident=000000,000006;accept=lybid
rule = reject
[reader]
active = 1
name = ntv_hd
type = newcamd525
account = xxx:xxx@xxx:xxx:0102030405060708091011121314
reconnect_delay = 20
emm_cache = 1
ecm_ttl = 5000
keepalive = 300
debug = 1
[reader]
active = 1
name = tricolor
type = newcamd525
emm_cache = 1
ecm_ttl = 5000
keepalive = 300
debug = 1
[reader]
active = 1
name = lybid
type = newcamd525
emm_cache = 1
ecm_ttl = 5000
keepalive = 300
debug = 1
twman
Пробовал ваш целиком -неидёт вообще ничего.Частично пробую вставлять -всё равно не идёт.
Фильтр поставил ваш всё что должно-идёт спасибо ,а птица никак.
18:16:36 192.168.1.100 lybid: Server detected: mpcs
18:16:36 192.168.1.100 lybid: CAID 2710, providers 1, UA 0000000000000000
18:16:36 192.168.1.100 lybid: provider 0: id 000000, SA 0000000000000000
18:16:37 192.168.1.100 lybid: auto update disabled
18:16:37 192.168.1.100 lybid: provider data updated
18:16:37 192.168.1.100 lybid: reconnecting... connected
Corwin
Судя по логу у вас идет раздача по сетке, так смотрите может на серваке проблемы.
kuchmich
Здравствуйте,как уже писал раньше прошу помощи в установке эмулятора Wicard на свой Azbox,на одном из форумов нашел такоеAttached Files Attached Files
File Type: zip WICARD MODIFIED UPC 100% OK ENIGMA 1.zip (266.4 KB, 0 views)
File Type: zip wicard-1.15-paranoia.zip (8.37 MB, 1 views) ,подскажите пожалуйста что мне нужно скачать для Azbox,напоминаю что эмулятор нужно устанавливать с нуля.Заранее большое СПАСИБО.
А с нашего форума не пробовали установить по инструкции?
ndminion
kuchmich ну тут же столько инструкций писали по установке викарда, даже вылаживали иструкции....только нужно пользоваться поиском!
vadim72
вот для детского сада - делов минута - просто раскидать и дать права правильные в bin и script 755
остальным не обязательно
в конфиге под себя правим одну только строчку
log:por@ip:port
перезагруз реса
синяя кнопка ваш spzCAMD указать викард и включить
если не получится читай не парь мазги и читай инструкцию для новичков
или ищи мою какда что
  • викард.zip
    241,7 KB · Просмотры: 289
kuchmich
Вы по своей инструкции сами попробуйте что нибудь сделать,я с очками не могу ничего увидеть.
---------- Сообщение добавлено в 22:50 ---------- Предыдущее сообщение размещено в 22:26 ----------
ИЗВЕНИТЕ уже розобрался как увеличить.Большое СПАСИБО за помощь,я так понимаю что по этой инструкции можно устанавливать и 15 версию или нет.
vadim72
можно всё но здесь нужно знать как у вас не получится - есть технические тонкости
15 версию которая в инете ставится по другой раскладке и она хуже и нужна только для того чего вам не нужно
ставте мою и не мучайтесь - она самая надёжная и простая
twman
Не знаю у меня 1.14 стала сразу быстро простым копированием с этим конфигом потом заменил бин с 1.15 тоже нормально.(кроме птицы).Поставил сегодня Алонзо думал ваш викард быстро поставлю ничего не пошло.Викарда не было в списке камов.Откатился на Kernel : ULK-3.9.2 нет пока времени разбираться.
vadim72
что вы сравниваете
чел. пишет в теме где всё есть а прочитать либо ленится либо он понимает что псё равно для него то тёмный лес
и как эы он это освоил если даже для меня (с эмулями стаж 12 лет) от имиджа к имиджу бывает повозишься
kuchmich
Здравствуйте,уважаемый vadim72 вы очень верно подметили что для меня это темный лес,я всего около года штудирую свой AZBOX и то только в свободное время которого у меня не так уж много и многого уже научился благодаря вашей и других знатоков помощи за которую всем вам большое СПАСИБО.Хочу еще научиться и знать куда прописывать кофинги шары на шару и куда вписывать ключи которые находятся там же,я пишу об кофингах на шару которые на спутниковом мире,помогите если кто имеет время объяснить.Установил ваш wicard но бисы непоказывают.Заранее всем большое СПАСИБО.И еще знаю что не втему но нигде не могу найти soft.cam на каналы-Sinema TV Arsion HD и Sinema TV ASK HD.
qantrom
вот мой конфиг
что тут не правильно,из за чего не идёт либить тв ?
+++ идут нормально
gold99
Вот мой,работают и карты +++ ,и телекарта.
[global]
log = /tmp/wicardd.log
log_size = 100
debug = 3
daemon = 0
[webif]
port = 8081
debug = 0
[dvb]
type = DVBAPI3
auto_update = 1
dre_fix = 1
sdt = 1
ecm_info = 1
debug = 1
[reader]
name = karta1
type = tuxbox
device = /dev/sci0
debug = 3
[reader]
name = karta2
type = tuxbox
device = /dev/sci1
debug = 3
name = shara11
type = newcamd525
account = 111:1111@111111111:4031:0102030405060708091011121314
reconnect_delay = 10
keepalive = 300
debug = 0
[reader]
name = biss
type = emubiss
caid = 2600
file = /usr/keys/SoftCam.Key
ecm_queue_size = 8
debug = 3
netkachev70
мой конфиг, все работает
sergik01
вот мой конфиг
+++ идут нормально
Как всегда типичная ошибка.
Отсутствие фильтра.
Если не использовать фильтр, то работает обычный перебор идентов.
Типа как-то работает, да и ладно.
Но серверы часто чудят. И вместо реального идента вдруг начитают раздавать с нулевым.
Лебедь как раз из это числа.
Так вот, при включении канала Викард определяет, какие иденты есть в потоке и что раздаёт сервер.
У Лебедя 6 идент. А если сервер чудит, то раздаёт с нулём.
Викард не находит сервера с нужным 6 идентом и естественно ничего не делает.
А вот фильтр как раз и помогает исправить косяк таких чудных серверов.
В фильтре можно переназначить тот же 6 идент в нолик.
Тогда Викард найдёт в списке серверов этот чудный сервак и будет на него направлять запросы.
---------- Сообщение добавлено в 20:07 ---------- Предыдущее сообщение размещено в 19:59 ----------
[reader]
name = biss
type = emubiss
caid = 2600
Для справки для тех, кто никогда док файл не читал.
Такого параметра как caid = 2600 нет у Викарда.
И если посмотреть лог, то Викард там напишет по поводу этой непонятной строки.
wicardd: Wrong or unused config key 'caid = 2600'
Если притормаживает триколор хлаява с wicardd . В приложение конфиги .
  • wicardd.rar
    378 байт · Просмотры: 111
