помогите пожалуйста разобраться в чем дело
после попытки сделать двойную загрузку с флэшки родная и с ресивера Е2
получил BOOTING
прошел все процедуры с 9 страницы и получил следующее
r─pЮЧЧxosPc0 serial#d2da3dd2e1c17d395405a24b816cdeeb subid 0xc4
xenv cs2 ok
Power supply: OK
DRAM0 OK (a)
DRAM1 OK (a)
zboot ok
* SMP863x zboot start ...
* Version: 2.4.0-2.8.0.1
* Started at 0x91000000.
* Configurations (chip revision: 6):
* Use 8KB DRAM as stack.
* Support XLoad format.
* Enabled BIST mode.
* Enabled memory test mode.
* Use internal memory for stage0/1.
Boot from flash (0x48000000) mapped to 0x8c000000.
Found XENV block at 0x8c000000.
CPU clock frequency: 300.37MHz.
System clock frequency: 200.25MHz.
DRAM0 dunit_cfg/delay0_ctrl (0xf34111ba/0x00098888).
DRAM1 dunit_cfg/delay0_ctrl (0xf34111ba/0x00098887).
Using UART port 0 as console.
Board ID.: "852-E2"
Chip Revision: 0x8634:0x86 .. Mismatched (0x8634:0x84 detected).
Setting up H/W from XENV block at 0x8c000000.
Setting <SYSCLK avclk_mux> to 0x00000000.
Setting <SYSCLK hostclk_mux> to 0x00000100.
Setting <IRQ rise edge trigger lo> to 0xff28ca00.
Setting <IRQ fall edge trigger lo> to 0x0000c000.
Setting <IRQ rise edge trigger hi> to 0x0000009f.
Setting <IRQ fall edge trigger hi> to 0x00000000.
Setting <IRQ GPIO map> to 0x20090820.
Setting <PB default timing> to 0x10101010.
Setting <PB timing0> to 0x10101010.
Setting <PB Use timing0> to 0x000003f4.
Setting <PB timing1> to 0x00110101.
Setting <PB Use timing1> to 0x000003f3.
Setting <PB timing2> to 0x105f1010.
Setting <PB Use timing2> to 0x000003f8.
PB cs config: 0x000e0040 (use 0x000e0040)
Enabled Devices: 0x00021ace
BM/IDE PCIHost Ethernet I2CM I2CS USB PCIDev2 PCIDev3 SCARD
MAC: 00:02:14:14:44:bf
PCI IRQ routing:
IDSEL 2: INTA(
#1 4) INTB(
#1 4) INTC(
#1 4) INTD(
#1 4)
IDSEL 3: INTA(
#1 5) INTB(
#1 5) INTC(
#1 5) INTD(
#1 5)
Smartcard pin assignments:
OFF pin = 0
5V pin = 1
CMD pin = 2
Setting up Clean Divider 2 to 96000000Hz.
Setting up Clean Divider 4 to 33333333Hz.
Setting up Clean Divider 5 to 25000000Hz.
Setting up Clean Divider 6 to 20000000Hz.
Setting up Clean Divider 7 to 20000000Hz.
GPIO dir/data = 0x76000038/0x76000000
UART0 GPIO mode/dir/data = 0x6e/0x00/0x00
UART1 GPIO mode/dir/data = 0x6e/0x00/0x00
XENV block processing completed.
Found existing memcfg: DRAM0(0x08000000), DRAM1(0x08000000)
Heap/Temp/Temp1/Dest start at 0x14000000/0x16000000/0x15000000/0x12000000.
Default boot index: 0
Scanning ROMFS image at 0x8c040000 (0x48040000) .. Found.
ROMFS found at 0x8c040000, Volume name = YAMON_XRPC
Found 1 file(s) to be processed in ROMFS.
Processing xrpc_xload_yamon_ES4_prod.bin (start: 0x8c040090, size: 0x0002fe84)
Checking zboot file signature .. Not found.
Trying xrpc_xload format .. OK
Checking zboot file signature at 0x13000000 .. OK
Decompressing to 0x91200000 .. OK (453328/0x6ead0).
Load time total 168/250 msec.
Execute final at 0x91200000 ..
* YAMON ROM Monitor
* Revision 02.06-SIGMADESIGNS-01-2.8.0.1
Memory: code: 0x11000000-0x11040000, 0x11200000-0x11204000
reserved data: 0x11240000-0x12440000, PCI memory: 0x12440000-0x12840000
Environment variable 'start' exists. After 1 seconds
it will be interpreted as a YAMON command and executed.
Press Ctrl-C (or do BREAK) to bypass this.
ROMFS found at 0xac080000, Volume name = MIPS_LINUX_XRPC
ac080040 : Name = ., Type = dir, Size = 00000000, Next = 00000040
ac080060 : Name = .., Type = hard link, Size = 00000000, Next = 00000060
ac080090 : Name = xrpc_xload_vmlinux_ES4_prod.bin, Type = file, Size = 0064bf44, Next = 00000000
Checking zboot signature.. it's not zboot file.
Error : Internal, code = ffffffff
YAMON>
YAMON> setxenv
(0x00) 4 a.avclk_mux 0x00000000
(0x00) 8 a.board_id "852-E2"
(0x00) 4 a.cd2_freq 0x05b8d800
(0x00) 4 a.cd4_freq 0x01fca055
(0x00) 4 a.cd5_freq 0x017d7840
(0x00) 4 a.cd6_freq 0x01312d00
(0x00) 4 a.cd7_freq 0x01312d00
(0x00) 4 a.chip_rev 0x86340086
(0x00) 4 a.enable_devices 0x00021ace
(0x00) 4 a.gpio_data 0x76000000
(0x00) 4 a.gpio_dir 0x76000038
(0x00) 4 a.gpio_irq_map 0x20090820
(0x00) 4 a.hostclk_mux 0x00000100
(0x00) 4 a.irq_fall_edge_hi 0x00000000
(0x00) 4 a.irq_fall_edge_lo 0x0000c000
(0x00) 4 a.irq_rise_edge_hi 0x0000009f
(0x00) 4 a.irq_rise_edge_lo 0xff28ca00
(0x00) 4 a.pb_cs_config 0x000e0040
(0x00) 4 a.pb_def_timing 0x10101010
(0x00) 4 a.pb_timing0 0x10101010
(0x00) 4 a.pb_timing1 0x00110101
(0x00) 4 a.pb_timing2 0x105f1010
(0x00) 4 a.pb_use_timing0 0x000003f4
(0x00) 4 a.pb_use_timing1 0x000003f3
(0x00) 4 a.pb_use_timing2 0x000003f8
(0x00) 4 a.pcidev1_irq_route 0x01010101
(0x00) 4 a.pcidev2_irq_route 0x01010101
(0x00) 4 a.pcidev3_irq_route 0x02020202
(0x00) 4 a.pcidev4_irq_route 0x02020202
(0x00) 4 a.scard_5v_pin 0x00000001
(0x00) 4 a.scard_cmd_pin 0x00000002
(0x00) 4 a.scard_off_pin 0x00000000
(0x00) 4 a.uart0_baudrate 0x0001c200
(0x00) 4 a.uart0_gpio_data 0x00000000
(0x00) 4 a.uart0_gpio_dir 0x00000000
(0x00) 4 a.uart0_gpio_mode 0x00007f6e
(0x00) 4 a.uart1_baudrate 0x00002580
(0x00) 4 a.uart1_gpio_data 0x00000000
(0x00) 4 a.uart1_gpio_dir 0x00000000
(0x00) 4 a.uart1_gpio_mode 0x00007f6e
(0x00) 4 a.uart_console_port 0x00000000
(0x00) 4 a.uart_used_ports 0x00000002
(0x00) 4 l.cs0_size 0x00000000
(0x00) 4 l.cs1_size 0x00000000
(0x00) 4 l.cs2_part1_offset 0x00000000
(0x00) 4 l.cs2_part1_size 0x00020000
(0x00) 4 l.cs2_part2_offset 0x00020000
(0x00) 4 l.cs2_part2_size 0x00020000
(0x00) 4 l.cs2_part3_offset 0x00040000
(0x00) 4 l.cs2_part3_size 0x00040000
(0x00) 4 l.cs2_part4_offset 0x00080000
(0x00) 4 l.cs2_part4_size 0x00680000
(0x00) 4 l.cs2_part5_offset 0x00700000
(0x00) 4 l.cs2_part5_size 0x00100000
(0x00) 4 l.cs2_parts 0x00000005
(0x00) 4 l.cs2_size 0x00800000
(0x00) 4 l.cs3_size 0x00000000
(0x00) 4 x.boot 0x00020000
(0x00) 4 x.csf 0x00000002
(0x00) 4 x.d0.cfg 0xf34111ba
(0x00) 4 x.d0.dl0 0x000a4444
(0x00) 4 x.d1.cfg 0xf34111ba
(0x00) 4 x.d1.dl0 0x000a4444
(0x00) 4 x.ds 0x00020080
(0x00) 4 x.dt 0x00000001
(0x00) 4 x.mux 0x00000701
(0x00) 3 y.startdelay "1"
(0x00) 4 z.boot0 0x00040000
(0x00) 4 z.boot1 0x00080000
(0x00) 4 z.boot2 0x00040000
(0x00) 4 z.boot3 0x00080000
(0x00) 16 a.build_date "TD210:20090123"
(0x00) 19 a.eth_mac "00.02.14.14.44.BF"
(0x00) 31 a.linux_cmd "mem=107m console=ttyS0,115200"
(0x00) 45 y.start dump romfs 0xac080000;load zbf 0xac080090; go
(0x00) 4 x.pll3 0x01020057
(0x00) 15 y.ipaddr "192.168.0.100"
(0x00) 15 y.subnetmask "255.255.255.0"
(0x00) 13 y.gateway "192.168.0.1"
79 records, 1715 bytes
YAMON> setenv ipaddr 192.168.0.0100
Updating XENV block at 0x48000000.
XENV verification OK.
YAMON> setenv subnetmask 255.255.255.0
YAMON> setenv gateway 192.168.0.1
YAMON> net up
Please initialize net first: net init | initpci
YAMON> net init
Ethernet driver for EM86XX (v1.0)
(MAC 00:02:14:14:44:bf, tx_desc/rx_desc = 16/32)
em86xx_eth:
pen(em86xx_eth) - Full-duplex mode
em86xx_eth:
pen(em86xx_eth) - 100 Mbit/s
em86xx_eth ethernet start
ipaddr: 192.168.0.0100
subnetmask: 255.255.255.0
gateway: 192.168.0.1
YAMON> net up
YAMON> ping 192.168.0.38
64 bytes ICMP-ECHO-REPLY user data received from 192.168.0.38
YAMON> load -b tftp://192.168.0.38/vmlinux.bin 0x90020000
About to load tftp://192.168.0.38/vmlinux.bin
Press Ctrl-C to break
Start = 0x90020000, range = (0x90020000,0x9095880f), format = BINARY
Length = 0x938810 (9668624)
Checksum = 0x2254194d
YAMON>
YAMON> go
em86xx_eth ethernet stop
Linux version 2.6.22.19-19-the_ripper (root@debian) (gcc version 4.3.2 (Debian 4.3.2-1.1) )
[URL=http://www.sat-expert.com/forum/usertag.php?do=list&action=hash&hash=1]#1 85[/URL] PREEMPT Mon May 31 16:44:40 CEST 2010
Configured for SMP863x (revision ES6+/RevA+), detected SMP8634 (revision ES7/RevB).
Detected CPU/System/DSP Frequencies: 300.37/200.25/300.37MHz
SMP86xx Enabled Devices under Linux/XENV 0x48000000 = 0x00021ace
Valid MEMCFG found at 0x10000fc0.
CPU revision is: 00019068
Determined physical RAM map:
memory: 06be0000 @ 10020000 (usable)
User-defined physical RAM map:
memory: 06ae0000 @ 10020000 (usable)
Wasting 2098176 bytes for tracking 65568 unused pages
Initrd not found or empty - disabling initrd
On node 0 totalpages: 92928
DMA zone: 726 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 92202 pages, LIFO batch:31
Normal zone: 0 pages used for memmap
Built 1 zonelists. Total pages: 92202
Kernel command line: mem=107m console=ttyS0,115200
Primary instruction cache 16kB, 2-way, physically tagged, linesize 16 bytes.
Primary data cache 16kB, 2-way, virtually tagged, cache aliases, linesize 16 bytes
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
PID hash table entries: 2048 (order: 11, 8192 bytes)
Using 150.188 MHz high precision timer.
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 96384k/109440k available (4018k kernel code, 12948k reserved, 1013k data, 4408k init, 0k highmem)
Calibrating delay loop... 295.93 BogoMIPS (lpj=147968)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
tangox: creating TLB mapping for 0x20000000 at 0xc0000000, size 0x08000000.
PCI: Initializing SMP86xx PCI host controller
PCI: Remapped PCI I/O space 0x58000000 to 0xc8020000, size 64 kB
PCI: Remapped PCI config space 0x50000000 to 0xc8004000, size 10 kB
PCI: device 1 disabled
PCI: device 4 disabled
PCI: Configured SMP86xx as PCI slave with 128MB PCI memory
PCI: Region size is 16384KB
PCI: Map DMA memory 0x10020000-0x16b00000 for PCI at 0x11000000
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Time: TANGOX clocksource has been installed.
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
Created /proc/cpucache_info entry.
Tango2 frequency scaling module installed.
NTFS driver 2.1.28 [Flags: R/W DEBUG].
JFFS2 version 2.2. б╘ 2001-2006 Red Hat, Inc.
fuse init (API version 7.8)
SGI XFS with large block numbers, no debug enabled
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Generic RTC Driver v1.07
Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x0 (irq = 9) is a 16550A
serial8250: ttyS1 at MMIO 0x0 (irq = 10) is a 16550A
loop: module loaded
nbd: registered device at major 43
tango2_enet: ethernet driver for SMP863x internal mac
tango2_enet: detected phy at address 0x01
tango2_enet: mac address 00:02:14:14:44:bf
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ide0: SMP86xx Bus Mastering IDE controller
Probing IDE interface ide0...
hda: Fordisk IDE DOM, ATA DISK drive
hda: no 80 conductors cable, falling back to lower udma mode
hda: selected mode 0x42
hda: set to Ultra DMA mode 2
ide0: DMA enabled for ATA DISK hda
ide0 at 0x223c0-0x223c7,0x22398 on irq 26
hda: max request size: 128KiB
hda: 501760 sectors (256 MB) w/0KiB Cache, CHS=980/16/32, UDMA(33)
hda: cache flushes supported
hda: hda1 hda2 hda3
QLogic Fibre Channel HBA Driver
physmap flash device CS2: 0x800000 at 0x48000000
CS2: Physically mapped flash: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Using physmap partition definition
Adding partition
[URL=http://www.sat-expert.com/forum/usertag.php?do=list&action=hash&hash=1]#1 -[/URL] #5
Creating 5 MTD partitions on "CS2: Physically mapped flash":
0x00000000-0x00020000 : "CS2-Part1"
0x00020000-0x00040000 : "CS2-Part2"
0x00040000-0x00080000 : "CS2-Part3"
0x00080000-0x00700000 : "CS2-Part4"
0x00700000-0x00800000 : "CS2-Part5"
PCI: Enabling device 0000:00:02.2 (0000 -> 0002)
ehci_hcd 0000:00:02.2: EHCI Host Controller
ehci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:02.2: irq 22, io mem 0x62008000
ehci_hcd 0000:00:02.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration
#1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 4 ports detected
driver tangox-ehci-hcd, 10 Dec 2004
TangoX USB initializing...
tangox-ehci-hcd tangox-ehci-hcd: TangoX USB 2.0
tangox-ehci-hcd tangox-ehci-hcd: new USB bus registered, assigned bus number 2
tangox-ehci-hcd tangox-ehci-hcd: irq 48, io mem 0xa0021400
tangox-ehci-hcd tangox-ehci-hcd: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb2: configuration
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
TCP cubic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 4408k freed
Algorithmics/MIPS FPU Emulator v1.5
Initializing random number generator... done.
Starting network...
ip: RTNETLINK answers: File exists
eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
udhcpc (v1.16.1) started
Sending discover...
Sending discover...
Sending select for 192.168.0.36...
Lease of 192.168.0.36 obtained, lease time 86400
deleting routers
route: SIOCDELRT: No such process
adding dns 145.155.10.1
===> Starting services...
[TD210] INITIALIZED END
[TD210] SLEEP MODE OFF
HDD Detected
RF Detected
SCART Detected
PCB Version : 0xb
Micom Version : 0xb
===> [1] telnetd starting...
===> [2] mounting DOM ...
kjournald starting. Commit interval 5 seconds
EXT3 FS on hda1, internal journal
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
mount: mounting /dev/hda2 on /PLUGINS failed: Invalid argument
mount: mounting /dev/hda3 on /DISK2 failed: Invalid argument
mount: mounting /dev/hda4 on /Download failed: No such device or address
insmod: can't read '/MMP/modules/2.6.22/llad.ko': No such file or directory
insmod: can't read '/MMP/modules/2.6.22/em8xxx.ko': No such file or directory
===> Starting vsftpd...
AZBOX login: root
Password:
login[701]: root login on 'ttyS0'
AZBOX[~]$ ifconfig
eth0 Link encap:Ethernet HWaddr 00:02:14:14:44:BF
inet addr:192.168.0.36 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:46 errors:0 dropped:0 overruns:0 frame:0
TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:12377 (12.0 KiB) TX bytes:1812 (1.7 KiB)
Interrupt:46
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
<.168.0.100 netmask 255.255.255.0 broadcast 192.168.0.255 up
AZBOX[~]$ ping -c 5 192.168.0.38
PING 192.168.0.38 (192.168.0.38): 56 data bytes
64 bytes from 192.168.0.38: seq=0 ttl=64 time=2.933 ms
64 bytes from 192.168.0.38: seq=1 ttl=64 time=0.691 ms
64 bytes from 192.168.0.38: seq=2 ttl=64 time=0.673 ms
64 bytes from 192.168.0.38: seq=3 ttl=64 time=0.666 ms
64 bytes from 192.168.0.38: seq=4 ttl=64 time=0.629 ms
--- 192.168.0.38 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 0.629/1.118/2.933 ms
AZBOX[~]$
AZBOX[~]$ cd /tmp
AZBOX[tmp]$ ls
HAVE_HDD HAVE_RF HAVE_SCART random-seed update
AZBOX[tmp]$ chmod a+x update
AZBOX[tmp]$ ./update /MMP/backup_kernel
INFILE: /MMP/backup_kernel, OUTFILE:/dev/mtdblock4
Progress 0
Progress 1
Progress 100
HX_DD: 6656+0 records in
HX_DD: 6656+0 records out
Updating old kernel finished!
Rebooting...
The system is going down NOW!
Sent SIGTERM to all processes
Sent SIGKILL toRestarting system.
xenv cs2 ok
Power supply: OK
DRAM0 OK (a)
DRAM1 OK (a)
zboot ok
перезагрузился
