maxiU-Boot 1.3.1 (Jan 16 2010 - 16:24:09) - by SoLaLa
DRAM: 32 MB
Flash: 16 MB
In: serial
Out: serial
Err: serial
selected Image to start: bootdesc_0
Hit any key to stop autoboot: 0
## Booting image at a0040000 ...
Image Name: Linux-2.6.17.14_stm22_0037
Image Type: SuperH Linux Kernel Image (gzip compressed)
Data Size: 1697141 Bytes = 1.6 MB
Load Address: 84401000
Entry Point: 84402000
Verifying Checksum ... OK
Starting kernel console=ttyAS0,115200 root=/dev/mtdblock3 mem=38m bigphysarea=12
80 coprocessor_mem=2m@0x04000000,2m@0x04200000 - 0x00000000 - 0 ...
Linux version 2.6.17.14_stm22_0037 (root@develgod) (gcc-Version 4.1.1 (STMicroel
ectronics/Linux Base 4.1.1-23)) #127 PREEMPT Tue Jul 1 19:41:06 CEST 2008
STMicroelectronics STb7100 Reference board initialisation
STb7100 version 3.x
Built 1 zonelists
Kernel command line: console=ttyAS0,115200 root=/dev/mtdblock3 mem=38m bigphysar
ea=1280 coprocessor_mem=2m@0x04000000,2m@0x04200000
st-coprocessor: Failed to reserve memory at 0x04000000
st-coprocessor: Failed to reserve memory at 0x04200000
PID hash table entries: 256 (order: 8, 1024 bytes)
Using tmu for system timer
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 29968k/38912k available (2821k kernel code, 8924k reserved, 360k data, 8
8k init)
PVR=04061100 CVR=30480000 PRR=00009100
I-cache : n_ways=2 n_sets=256 way_incr=8192
I-cache : entry_mask=0x00001fe0 alias_mask=0x00001000 n_aliases=2
D-cache : n_ways=2 n_sets=512 way_incr=16384
D-cache : entry_mask=0x00003fe0 alias_mask=0x00003000 n_aliases=4
Mount-cache hash table entries: 512
CPU: STb710x
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
NET: Registered protocol family 2
IP route cache hash table entries: 512 (order: -1, 2048 bytes)
TCP established hash table entries: 2048 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 2048 bind 1024)
TCP reno registered
bigphysarea: Allocated 1280 pages at 0x847ab000.
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Device probe found data for platform device lirc
lirc_dev: IR Remote Control driver registered, at major 61
lirc_dev: lirc_register_plugin: sample_rate: 0
lirc_dev: lirc_register_plugin: plugin lirc_stm owner 00000000
STM LIRC plugin has IRQ 125
Lirc STM: Using IRB mode
STMicroelectronics LIRC driver configured
STPIO layer initialised
VFD_Controller Type : NEW Kathrein VFD
STMicroelectronics ASC driver initialized
ttyAS0 at MMIO 0xb8032000 (irq = 121) is a asc
ttyAS1 at MMIO 0xb8033000 (irq = 120) is a asc
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
s_env_mac[0] = 0
s_env_mac[1] = 0
s_env_mac[2] = :
s_env_mac[3] = 1
s_env_mac[4] = d
s_env_mac[5] = :
s_env_mac[6] = e
s_env_mac[7] = c
s_env_mac[8] = :
s_env_mac[9] = 0
s_env_mac[10] = 0
s_env_mac[11] = :
s_env_mac[12] = c
s_env_mac[13] = 9
s_env_mac[14] = :
s_env_mac[15] = 9
s_env_mac[16] = 7
get ether addr = 0, 1d, ec, 0, c9, 97
mac hi address = 97c9, lowaddress = ec1d00
nwhw_config: device not found
ata1: SATA max UDMA/133 cmd 0xB9209000 ctl 0xB9209820 bmdma 0x0 irq 170
ata1: SATA link down (SStatus 0)
scsi0 : sata_stm
Generic ST boards onboard flash device: 0x01000000 (16.0Mb) at 0x00000000
Onboard_Flash: Found 1 x16 devices at 0x0 in 16-bit bank
Onboard_Flash: Found 1 x16 devices at 0x800000 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Onboard_Flash: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 2
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Creating 10 MTD partitions on "Onboard_Flash":
0x00000000-0x00020000 : "1st stage BL: 0xA000.0000-0xA001.FFFF"
0x00040000-0x00200000 : "Kernel: 0xA004.0000-0xA01F.FFFF"
0x00200000-0x002a0000 : "Config FS: 0xA020.0000-0xA029.FFFF"
0x002a0000-0x004e0000 : "Root FS: 0xA02A.0000-0xA04D.FFFF"
0x004e0000-0x00ae0000 : "Application FS: 0xA04E.0000-0xA0AD.FFFF"
0x00ae0000-0x00c00000 : "Emergency FS: 0xA0AE.0000-0xA0BF.FFFF"
0x00c00000-0x00fc0000 : "Data FS: 0xA0C0.0000-0xA0FB.FFFF"
0x00020000-0x00040000 : "BL1 Config: 0xA002.0000-0xA003.FFFF"
0x00fc0000-0x00fd0000 : "BL2 Config: 0xA0FC.0000-0xA0FC.FFFF"
0x00fd0000-0x01000000 : "2nd stage BL: 0xA0FD.0000-0xA0FF.FFFF"
ST40_start_host_control
ST40_start_host_control proceeding
ST40-ehci ST40-ehci.2: ST EHCI Host Controller
ST40-ehci ST40-ehci.2: new USB bus registered, assigned bus number 1
ST40-ehci ST40-ehci.2: irq 169, io mem 0xb91ffe00
ST40-ehci ST40-ehci.2: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: Product: ST EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.17.14_stm22_0037 ehci_hcd
usb usb1: SerialNumber: STB7100_EHCI
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usbcore: registered new driver libusual
pegasus: v0.6.13 (2005/11/13), Pegasus/Pegasus II USB Ethernet driver
usb 1-1: new high speed USB device using ST40-ehci and address 2
usb 1-1: Product: USB2.0 Hub
usb 1-1: configuration #1 chosen from 1 choice
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
usbcore: registered new driver pegasus
usbcore: registered new driver asix
usbcore: registered new driver cdc_ether
usbcore: registered new driver net1080
usbcore: registered new driver zaurus
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
stssc layer initialized
STMicroelectronics - Coprocessors st231 Init
st231-0 Coprocessor -------------------------------------------
flags 0001 RAM start at 0xa4000000 size 0x00200000
cop. addr 0x04000000
Channels : Not defined
IRQ : not used
st231-1 Coprocessor -------------------------------------------
flags 0001 RAM start at 0xa4200000 size 0x00200000
cop. addr 0x04200000
IRQ : not used
TCP bic registered
TCP highspeed registered
NET: Registered protocol family 17
VFS: Mounted root (cramfs filesystem) readonly.
Freeing unused kernel memory: 88k freed
/etc/init.d/rcS running...
Remounting root file system in read-write mode...mount: Can't find / in /etc/fst
ab
: Success
mount: Mounting / on (null) failed: Success
[FAILED]
/etc/rcS.d/S200mountfs: /etc/rcS.d/S200mountfs: 91: cannot create /etc/mtab: Rea
d-only file system
mount: Can't find / in /etc/fstab
: Success
Mounting other file systems...[ OK ]
Bringing up the loopback interface...[ OK ]
Setting up hostname...(none)
[ OK ]
BusyBox v1.1.0 (2006.03.02-09:48+0000) Built-in shell (ash)
config/start.sh does not exist.... running /app/start.sh
PARAM : boot_param_version=11
PARAM : №V)
PARAM : bootcmd=bootm a0040000
PARAM : bootdelay=1
PARAM : autoload=n
PARAM : stdin=serial
PARAM : stdout=serial
PARAM : stderr=serial
PARAM : bootargs=console=ttyAS0,115200 root=/dev/mtdblock3 mem=38m bigphysarea=1
PARAM : bootcmd_0=bootm a0040000
PARAM : ethaddr=00:1d:ec:00:c9:97
BOOT PARAM VERSION = 11
mknod: /dev/vfd: File exists
vfd_driver_new: module license 'Marusys' taints kernel.
tmp_pin = 8474d548
VFD_Driver Init
/app/start.sh: /app/modules_sys/bin/stapi_modlist_mknod.sh: 14: /app/modules_sys
: Permission denied
MODULE_INSTALL_DIR = /app/modules_sys/modules26
BIN_INSTALL_DIR = /app/modules_sys/bin
the reference tree was released on W650
stos_core_init_module(): Initializing STOS Module
stcommon_core_init_module(): Initializing STCOMMON Module
Setting all Group priorities done
PTI Clock: Cut 3.0 detected -> setting PTI workaround clock.
TC_Ram test...
Writing...
Reading...
ok
Preproc Clock: Cut 3.0 detected -> setting Preproc clock.
stpio_core_init_module(): Initializing STPIO Module
Load module fdma [254] by insmod (pid 117)
STFDMA_ClbckMgr: task created ... Priority=99
Load module stpti4_core by insmod (pid 119)
Load module stclkrv_core by insmod (pid 120)
hdmi_i2c_init : Initializing I2CHDMI kernel Module
the adapter name is i2c-ssc-0 number 0
the adapter name is i2c-ssc-1 number 1
the adapter name is i2c-ssc-2 number 2
Checking I2C bus status..
Name = ssc clock/ssc data
Status CLK = 1, Data = 1
tmp = 8474d728
hdmi : detected @ 0x3a on adapter i2c-ssc-2 :
The address of the second client is : (0x3a)
hdmi : detected @ 0x50 on adapter i2c-ssc-2 :
The address of the first client is : (0x50)
mod_lxload_init: Initializing LXLOAD kernel Module, StartAddress: 0x04200000
Load module lxload[253] by insmod (pid 130)
LXLOADER virtual io kernel address of phys 0xa4200000 = 0xa4200000
/dev/stapi/lxload
mknod -m 0660 /dev/stapi/lxload c 253 0
loading audio binary file
lxload_open: major=253 minor=0
setting up Audio LX in NON-DEBUG mode
lxload_release: major=253 minor=0
Starting Audio LX by disabling reset
LX loaded:
Base: 0xa4200000
Last: 0xa4347284
mod_lxload_exit: Exiting LXLOAD kernel Module
The I/O memory region 0x04200000 is released successfully
Unload module lxload by rmmod (pid 141)
mod_lxload_init: Initializing LXLOAD kernel Module, StartAddress: 0x04000000
Load module lxload[253] by insmod (pid 142)
LXLOADER virtual io kernel address of phys 0xa4000000 = 0xa4000000
/dev/stapi/lxload
setting up LX in NON-DEBUG mode
Starting video LX by disabling reset
LX loaded:
Base: 0xa4000000
Last: 0xa403403c
The I/O memory region 0x04000000 is released successfully
Unload module lxload by rmmod (pid 152)
EMBXSHM-PortClosed: with RT priority done with syscall. PID=159
EMBX EMBXSHM-PortClosed: task created ...
EMBXSHM-NewPort: with RT priority done with syscall. PID=158
EMBX EMBXSHM-NewPort: task created ...
mknod -m 0660 /dev/stapi/sti2c_ioctl c 253 0
Load module staudlx_core [252] by insmod (pid 170)
sthdmi_ioctl_init_module: Initializing STHDMI IOCTL Module
Load module sthdmi_ioctl[251] by insmod (pid 172)
mknod -m 0660 /dev/stapi/sthdmi_ioctl c 251 0
Load module stvid_ioctl[250] by insmod (pid 180)
mknod -m 0660 /dev/stapi/stvid_ioctl c 250 0
Load module stevt_ioctl [249] by insmod (pid 188)
mknod -m 0660 /dev/stapi/stevt_ioctl c 249 0
stblit_ioctl_init_module: Initializing STBLIT IOCTL Module
Load module stblit_ioctl[248] by insmod (pid 196)
mknod -m 0660 /dev/stapi/stblit_ioctl c 248 0
stlayer_ioctl_init_module: Initializing STLAYER kernel Module
Load module stlayer_ioctl[247] by insmod (pid 204)
mknod -m 0660 /dev/stapi/stlayer_ioctl c 247 0
Load module stpti4_ioctl [246] by insmod (pid 212)
mknod -m 0660 /dev/stapi/stpti4_ioctl c 246 0
Load module stclkrv_ioctl [245] by insmod (pid 220)
mknod -m 0660 /dev/stapi/stclkrv_ioctl c 245 0
stdenc_ioctl_init_module: Initializing STDENC IOCTL Module
Load module stdenc_ioctl[244] by insmod (pid 228)
mknod -m 0660 /dev/stapi/stdenc_ioctl c 244 0
stvtg_ioctl_init_module: Initializing STVTG IOCTL Module
Load module stvtg_ioctl[243] by insmod (pid 236)
mknod -m 0660 /dev/stapi/stvtg_ioctl c 243 0
stvout_ioctl_init_module: Initializing STVOUT IOCTL Module
Load module stvout_ioctl[242] by insmod (pid 244)
mknod -m 0660 /dev/stapi/stvout_ioctl c 242 0
stvmix_ioctl_init_module: Initializing STVMIX IOCTL Module
Load module stvmix_ioctl[241] by insmod (pid 252)
mknod -m 0660 /dev/stapi/stvmix_ioctl c 241 0
stvbi_ioctl_init_module: Initializing STVBI kernel Module
Load module stvbi_ioctl[240] by insmod (pid 260)
mknod -m 0660 /dev/stapi/stvbi_ioctl c 240 0
Load module stmerge_ioctl [239] by insmod (pid 268)
mknod -m 0660 /dev/stapi/stmerge_ioctl c 239 0
Load module staudlx_ioctl[238] by insmod (pid 276)
mknod -m 0660 /dev/stapi/staudlx_ioctl c 238 0
utils_ioctl_init_module: Initializing UTILS IOCTL Module
Load module utils_ioctl[237] by insmod (pid 284)
mknod -m 0660 /dev/stapi/utils_ioctl c 237 0
Load module stinj_ioctl [236] by insmod (pid 292)
mknod -m 0660 /dev/stapi/stinj_ioctl c 236 0
Load module stpio_ioctl [235] by insmod (pid 300)
mknod -m 0660 /dev/stapi/stpio_ioctl c 235 0
Unload module stttx_core by insmod (pid 309)
mknod: /dev/stpio_dev: File exists
CIMAX DeviceInit
SysConf device Init
LMI_SYS VCR0 = 00d40000
LMI_SYS VCR1 = 0f041000
LMI_SYS MIM0 = 861a0247
LMI_SYS MIM1 = 01010022
LMI_SYS SCR = 00000000
LMI_SYS STR = 35b06455
LMI_SYS COC = 00000000
LMI_SYS SDRA0 = 08001900
LMI_SYS SDRA1 = 08001900
LMI_SYS CIC = 00000249
LMI_SYS SDMR0 = 00000000
LMI_SYS SDMR1 = 00000000
LMI_VID VCR0 = 00d40000
LMI_VID VCR1 = 17101000
LMI_VID MIM0 = 861a0247
LMI_VID MIM1 = 01010022
LMI_VID SCR = 00000000
LMI_VID STR = 35b06455
LMI_VID COC = 00000000
LMI_VID SDRA0 = 14001900
LMI_VID SDRA1 = 14001900
LMI_VID CIC = 00000249
LMI_VID SDMR0 = 00000000
LMI_VID SDMR1 = 00000000
UFS910 Button Device Driver(by Marusys Co.)
TestModMgr::CheckTestMode CmdLine = console=ttyAS0,115200 root=/dev/mtdblock3 me
m=38m bigphysarea=1280 coprocessor_mem=2m@0x04000000,2m@0x04200000
CMDLINE = console=ttyAS0,115200 root=/dev/mtdblock3 mem=38m bigphysarea=1280 cop
cannot fine test mode
TestModeMgr::CheckMode : TestMode Disabled
Oops: 0000 [#1]
Pid : 345, Comm: pvrmain
PC is at i2cdev_open+0x44/0xc0
PC : 845fd204 SP : 858cfec8 SR : 40008000 TEA : c01644c4 Tainted: P
R0 : 000001e0 R1 : 3b12f6f8 R2 : 858ce000 R3 : 858ce000
R4 : 00000001 R5 : 85884220 R6 : 84df7f20 R7 : 40008000
R8 : 85884220 R9 : 84df7f20 R10 : 84df7f60 R11 : 00000000
R12 : 00000000 R13 : 8446f420 R14 : 84f71b24
MACH: 0000002c MACL: acacacd9 GBR : 2956cf10 PR : 845fd1d4
Call trace:
[<8446fc7e>] chrdev_open+0x11e/0x2c0
[<84460a52>] __dentry_open+0xd2/0x300
[<8446fb60>] chrdev_open+0x0/0x2c0
[<84460d4c>] nameidata_to_filp+0x4c/0x60
[<84460da8>] do_filp_open+0x48/0x60
[<84485660>] expand_files+0x0/0x3a0
[<84460dea>] do_sys_open+0x2a/0x100
[<84460dfe>] do_sys_open+0x3e/0x100
[<84405198>] syscall_call+0xc/0x10
[<84460ee0>] sys_open+0x0/0x20
Cannot connect UDP socket to 172.16.1.1
Cannot connect UDP socket, udp log disabled
tuxbox mgcamd v1.31 by mixvt (compiled Oct 27 2008 23:09:59)
[mg] Net:1:7:2:7s Show ecm:1, emm:1 Up:1 Au:2 Dir:0 Osd:no:80:0 Cache:7 Log:2:17
2.16.1.1:28007 Reread:0
[mg] Ecm cache time: 15
Box type: stapi
Conax.Key error 2: No such file or directory
Keys readed
AutoRoll.Key error 2: No such file or directory
newcamd keep alive: 300, incoming port: 21000
[mgcam] emm thread started
route: SIOC[ADD|DEL]RT: Network is unreachable
[mgcamd] tps update started.
/data/keys/tps.bin error 2: No such file or directory
